RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Sep 4, 2024 at 5:29 PM
    #1111
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Oh no - I paid for the shirt…
    Something something drug dealer on speed dial something something…
  2. Sep 4, 2024 at 5:41 PM
    #1112
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Oh I thought you bought all your stuff post-shirt giveaway offer
  3. Sep 6, 2024 at 10:42 AM
    #1113
    RainMan_PNW
    Casey
    Clark County, WA
  4. Sep 6, 2024 at 4:55 PM
    #1114
    RainMan_PNW
    Casey
    Clark County, WA
  5. Sep 7, 2024 at 1:35 PM
    #1115
    RainMan_PNW
    Casey
    Clark County, WA
    This summer while navigating about 40 miles of old FS roads in MT and ID, I lost one of the shackles I had on the front bumper - there was apparently enough vibration to cause the standard pin to back out and that's the end of it.
    So I decided to replace them with something that should be a bit more "vibration proof":
    First, I grabbed a couple of Crosby 3/4" S-2130 bolt type bow shackles (Crosby part number 1019524). These ones are all red, and they use a cotter pin to retain the nut.
    Then I picked up some 3/16" linch pins to use in place of the cotter pins.
    So I replaced the two on the front bumper and the one on the Agency 6 rear hitch mount, and then put the two screw-pin shackles in the tool box under the rear seat.
  6. Sep 7, 2024 at 2:11 PM
    #1116
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Planning anything different for mud flaps or flares with the added poke when using the spacers?
  7. Sep 7, 2024 at 2:18 PM
    #1117
    RainMan_PNW
    Casey
    Clark County, WA
    not currently
    Dsptundra[QUOTED] likes this.
  8. Sep 7, 2024 at 6:16 PM
    #1118
    SAGE63
    San Diego County
    Hey Casey,
    Figured I would ask you... Do you know how and where I would tap into the rear camera wiring if I am going to replace and relocate my rear camera to my bed rack as my spare tire swingout blocks the camera.
    Thanks in Advance
    Sid
    bulldog93 and ToyoMafia like this.
  9. Sep 7, 2024 at 7:22 PM
    #1119
    RainMan_PNW
    Casey
    Clark County, WA
    Sure thing, and actually relatively easy.
    Under the truck just before the tailgate is a junction connector just for the camera. It’s clustered up there attached to the frame with the one that goes to the rear bumper. The tailgate camera harness from that connector then passes through a rectangular “grommet” to the rear side of the bed and up into the bottom of the tailgate - it’s set up that way so that it can be disconnected if you have to remove the tailgate ever.
    SO, if you are looking to reuse the factory camera and just relocate it, you could disconnect that connector, fish the harness and camera out of the tailgate, then cut and extend the wires in the factory harness and route it from the connector junction up through the rear brakelight area and out the stake pocket to the bed rack…
    Tripleconpanna, bulldog93 and Mater like this.
  10. Sep 7, 2024 at 7:36 PM
    #1120
    SAGE63
    San Diego County
    Thanks Casey,
    Yeah I am going to get an aditional camera to run up to the rack. That way if needed just disconnect and connect which ever cam I want to use.
    Sid
  11. Sep 7, 2024 at 7:43 PM
    #1121
    RainMan_PNW
    Casey
    Clark County, WA
    Then I can dig up the details you need for a new connector and pins to matter up with the existing. Know that the factory camera is a different voltage than a lot of aftermarket ones…I don’t recall exact details but you’ll want to make sure you get one that works on the factory circuitry (basically an oem replacement)
  12. Sep 7, 2024 at 7:46 PM
    #1122
    SAGE63
    San Diego County
    Great point and thanks
  13. Sep 8, 2024 at 5:30 AM
    #1123
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Thank ya man. This is going to come in handy.
