Metal in oil filter question
Discussion in '3rd Gen Tundras (2022+)' started by Dpoll995, Aug 4, 2024.
  1. Aug 4, 2024 at 12:37 PM
    Dpoll995
    Dpoll995 [OP] New Member
    Houston TX
    2024 Tundra Limited
    So how much is too much metal in the oil filter? I just cut open the filter from my 5k oil change and found a few metal specs in there. I have never examined a filter so I’m not even sure if this is normal.
  2. Aug 4, 2024 at 1:21 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    First change? Totally normal for every engine after break in. You’ll find almost nothing at 10K and should be nothing ever after that. Many here have shown much more significant “glitter” and small fleck shavings than what you have. Specially in the bottom of their oil drain pans. Some where even on their 2nd and 3rd oil changes.
  3. Aug 4, 2024 at 1:24 PM
    Retired...finally
    Yep. Looks like a good one to me. If you still have it, rub a clean magnet over the pleats. Betting that comes out pretty clean.
  4. Aug 4, 2024 at 1:36 PM
    Tb2
    Tb2 New Member
    James
    Send your oil to be analyzed , that way u will know if it’s normal amount or not , otherwise your guessing
  5. Aug 4, 2024 at 1:49 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Is that's a paper based filter? What brand is it?
  6. Aug 4, 2024 at 2:17 PM
    Dpoll995
    Houston TX
    2024 Tundra Limited
    This was my 2nd oil change. I changed it at 1k miles. I sent the sample at 1k to Blackstone. It was normal. I also sent a sample from this change too, I messed up and drained it forgot to take the ssmaple. I ended up using the oil that drained out of the filter. The filter I cut open is a Toyota filter.
  7. Aug 4, 2024 at 2:33 PM
    Tb2
    Tb2 New Member
    James
    Oil out of filter may skew the results negatively
  8. Aug 4, 2024 at 2:35 PM
    Dpoll995
    Houston TX
    2024 Tundra Limited
    Yea I realize that but it was use that oil or nothing. I made a note in the comments on the order form. Hopefully they can do some sort of accounting for that.
  9. Aug 4, 2024 at 5:24 PM
    Mr Badwrench
    Mr Badwrench New Member
    That's pretty clean!
  10. Aug 4, 2024 at 6:32 PM
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    At my recent 5K: I had 2 "significant" sized specks similar to yours, but considerably more micro-glitter.
    I'm waiting on Blackstone results also. Also did my 1st at 1K but didn't do analysis on that one.
    Not worried about mine and I absolutely wouldn't worry about yours.
  11. Aug 4, 2024 at 6:48 PM
    PNW Tundra Mike
    Back in So Cal
    I'll be really interested to see a test from a filter. I'd expect higher counts on aluminum and trace metals. Please share when you get it on the Official Oil Analysis Thread noting it was sampled from the filter. Thanks - OFFICIAL: Oil Analysis Report Thread ONLY
  12. Aug 4, 2024 at 6:49 PM
    Dpoll995
    Houston TX
    2024 Tundra Limited
    Yep will do. I already posted my 1k results in there.
  13. Aug 26, 2024 at 2:14 PM
    Dpoll995
    Houston TX
    2024 Tundra Limited
    FYI here is my report
  14. Aug 26, 2024 at 3:04 PM
    BlackNBlu
    Rich
    MN
    Your 5K #'s are VERY close to mine, and I had a fair amount more micro-glitter showing in the filter pleats.
  15. Aug 26, 2024 at 4:46 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    30k and still pulling flakes this size
  16. Aug 26, 2024 at 4:56 PM
    Dpoll995
    Houston TX
    2024 Tundra Limited
    What mileage interval are you using?
  17. Aug 26, 2024 at 5:10 PM
    eddiefromcali
    Eddie
    100% Stock
    5k
  18. Sep 8, 2024 at 10:41 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    I just did my first oil change at 3750 miles. 4/24 build date.
    WTF is this!?
    I don’t think it’s metallic. Then, did a baby chipmunk shit in there(blue circle)?
    Zoom you can see a very little and very fine ‘forbidden glitter’(yellow circle). So if the chipmunk shit and gritty stuff is somehow normal/expected from manufacturering the glitter isn’t bad.
    A filter opener will be here tomorrow and I took a sample. I’ll report back on both of those.
  19. Sep 8, 2024 at 1:06 PM
    Lee.M
    Lee.M New Member
    TN
    24tundra limited 4x4
    Level/35s
    Had the same stuff in my 10/23 build 2024 model. You might get two or three oil changes with that silica or silicon based goo. I had metal flakes and bits and that black stuff.I did a early oil change last week the 4th one less trash but a few flakes and bits in my oil filter at 7800 miles. The first time I had anything in my filter was at 7800 miles go figure.
    MaineTundy likes this.
  20. Sep 8, 2024 at 1:42 PM
    MaineTundy
    The opener was in the mailbox so surgery ensued.
    It looks really good, I can see a few super fine specs. First pic is the inside of filter. Second pics is outside of filter. Last pic is from the oil that was in the filter.
    Maple Syrup anyone? (Don’t tell wife I used her jar)
  21. Sep 8, 2024 at 2:02 PM
    eddiefromcali
    Eddie
    100% Stock
    Probably assembly lube. Most first changes result is high moly ppm
