Not yet but when the time comes
Discussion in '3rd Gen Tundras (2022+)' started by ARB1977, Sep 7, 2024.
  1. Sep 7, 2024 at 12:36 PM
    ARB1977
    ARB1977 [OP] New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Every vehicle I’ve owned. Every 30K I clean the throttle body. I typically don’t remove them. Are the throttle bodies hard to access on these engines? I haven’t explored around the engine bay yet to see. Thanks.
  2. Sep 7, 2024 at 3:45 PM
    TundraFl83
    TundraFl83 New Member
    Wut in the tarnation
    OHwendTrd likes this.
  3. Sep 7, 2024 at 4:00 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    He's probably the Toyota engineer who came up with 40K mile spark plug change interval on these engines too.
  4. Sep 7, 2024 at 5:59 PM
    TundraFl83
    Breathing Borla and Blufin like this.
  5. Sep 7, 2024 at 6:06 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You better put down your Chiltons manual
  6. Sep 7, 2024 at 6:46 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
  7. Sep 8, 2024 at 4:36 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Waste of time. But it's your time.
  8. Sep 8, 2024 at 6:38 AM
    ARB1977
    Anthony
    DFW
    I guess y’all never take out the maf sensor and clean those too. You be surprised how dirty throttle bodies get.
  9. Sep 8, 2024 at 11:28 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    I clean my throttle body on my Mustang and mass air every oil change. Does make it idle more smoothly.
    I’ve yet to explorer what cleaning the throttle body on the Tundra consists of. Good question.
    l do clean the maf also. It’s a good idea depending how hard you drive your truck to change plugs for optimal performance around 40k also, not a must. But for the nay sayers, you do you…
  10. Sep 8, 2024 at 11:59 AM
    Mr Badwrench
    Mr Badwrench New Member
    Are you using aftermarket filters like K&N or anything that takes spray-on filter oil? Those will gum up a throttle body real fast. If not, try using OEM spec air filters or something with a little more filter media.
    Tundrastruck91 likes this.
  11. Sep 8, 2024 at 2:13 PM
    ARB1977
    Anthony
    DFW
    I do me every 30K. Plugs when they say.
  12. Sep 8, 2024 at 2:14 PM
    ARB1977
    Anthony
    DFW
    I use AFE dry flow.
  13. Sep 8, 2024 at 9:47 PM
    Black widow TRD
    Manuel
    Yeah I’ve got a k&n drop in. I don’t mind cleaning them. Fairly accessible. Tundra is more of a pain.
