Alternator Mount SNAP!
Discussion in '1st Gen Tundras (2000-2006)' started by jlawson4623, Sep 13, 2024.
  1. Sep 13, 2024 at 4:23 PM
    jlawson4623
    jlawson4623 [OP] New Member
    Alabama
    2000 Tundra Sr5 2UZ AC
    451K miles
    Alternator finally gave out at 450k. I go to install new one and find the bracket has broken off. Does anyone know what the front plate is that I will need to fix this? Guess I’ll be doing a timing belt change since I’m going in.. IMG_4550.jpg IMG_4549.jpg
  2. Sep 13, 2024 at 4:27 PM
  3. Sep 13, 2024 at 5:14 PM
    jlawson4623
    Alabama
    451K miles
    I found it, oil pump…
  4. Sep 13, 2024 at 5:21 PM
    Power steering pump?
  5. Sep 13, 2024 at 5:34 PM
    jlawson4623
    Alabama
    451K miles
    The question now is.. Do I have to pull the motor to change the pump?
  6. Sep 13, 2024 at 5:36 PM
    jlawson4623
    Alabama
    451K miles
    It’s the oil pump I’m pretty sure.
  7. Sep 13, 2024 at 5:44 PM
    Ahhh ok, do you have a v6 motor or 8pistons, update your info on your avatar page
  8. Sep 13, 2024 at 5:46 PM
    bfunke
    bfunke Tundra Curmudgeon
    Both pans must be removed on the 2UZ to remove the oil pickup tube which is attached to the back of the pump by two studs.
    FrenchToasty and Jack McCarthy like this.
  9. Sep 13, 2024 at 5:52 PM
    bfunke
  10. Sep 13, 2024 at 6:16 PM
    Damn, dude. That corner broke off? Talk about poorly casted metal. Well at least you got to 450k miles before it happened.
  11. Sep 13, 2024 at 6:33 PM
    jlawson4623
    Alabama
    451K miles
    4.7L
  12. Sep 13, 2024 at 7:18 PM
    jlawson4623
    Alabama
    451K miles
    Can this be done with it in the truck?
  13. Sep 14, 2024 at 6:11 AM
    bfunke
    The video shows him doing it in the truck with a 4WD 2Gen.
  14. Sep 14, 2024 at 6:18 AM
    jlawson4623
    Alabama
    451K miles
    Yea I watched the video, just didn’t know if anything is different with it being a 2nd Gen clearance wise.
  15. Sep 14, 2024 at 8:48 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    yuck, well hopefully my alternator lasts a lot longer....is this unusual to happen
  16. Sep 14, 2024 at 1:58 PM
    Shit, if it were me, I'd have to spend a couple hours drilling it in two places, tapping the holes, then and bolting it back together with JB WELD inside the crack seam. The combo should be good enough to hold until the next timing belt change, where it'd be more reasonable to change it.
    Weagle likes this.
  17. Sep 15, 2024 at 6:19 PM
    jlawson4623
    Alabama
    451K miles
    I dropped the bottom pan today, much easier than I expected. It looks like I can get to the bolts to remove the pickup tube and the bolts to remove the pump. IMG_4566.jpg
  18. Sep 15, 2024 at 6:26 PM
    Wow. I wonder if that’s typical of what the bottom end looks like on our trucks. For 450k, it doesn’t look too bad. A wee-bit sludgy perhaps.
  19. Sep 15, 2024 at 6:47 PM
    jlawson4623
    Alabama
    451K miles
  20. Sep 16, 2024 at 8:33 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    i think it looks pretty clean for over 450k. good luck...mean that in a positive way
  21. Sep 28, 2024 at 9:53 AM
    jlawson4623
    Alabama
    451K miles
    I’m getting back to it this afternoon. Hopefully get the new pump on at least with the time I have free to work on it.
    whodatschrome and JakeJake like this.
  22. Oct 21, 2024 at 11:07 AM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 CaptainsSeats
    Freshly Killed Piezo Buzzr!, Re-paint 04-2025
    https://www.youtube.com/watch?v=BTIm0D2A5o8
    ...check out the big brain on @jlawson4623....
    Been almost a month...Im hoping to hear that it worked for him.
  23. Oct 21, 2024 at 12:24 PM
    jlawson4623
    Alabama
    451K miles
    I was able to pull the pump off with the 2nd pan still bolted up. However, I had to remove one of the studs for the pickup tube for it to clear. I ended up dropping the 2nd pan in fear I wouldn’t get a good gasket seal around the bottom of the new pump. It was a nightmare to clean due to it not having enough clearance to drop to the ground. I successfully got everything back together two weekends ago. A job I hope I never have to do again. Especially when it all started with the alternator going out.
    mdfish97, Weagle and ps8820[QUOTED] like this.
  24. Oct 21, 2024 at 12:31 PM
    JakeJake and Weagle like this.
