What causes timing to retard at startup SR5 5.7 flex fuel
Discussion in 'Performance and Tuning' started by westley, Sep 7, 2024.
  1. Sep 7, 2024 at 3:39 PM
    westley
    westley [OP] New Member
    west slater
    Need to find out more about Toyota tundra5.7 SR5 default vvt timing at startup.
    Flex fuel
  2. Sep 11, 2024 at 6:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The ECU uses the engine coolant temp for timimg. I believe 2 set points are knock retard minimum ect of 140deg and starts adding when it hits 176deg.
  3. Sep 11, 2024 at 6:50 PM
    centex
    centex New Member
    Makes sense. Cold engines don’t like a lot of timing.
  4. Sep 13, 2024 at 6:11 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    What are you wanting to know? Your question is pretty generic.
    Mdl likes this.
  5. Sep 13, 2024 at 1:36 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Also, what year is your Tundra? I can pull up the VVT maps and show you what’s going on
