how to visually check TB for jumped time 2006 4.7
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Sep 9, 2024.
  1. Sep 9, 2024 at 5:33 AM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I'm trying to determine if my truck jumped time without draining coolant and breaking it down as you would to change the timing belt. I've got the two top timing belt covers loose where I can see the cam timing marks
    if you match up the cam timing marks then where should the crank / dampener be on the timing marks located on the lower TB cover?
    0? TDC?
    EDIT: for future reference in case anyone runs across this And has the same question. These are the images from what @shifty` linked below which answered my questions:
    hammeron likes this.
  2. Sep 9, 2024 at 5:39 AM
    Weagle[OP] likes this.
  3. Sep 9, 2024 at 5:40 AM
    Weagle
    Prattville, AL
    Perfect, thanks. I guess I search for the wrong terms because I could never find anything like that.
  4. Sep 9, 2024 at 6:29 AM
    Weagle
    Prattville, AL
    EDIT: this is not an issue for now. I got the serpentine belt off. Looks like I will have to tear down at least part of the front end and take that tensioner pulley off to address this issue. But now I'm moving forward to check the timing
    Orig:
    Cant get serpentine belt off. Trying to turn the tensioner counter clockwise, but the nut/bolt is just spinning
  5. Sep 9, 2024 at 6:37 AM
    Clockwise. Serp belt tensioner is reverse-thread, IIRC, so CCW rotation should be tightening the fastener. are you sure that thing was installed fully, or did you just not tighten it? Maybe this is the source of your problem? (1m30s if it doesn't autoplay in that spot)
  6. Sep 9, 2024 at 6:46 AM
    Weagle
    Prattville, AL
    Yes I thought it was reverse thread and he shows that in the video.
    However, I'm turning it counterclockwise in order to remove the belt, but it just keeps spinning. If it was loose, that should tighten it. But it just keeps turning.
  7. Sep 9, 2024 at 6:59 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    sounds stripped or wrong bolt?
    Weagle[QUOTED][OP] likes this.
  8. Sep 9, 2024 at 7:08 AM
    Weagle
    Prattville, AL
    shouldn't be. Brand new and it comes already mounted
  9. Sep 9, 2024 at 7:14 AM
    FishNinja
    Lee
    06DC2wd
    oh I wait. I thought you were trying to remove the tensioner.
    Ignore me
  10. Sep 9, 2024 at 7:40 AM
    That's bizarre. I can't imagine they changed the model? I mean, I know some changes happen over the years, like changing pulley diameter and position (as a result of changing the diameter), but I've never seen any manufacturer change the fundamental function of one.
    I wonder if you just found your issue? Maybe the THUMP you felt was the pulley freezing up and the fastener snapping? And now it's just spinning in place?
  11. Sep 9, 2024 at 11:15 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    There are indeed two tensioner assy's for the 2UZ. The older one has a larger idler wheel (~4" as a recall) and the newer design has a smaller idler wheel. I learned this a few years ago when I was try to replace mine, and I kept getting the smaller one (I needed the larger one). I think the change happened midyear 2004, which is why I was having difficulty with the right part.
  12. Sep 9, 2024 at 12:34 PM
    Right, but with the newer style, smaller diameter (2.5" IIRC?) wheel not pivot CCW?
  13. Sep 9, 2024 at 12:47 PM
    w666
    Maryland
    It should still pivot the same way to release tension to remove the belt, but I don't own that one so I've never seen it, so I can't say for sure. The "Belt Noise" TSB (attached) is where the change originated.
    Weagle[OP] and shifty`[QUOTED] like this.
  14. Sep 9, 2024 at 1:05 PM
    Weagle
    Prattville, AL
    EDIT: this is not an issue for now. I got the serpentine belt off. Looks like I will have to tear down at least part of the front end and take that tensioner pulley off to address this issue. But for now I'm moving forward to check the timing
    I tried to get underneath last night and take the serpentine belt off. It was easier to get to that tensioner pulley from underneath. I finally decided to wait because I didn't have my big light with me. It was not bright enough outside.
    i'm thinking I might have gotten my directions mixed up from underneath and turned it the wrong way (clockwise) last night. So maybe it's not a bolt but some form of nut and bolt and that is why it is just spinning? Feels pretty smooth and solid. I don't think it's been stripped.
    shifty` likes this.
  15. Sep 9, 2024 at 4:17 PM
    Weagle
    Prattville, AL
    I cautiously report what appears to be great news. It does not appear to have jumped time and thereby bricking the engine.
    Please see @shifty` s link above or my post above with the pics of the correct alignment for the Crankshaft relative to the cam timing marks
    Ignore the timing alignment marks on the belt. It has already been running and is purely coincidental that they are in these pics
    The crankshaft mark is at an awkward angle and difficult to see because I didn't remove the fan, fan shroud, radiator etc. it's a little easier to tell in person that it appears to be on the mark
    Driver side cam timing mark:
    Passenger side cam timing mark:
    IMG_7848.jpg A
    A little concerned about how far the timing belt shifted forward on passenger side, but it appears to be within the ridge on the pulley (not pictured)
  16. Sep 9, 2024 at 7:26 PM
    Weagle
    Prattville, AL
    but that wouldn't explain why it suddenly would not run, even though the starter was turning the engine over normally
  17. Sep 11, 2024 at 10:23 AM
    Weagle
    Prattville, AL
    Apparently it was stripped. I bought the tensioner and the pulley in a kit and it was already mounted to the tensioner so it is definitely the right bolt
    pretty odd for it to strip that quickly
    need to find the right brand to replace (edit: Dayco is what came with the Aisin kit and in stock locally)
  18. Sep 11, 2024 at 10:27 AM
    FishNinja
    Lee
    06DC2wd
    what the fuck.
  19. Sep 11, 2024 at 5:26 PM
    fishordie
    fishordie New Member
    Earl
    East Texas Piney Woods
    2002 SR5 AC 2WD 210K Grocery Getter
    Middle of Timing Belt - Possibly Cam seals
    ha..i was thinking the same thing. Im up til 1 oclock last night researching and that never came up. Maybe I should get off of AOL.
