2nd gen trailer brake controller
Discussion in '2nd Gen Tundras (2007-2013)' started by Markass, Sep 10, 2024.
  1. Sep 10, 2024 at 6:02 PM
    Markass
    Markass [OP] New Member
    2012 tundra single cab 5.7 4x4
    Hi. I’ e got a 2012 single cab with bench seat. TRD. SR5
    It has + - gain on the shift controller next to the Tow/Haul mode button.
    The gain doesn’t seem to do anything. Has anyone figured out how this works?
    Thanks in advance.
  2. Sep 10, 2024 at 7:14 PM
    JRS
    JRS New Member
    2012 DCLB
    That's to manually set the max trans gear when in "S." Helpful when downshifting while towing.
  3. Sep 10, 2024 at 8:35 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    When you pull the shifter down and in past drive check the gear indicator - it should read 4.
    Not D. That button allows manual shifting of gears at that point. It helps when in Tow/Haul mode
    but lots of guys just shift manual all the time. It’s nice downhill in construction to save brakes!
    yer dash is filthy, clean that up! LOL.
    grave likes this.
  4. Sep 10, 2024 at 8:39 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That's how you shift.
    If you have a brake controller (unlikely it sounds like) it would be just right of your right knee, if you don't have it then there will be a little cubby spot.
