Blinker socket melted
Discussion in '2nd Gen Tundras (2007-2013)' started by Bd9607, Sep 7, 2024.
  1. Sep 7, 2024 at 4:39 PM
    Bd9607
    Bd9607 [OP] New Member
    2008 Tundra 4x Limited
    Bought our 2008 Tundra used and noticed driver front blinker went out. Replacing the bulb to find the socket melted along with housing around it. While the housing might be aftermarket (tinted cover) the blinker bulb connector and wiring looks factory. Question is do the blinkers double as DRL when not in use? They are/were always on. Replacing everything of course just want to correct it so it doesn’t happen again. Any suggestions besides OEM on headlight housings?
  2. Sep 7, 2024 at 5:15 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    They double as your DRL. And I believe the bulbs have a higher output due to this. Previous tundra was a 2012 and when I had to change one the socket looked almost scorched
  3. Sep 7, 2024 at 5:24 PM
    Bd9607
    Must be the case. Both sides suffered the same fate. Hopefully the new housing I ordered is a little better suited.
  4. Sep 7, 2024 at 5:32 PM
    It's common that those bulb sockets have burn marks on them due to the heat of halogen bulbs. If there is melted plastic, there is a good chance that the previous owner used higher wattage bulbs.
  5. Sep 7, 2024 at 6:19 PM
    texmln
    texmln New Member
    Mine were always burned or melted in my 2008. They're only like $5 on Amazon so I replaced them along with bulbs every time.
  6. Sep 8, 2024 at 7:38 PM
    Dr_Al
    Dr_Al New Member
    Al
    I replaced the bulbs with LEDs after the local garage replaced the clear bulbs with higher wattage amber ones. I did replace the sockets.
  7. Sep 8, 2024 at 8:24 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    That's what happens when you don't change the blinker fluid! :D
    KNABORES likes this.
  8. Sep 8, 2024 at 11:43 PM
    This^^^^^. It doubles as a coolant.
