Speaker Rattle FIX
Discussion in '3rd Gen Tundras (2022+)' started by Hextorm, Feb 11, 2022.
  1. Feb 11, 2022 at 2:32 PM
    Hextorm
    Hextorm [OP] New Member
    Blake
    White 2022 Tundra TRD Sport CrewMax
    Like many of you, I was also experiencing my driver side speaker having a very noticeable rattle during bass heavy songs. This is the fix! There is a loose, thin piece of felt-like fabric at bottom of the slit directly behind the window switches. Simply removing this piece has fixed the problem for me. I have no idea why this works but I saw it posted somewhere else, and sure enough my speaker rattle is now gone after testing it with the most bass heavy music I could find.
    wayoflife, Rwaters, MTRock and 2 others like this.
  2. Feb 11, 2022 at 4:59 PM
    xc_tc
    xc_tc New Member
    OH the door handle
  3. Feb 12, 2022 at 7:11 AM
    cdq85
    cdq85 New Member
    Corey
    Greensburg,PA
    2022 TRD Pro Tundra
    I just noticed a slight rattle last night (only during heavy bass). I took both inserts out this morning so I'll report back if I notice any difference.
  4. Feb 12, 2022 at 7:57 PM
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    You do realize that felt piece is what is used to keep the wastegate issues at bay, right?
    daverxa, Woocawachie, Coasty and 6 others like this.
  5. Feb 13, 2022 at 5:41 PM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    I’ll bite and give it a try
  6. Feb 13, 2022 at 8:23 PM
    RavingOx
    RavingOx Member
    WNC
    Let me know if this works. I noticed it today on my passengers side door. I didn’t want to reach over and look for felt as I was driving responsibly.
    Rwaters[QUOTED] likes this.
  7. Feb 14, 2022 at 11:42 AM
    Rwaters
    Rwaters New Member
    It did not work on mine. My rattle is coming from behind the little pocket under the handle
  8. Feb 14, 2022 at 11:47 AM
    Troyboy84
    Troyboy84 New Member
    BC Canada
    2022 SR5 TRD Offroad
    I’m dealing with what sounds to be the same rattle. I’ll be taking it into the dealership this week or next, between that and the rattle from the rear sliding window when it’s down, I can’t drive without the music on.
  9. Feb 14, 2022 at 12:43 PM
    Rwaters
    Rwaters New Member
    Is that why that rattle is in the back!?!? I figured it was a the seat trap
  10. Feb 14, 2022 at 3:48 PM
    Troyboy84
    BC Canada
    My rear window only rattles when it’s opened and all the way down. I love having it open but the rattle is unacceptable.
  11. Feb 23, 2023 at 7:29 AM
    Watszach
    Watszach New Member
    I had the same speaker rattle in my passenger door when playing heavy bass songs. I took it to the dealer and they attempted to isolate the door panel and was told “it is what it is”. I opened a case with Toyota Customer service and the truck ended up going back to the dealership. The dealership did a technical call with Toyota and they replaced the door panel as well as installed a noise kit which seems to have fixed my issue.
    Troyboy84 likes this.
  12. Apr 3, 2023 at 10:50 AM
    timjjang
    timjjang New Member
    2022 trd pro
    Hey, super weird. Both my passenger and driver are severely rattling. Took it to toyota multiple times where the techs “confirmed it”. They tried several fixes and claimed that they even called technical toyota but their response was that it was “normal” so the dealer pretty much said im out of luck……so now im sitting here not even able to enjoy the sound system.
    any suggestions?
  13. Apr 3, 2023 at 10:55 AM
    Breathing Borla
    AZ
    super cheap method, slap a in line bass cap on the two front door speakers
    better method, take it to aftermarket stereo place and get them to sound deaden the door and take out the rattles with the stock system.
    best method, aftermarket system that puts the bass in a real sub where it should be
  14. Apr 3, 2023 at 2:27 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    100% Stock
    Wrong. Most well put together sound systems will use 6.5" drivers in the doors for mid bass. 10" or bigger subs aren't that good playing mid bass and are more efficient with lower frequencies. You cant/shouldn't keep mid bass out of the doors if you want a well rounded system. What you could do with a DSP is turn down specific stages to not be as loud (Gain) or better time align them or set more aggressive crossover (1st-4th order filters). But by no means should you solely rely on a "real sub" for bass. Youd be surprised how well Toyota/Lexus performs in SQ competitions...there are guys running stock Lexus/Mark Levinson processors and winning competitions.
    Black widow TRD likes this.
  15. Apr 3, 2023 at 4:11 PM
    Breathing Borla
    AZ
    no shit , lol. My point is your first sentence, “ most well put together systems”
    the stock setup isn’t one.
    I know how a real system should be, I have one now. I’m not saying take all the bass out of the doors , of course mid drivers should have some, but the way jbl has this tuned , it’s too heavy and needs to roll off higher if your sticking totally with what they have. They push the mid drivers harder and lower than they do the sub in these pos systems .
    anyway , we ultimately agree, like I said , the best way to do it is with aftermarket stuff, like I have now and like you mentioned .
    but for some one who doesn’t particularly care for the best sound and just wants the doors not to rattle like crazy when they listen , and also doesn’t want to spend any money at all really , like I said super cheap bass caps would do it most likely .
    Anyways, my truck is on the way now and off we go, stock isn’t going to cut it for me
  16. Apr 4, 2023 at 5:25 AM
    Watszach
    Watszach New Member
    Did you try calling the Toyota 1-800 number and opening a claim? They were very helpful when my dealer was giving me the run around with this issue. 1-800-331-4331
  17. Apr 4, 2023 at 5:41 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    My fix was a loose wire harness on the inside of the door (between the inner and outer skin). I just had to snap the two clips into the appropriate holes, and rattle was gone. I would suggest replacing the clips on the door panel before snapping it back on the door. You don’t want to create a new rattle lol.
  18. Jul 24, 2024 at 7:00 PM
    Paul632
    Paul632 New Member
    Paul
    2024 Tundra Limited
    OEM 100,000 bumper to bumper
    I have the rattle in the driver and passenger doors. If I put my finger on the smooth plastic below the window control it stops. I have the JBL system. One thing I am finding is the system has a minimal adjustment. I’m mostly frustrated as the truck has almost 300 miles….
  19. Jul 24, 2024 at 7:30 PM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I fixed a rattle (and squeak when I pushed my knee against it) by popping off the panel that holds the window controls and adding a little felt tape where the plastic comes together. Can't see it when together, but much quieter now.
    mayan and Paul632 like this.
  20. Jul 24, 2024 at 7:43 PM
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    Exact same for me - rattle and squeak. Got any pics?
  21. Jul 26, 2024 at 2:35 PM
    sandiegosteve
    San Diego
    Have been traveling...
    Pop off the panel, and put on some tape. I used the felt wire loom stuff. Some clearly isn't sticking great, but when you pop it back on, any squeaky contact points seem to be solved.
  22. Sep 13, 2024 at 9:39 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I think I shared this before but I traced a rattle down to the pocket. I put a small piece of tesa tape and that did the job.
    sandiegosteve and Tundrastruck91 like this.
  23. Sep 13, 2024 at 10:04 AM
    Lamarre4995
    Lamarre4995 New Member
    Daniel
    Red 2024 Tundra Trd Sport
    Hi
    Mine have the same rattle in the driver doors when the sound is hight. But I have one small rattle when my back window is close, this one behind back seat it’s only when it’s hot outside the dealer try to put some silicone in track but it not stop do you have an idea or somebody found this problem. If I just open the window punch button the rattle stop
