Performance issues...
Discussion in '1st Gen Tundras (2000-2006)' started by Jack McCarthy, Jan 5, 2022.
  1. Jan 5, 2022 at 9:05 AM
    Jack McCarthy [OP] It’s always the fuel filter
    With my seat belt buckle. :p
    Anyone have a fix to get the button to pop back out or do I need to order a new buckle? (driver's side)
    It still works and has no fault light under proper use.
    Also, I'm not sure if the part number is 73240 or not. Diagrams on parts.toyota.com are a little confusing.
    FrenchToasty, FirstGenVol and bmf4069 like this.
  2. Jan 5, 2022 at 9:07 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I'd try cleaning all the crumbs between the red and gray parts, maybe spray some silicone lube in there to help...then replace if it still doesn't work...Luck.
    CodyP, des2mtn and Jack McCarthy[OP] like this.
  3. Jan 5, 2022 at 9:08 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    please clarify. the release button is meant to be depressed when the buckle is not in use. is that what you mean? or is the button not popping out when you plug in the buckle?
  4. Jan 5, 2022 at 9:10 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Mine used to stick bad, pretty sure it was mostly because of sugary drinks getting spilled. I'd have to stick a knife in the buckle hole and manually pop it up so I could make my seat belt click.
    Eventually I sprayed some Simple Green in there, used a few q-tips, then sprayed lubricant and it's gotten a bit better.
  5. Jan 5, 2022 at 9:11 AM
    It shouldn't be depressed when not in use. It used to pop back out like it does on the passenger seat or when it was new.
  6. Jan 5, 2022 at 9:12 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    I soaked mine in hot water with dish soap, sprayed it out, and repeated the process for about 5 minutes. worked like new afterwards.
    Weagle and Jack McCarthy[OP] like this.
  7. Jan 5, 2022 at 9:13 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    I dont think thats correct. both of mine are depressed when not in use. I can send pictures later
  8. Jan 5, 2022 at 9:18 AM
    Passenger is the way it should be when not in use...I should know, I've owned this truck since new. If that's changed with a model that's a year or two older then I'm not aware of it.
    Weagle, FirstGenVol and des2mtn like this.
  9. Jan 5, 2022 at 9:22 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    Looks like you're right. I have a 03' with bucket seats so maybe different. I would try the hot water soak I mentioned. I had problems with one of mine and that fixed it.
  10. Jan 5, 2022 at 10:32 AM
    Twinning.
  11. Jan 5, 2022 at 7:55 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My driver side is the same way. When I put the seatbelt in it, it pops out and latches just fine so i hadn't put much time into it yet.
  12. Jan 5, 2022 at 8:00 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wonder if you can swap the muddle seat one to drivers seat.
    I had that happen once, there was a dime stuck in there.
  13. Jan 6, 2022 at 4:22 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Had it happen with a few vehicles. It's just all crudded up as others have mentioned.
    Jack McCarthy[OP] likes this.
  14. Jan 6, 2022 at 8:34 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Seat belts??? We don't need no stinking seat belts!!!
    Mine's the same way. It works fine as-is, so I haven't done anything about it. If I was to get motivated, I'd remove it, blow it out with compressed air, then dunk it in soap and water, blow it out again, and finish with a spritz of WD40. But I don't anticipate getting motivated. :rofl:
    Jack McCarthy[OP] and bmf4069 like this.
  15. Sep 10, 2024 at 3:18 PM
    I'm re-posting this video in a few different threads to spread it around. I had the worst time trying to find it a minute ago.
    This video shows how to tear Toyota bucks apart and repair, swap internals, fixing broken circuit in the meantime. Props to @VR6T for finding it. Jump to roughly 4m30s to see where disassembly really begins. A lot of what comes before is referential fluff.
    Weagle, bfunke and KNABORES like this.
  16. Sep 10, 2024 at 4:28 PM
    Speaking of, he hasn’t been back since the ban
  17. Sep 10, 2024 at 4:32 PM
    Only one broken tab for my seat belt according to the video and what I see. Kind of like working with only one nut. Might be ugly but it does the job.
    shifty` and bmf4069 like this.
  18. Sep 10, 2024 at 5:57 PM
    bfunke
    bfunke Tundra Curmudgeon
    I was going to say someone posted a video on this but Shifty beat me to the link.