  14. Sep 25, 2024 at 11:50 AM
    #1124
    RainMan_PNW
    Casey
    Clark County, WA
    Couple more things showed up from Hotshot…
  15. Sep 25, 2024 at 11:53 AM
    #1125
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I feel like I may have nailed the color :cool:. Now that I see it again I’ve decided!
  16. Sep 25, 2024 at 12:02 PM
    #1126
    RobertD
    Robert
    DFW, Texas
    :hearteyes:
  17. Sep 25, 2024 at 12:18 PM
    #1127
    RainMan_PNW
    Casey
    Clark County, WA
    Yes
    For sure!
    TaquitoBandito likes this.
  18. Sep 25, 2024 at 10:25 PM
    #1128
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Careful, don’t want you to hurt yourself while patting yourself on the back so hard… :rofl:
  19. Sep 25, 2024 at 10:25 PM
    #1129
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Wanna go fast?
  20. Sep 25, 2024 at 10:48 PM
    #1130
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I don’t know how far you will get with this new stuff before Saturday, but I’m definitely looking forward to seeing your truck!
    TaquitoBandito and TRDFerguson like this.
  21. Sep 26, 2024 at 5:34 AM
    #1131
    RainMan_PNW
    Casey
    Clark County, WA
    Don’t think I’m going to take it to Jason level, but hoping to do a little…
  22. Sep 26, 2024 at 5:36 AM
    #1132
    RainMan_PNW
    Casey
    Clark County, WA
    Not going to get anywhere with this install this week.
    UPS still has one rear shock “in transit” even though all of them shipped together. And I’m waiting on a couple other bus and pieces to do while I have it all tore apart
  23. Sep 26, 2024 at 7:13 AM
    #1133
    memario1214
    Colton
    Missoula, MT
    I was channeling you when I wrote it! I learned it from you my Sensei
  24. Sep 26, 2024 at 7:39 AM
    #1134
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    I don't know why I thought of this scene from The Jerk, probably because I hated how much crap the wheels/tires I put on my old Tundra threw shit up the side of the truck.
    Are you doing flares on your truck?
    French Avocado likes this.
  25. Sep 26, 2024 at 8:14 AM
    #1135
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  26. Sep 26, 2024 at 8:57 PM
    #1136
    RainMan_PNW
    Casey
    Clark County, WA
    Currently not planning flares.
    These are only an inch, and I’m on the fence between sticking with 295’s or going to 285’s for tires later this fall. I’m also going to see how everything fits/looks without the spacers first.
    And, in the end, I’m not against a small flare (not a fan of the big pocket flare look) if necessary…but I’m also not the most gentle on my paint either.
    FireFinder44[QUOTED] likes this.
  27. Sep 27, 2024 at 9:59 AM
    #1137
    FireFinder44
    Albany, OR
    When I did the lift on my 2012 Tundra, I also got Method Grid wheels and Nitto Ridge Grapplers (which I got rid of for Cooper Discoverer tires) and ended up getting some Bushwhacker no-drill smooth flares. What a hassle that was. The front flares were fine, one per side, but the shipment had 2 left side flares, and I didn't check them when I took them to the body shop to get painted, then I had to get another set of rear flares, and have them painted. Still didn't prevent everything from spraying up the side of the truck because there were no mud flaps with 31" tires on a 20in wheel, and a front body mount chop.
    I'm not going to worry about the paint on the 2019 TRD Pro like I did for the Acura MDX Type S Advance I owned for a couple of years between Tundras.
    Really wish I had kept this.
  28. Oct 19, 2024 at 8:56 AM
    #1138
    RainMan_PNW
    Casey
    Clark County, WA
    Another piece came in…
  29. Oct 19, 2024 at 9:22 AM
    #1139
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    since when does hotshot @memario1214 brand brakelines?
    Mater and TRDFerguson like this.
  30. Oct 19, 2024 at 9:23 AM
    #1140
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Dude. Get the ‘net.
    I think he sources the same ones as SDHQ. They’re on my short list.
    Mater likes this.
