2021 Trail model CC largest stock tire size
Discussion in '2.5 Gen Tundras (2014-2021)' started by Trail21, Aug 24, 2024.
  1. Aug 24, 2024 at 11:02 AM
    Trail21
    Trail21 [OP] New Member
    2021 Crew Cab 4x4 Trail Model
    Have not found an answer to this specific model bc I can’t tell if mine is TRD or not. Some paperwork says it is and some doesn’t mention it.
    Stock black wheels and 275 65 R18 tires.
    I want to go with 275 70 R18 10 ply mud tires: same width but a good bit taller. Will they fit with no modifications or do I need to drop back to 285 65 R18: wider and only a little taller.
    Truck is 100% stock.
    thanks!
  2. Aug 24, 2024 at 11:08 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Being your truck is 100% stock, search the threads on stock truck size sizes.
    Being a Trail Model wouldn't make any difference.
    The only difference in the TRD offroad is the shocks, not anything else in the suspension like height or tire clearance...
    2021 Toyota Tundra Revs Up Big-Pickup Fun with New Trail and Nightshade Special Editions - Toyota USA Newsroom
  3. Aug 24, 2024 at 11:20 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I bought my truck used (stock suspension) with 275 70 R18 KO2's no issues. 20240811_102339.jpg
  4. Aug 26, 2024 at 9:15 AM
    Trail21
    Looks like I’m go to order some 275 70 18 mud tires and just hope for the best. Seems like most can squeeze them on a stock truck.
  5. Aug 27, 2024 at 4:36 PM
    d33pt
    d33pt New Member
    I am running 265/70-18 on stock suspension and seems like there is plenty of room. Should've gone one size bigger.
  6. Aug 27, 2024 at 5:27 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations
    Your answer should be in the beginning of this thread.
  7. Sep 12, 2024 at 7:51 PM
    Trail21
    Well I bought the 275 70-18 and they fit perfectly. No rubbing and the truck seems like this size should have been sta dare from the factory. Handles and drives much better.
