  1. Sep 14, 2024 at 6:11 AM
    TundraJedi
    TundraJedi New Member
    Eric
    2021 Tundra Pro
    SDHQ Dual battery kit. This kit requires patience… I took me hours just to replace the power steering fluid line under the engine and the battery tray mounted under the tiny space between the fender liner wall and sheet metal… mostly due to working in tiny spaces and dealing with hose clamps in awkward positions (this was the “gotcha, haha you thought this would be easy but it’s not” moment). Overall, instructions were fine. And if I can do it, anyone can.
    My only concern after install was added protection to the terminals, so I’m adding fuses at the main battery terminal and aux battery terminal… I went to SDHQ for the kit and to Blaze Off-road for the terminal fuses.
    There are no YouTube videos for a 2.5 gen Tundra, but there’s enough out there to search for what’s needed.
    The plan is to add a 1000w inverter but still not sure where to put it.
  2. Sep 14, 2024 at 6:51 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    That windshield reservoir relo kit is clutch. It’s nicely tucked away in the back. Thing is though, I think I’ll have to use a funnel now to refill the blinker fluid.
  3. Sep 14, 2024 at 7:25 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Very nice, looks OEM
    TundraJedi[QUOTED] likes this.
  4. Sep 14, 2024 at 7:35 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    For those search engine experts: I've looked but I'm such a noob (apparently) and can't seem to find it. Is there a video or a walk through on changing out the rear cigarette lighter socket ti a USB port? I have a bench front seat. Any and all help or pointing in the right direction will be appreciated.
    Thank you in advance.
    Edsel
  5. Sep 14, 2024 at 7:36 AM
    TundraJedi
    Eric
    2021 Tundra Pro
    True. I was worried about the size of it; only 2 quarts. But that’s probably fine. Cut an old spray bottle and made a funnel because after this install, no more money to spend on a $5 funnel.
  6. Sep 14, 2024 at 9:25 AM
    centex
    centex New Member
    antennamastsrus.com short antenna.
    Florida AF, mgm16trdpro and bulldog93 like this.
  7. Sep 14, 2024 at 9:52 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    What's she for? Project not on the tundra, right?!
    PermaFrostTRD[QUOTED] likes this.
  8. Sep 14, 2024 at 10:12 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Went for a morning rip. Played with the lower bypass tubes get rid of the small bump chatter. Felt damn good and was a on tear on my loop until the Christmas tree dash. Smoked an abs sensor. Easy fix.
    Powertank setup is awesome I like it better than my dual arb under the seat.
  9. Sep 14, 2024 at 10:12 AM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Truck has started to sound like it was falling apart when parking or backing out of a spot. Skid plates were creaking and got really bad. I’ve got the full skid from Talons Garage. I put some plastic washers between the plate and the mounting point. It was easier than I thought it would be. I loosened and lowered the engine skids without taking them off. I was able to get the washer on one bolt at a time. It made a dramatic difference. The noise is all but gone now. I think I can hear a little creak at the cat shield/transmission/transfer case shields, but it may be my imagination. I may take a look at those tomorrow.
    Used these washers from Lowe’s
  10. Sep 14, 2024 at 11:03 AM
    PermaFrostTRD
    Northern NY
    Correct. A new (but used) transmission for my daughter’s 2009 Subaru outback
  11. Sep 14, 2024 at 11:09 AM
    French Avocado
    Utah / Wyo
    Where did you purchase these? I need to do this as the creaking is bothering me.
    Henry1jg and jeffw6236[QUOTED] like this.
  12. Sep 14, 2024 at 11:38 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Says lowe’s
  13. Sep 14, 2024 at 11:42 AM
    French Avocado
    Utah / Wyo
    Thanks - I have difficulty reading
  14. Sep 14, 2024 at 12:21 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Parked it at the end of the driveway as I sealed the driveway this am. Back is aching!
    Tundra-XP, woods, mgm16trdpro and 6 others like this.
  15. Sep 14, 2024 at 12:24 PM
    Looks good.:thumbsup:
    What product did you use? I need to do mine.
  16. Sep 14, 2024 at 12:30 PM
    Xcumminsguy
    NY
    Thanks Jim. VelveTop, black 5g bucket, yellow writing. Nice and thick, used 4 buckets. Dumped it all into 1/2 of a 55g fiber drum to blend and assure matching color. Took about 3 hrs. I think I measured the sq footage at 1550 or so.
  17. Sep 14, 2024 at 12:42 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    Towed a couple mini kei trucks with my looooooooooooooooooooooooooooooooooooooong bed
  18. Sep 14, 2024 at 1:12 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Productive weekend so far..
    Revesol steering wheel
    2nd DIY oil change with the Motive kit(highly recommend) and installed Fumoto
    Installed some rubber washers on my skids to hopefully get rid of some creaks n pops
    20240913_143127.jpg 20240914_110012.jpg 20240914_112845.jpg 20240914_121257.jpg
    Tundra-XP, Florida AF, woods and 13 others like this.
  19. Sep 14, 2024 at 1:13 PM
    This.....
    BR73, ATV25, bulldog93 and 1 other person like this.
  20. Sep 14, 2024 at 1:16 PM
    Xcumminsguy
    NY
    That’s the stuff. 37.99 5g here.
    Jim LE 1301 likes this.
  21. Sep 14, 2024 at 1:19 PM
    centex
    centex New Member
    Cabin filter. No clue when it was changed last as I bought the truck used.
  22. Sep 14, 2024 at 1:31 PM
    French Avocado
    Utah / Wyo
    Rear diff breather mod. Did not use The threaded bolt hole because it is too close to the dual exhaust line.IMG_1521.jpg IMG_1521.jpg IMG_1519.jpg
  23. Sep 14, 2024 at 1:49 PM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    I have a Talon set, the same thing. Winter gets pretty creaky. I did the same as you but used pieces of an old dirt bike inner tube. I like your nylon washer idea better.
  24. Sep 14, 2024 at 2:05 PM
    Pac12AfterDark
    Pac12AfterDark New Member
    Man I have been so close to pulling the trigger on a daihatsu
    Lassie likes this.
  25. Sep 14, 2024 at 2:19 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    This should be what you are looking for. The video of the crewmax shows the replacement for a USB port. The other short video gives a good idea of the clip layout on the bench seat panel. The two panels seem to be fairly similar.
    https://www.youtube.com/watch?v=FWDCs7CejrM
    https://www.youtube.com/watch?v=kQNmSAyqIvU
    Pangaea, Henry1jg, Florida AF and 2 others like this.
  26. Sep 14, 2024 at 2:47 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Changed air filter and added Perry parts bump stops.
    BR73, pvn.beluga and bulldog93 like this.
  27. Sep 14, 2024 at 3:11 PM
    jeffw6236
    Jeff
    San Antonio
    lowes. Tried to catch the part number or size in the packaging
  28. Sep 14, 2024 at 4:37 PM
    koditten
    Kirk
    Midland of the Mitten
    Been waiting for an update.
    I want a CO2 can for my RV. Id rather carry a small can that needs no power to air up tires before a tow.
  29. Sep 14, 2024 at 5:28 PM
    TacomaTRD4x402
    Southern California
    Here's the rubber ones I put on today. They seem to do the trick so far.
  30. Sep 14, 2024 at 5:30 PM
    GeoJoe
    If they are street legal in your state - much better.
