New Guy with LED bulb question..
Discussion in 'Electrical' started by Viclava, Sep 10, 2024.
  1. Sep 10, 2024 at 3:02 PM
    Viclava
    Viclava [OP] New Member
    Scott
    Central Washington
    19 TRD Pro
    Air freshener
    I just bought a 19 TRD Pro, and want to swap out brake, front/rear turn signals with LED bulbs. Do I need can-bus or load resistors in order for them to work and not throw codes on the Tundra? Thanks for any assistance.
    cheers,
    scott
  2. Sep 10, 2024 at 4:52 PM
    Depending on your budget, I would look at the taillight conversion known as Hottails from @memario1214. It makes all 4 positions running lights as well as brake lights. It also utilizes a switchback in the reverse bulb for the turn signals. For the front, look at the V6 Triton from Vleds.
  3. Sep 10, 2024 at 5:29 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Vleds.
    No canbus
    You will need a set of resistors. I’m running Led eveything, and only needed resistors in the rear blinkers to keep everything happy.
  4. Sep 10, 2024 at 5:40 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I used Sylvania Zevo turns and ended up putting resistors in both driver & passenger side, but never had an issue after that.
    VLEDs probably won't have that issue.
  5. Sep 10, 2024 at 7:50 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Viclava[OP] likes this.
