2021 Lunar Rock
Discussion in '2.5 Gen Builds (2014-2021)' started by Downytide, Apr 6, 2021.
  1. Jun 10, 2024 at 12:23 PM
    #91
    Downytide
    Downytide [OP] New Member
    GTA
    Lunar Rock that whines
    For those ever wonder:
    The front is sitting on Coachbuilder 1" shim, middle position on the coilovers, I don't want to go any higher cause I personally feel this is as much angle as I'm comfortable with on factory cv.
    Rear has 35" spare with factory 18" steelie, and may be 100-200lbs worth of stuff in it.
  2. Jun 28, 2024 at 2:15 PM
    #92
    Downytide
    GTA
    Everything feels "broken in", I like the way it is for now, thinking about pulling the air bags and run with hydraulic bump, the deaver has been great on rough roads, towing etc, I've been towing without filling up the bags.
    And the little side project, the Winnebago now has 3x 320ah lithionics batteries, or about 11.5kwh capacities.
  3. Aug 28, 2024 at 7:38 AM
    #93
    Downytide
    GTA
    I'm very excited for the new exhaust in progress, currently from headers collectors to x pipe is 3" then shrink down to 2.5" for TRD exhaust, so now it's getting 3" all the way also make it equal length, WB O2 sensor bungs etc, it'll be similar to SPD exhaust in design but will use different mufflers, the goal here is no drone when towing.
    X-pipe:
  4. Aug 28, 2024 at 9:18 AM
    #94
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    I saw you had fox 2.5 dsc race series and now have the Bilsteins 8100 - how have you been liking them so far? Any regrets or wishes you went with a 3.0 shock like Kings or ADS? I am also from the north east and these fox's after 2 years just leave a lot to be desired for me.
  5. Sep 3, 2024 at 3:10 PM
    #95
    Downytide
    GTA
    I like them a lot, I'd recommend them to everyone.
    Kings corrode like crazy, I've seen them first hand, I've never ridden ADS so I can't comment, I think the biggest issue with shocks is on paper it's hard to describe how they feel. I have no regrets because doing things in stages keeps me busy and entertained, I enjoy the continous evolution more than just "bam, it's done" kinda thing.
    More progress on the exhaust:
    I'm very stoked and excited to hear the truck again.
  6. Sep 4, 2024 at 11:52 AM
    #96
    Downytide
    GTA
    It looks so beautiful I'm going to be hesitant to drive it in the winter.
  7. Sep 7, 2024 at 12:10 PM
    #97
    Downytide
    GTA
    Edit: the exhaust is done and I can't be happier, it sounds absolutely bonkers, while being somewhat quiet, no drone, no obnoxious loudness, at idle you can barely hear anything, at WOT is another story.
    The biggest test will be towing.
  8. Oct 15, 2024 at 11:57 AM
    #98
    Downytide
    GTA
    I can't say enough good things about equal length exhausts and honeyseal.
    For the exhaust, I've consistently see 10% increase in mpg, even in towing, it is also absolutely hilarious as it will do pop and bang when off throttle at times, I cannot master it yet, it makes driving in manual mode insanely fun considering I'm piloting a house down the road.
    anything below 3k rpm it's pretty tame in all situations, above 3k rpm it's party time, so big shoutout to Mike @ GTcustom , if you are in Toronto area, check him out:
    https://www.instagram.com/mikegtcustom/?hl=en
    The truck got honeyseal treatment, Jake and Steve @ Honeyseal in Oakville blew me away, you can see photos here showing the before and after, the before is still with annual Krown treatment, to saw Krown has lost its edge would be an understatement, I also rinse the truck weekly in winter.
    Before:
    After dry-ice/acid spray
    after Honeyseal coating:
    That concludes about all I've got planned this year.
  9. Feb 11, 2025 at 10:46 AM
    #99
    Downytide
    GTA
    This truck is the most personified vehicle I've ever had, there are times she would literately tells me "no, that is good, no more"
    I had new injectors/fuel pump, pulley set up installed, during tuning, there was a set up that seemed to work the best, but we decided to push for further refinery, the truck didn't like it, it almost brick the ECU and I almost ******** a brick, thanks to Mr. Sniv on saving the day
    AFRs is good, she's humming along.
    I don't think I'll touch the engine for a while until it's time to have a fully built engine.
    One additional thing that got dialed in was SDHQ traction bars, it made a very big difference in how the truck rides in a positive way, on very rough surface it's much more dialed in, more settled, which makes sense, I was worry the front mount would hang lower than I'd like, but the powerstep housing sits at same level.
  10. Feb 17, 2025 at 3:31 PM
    #100
    Downytide
    GTA
    Nothing special, just a nice snow day.
  11. Mar 5, 2025 at 8:44 AM
    #101
    Downytide
    GTA
    Transfer flow 46 gallons is here, I gotta say the packaging was great, super fast shipping to Canada.
  12. Mar 5, 2025 at 9:38 AM
    #102
    enve46
    enve46 New Member
    Andrew
    Man what a build. This is nearing perfection and that exhaust work is some of the best Ive seen awhile.
  13. Mar 5, 2025 at 6:25 PM
    #103
    Khanhyeeast
    Khanhyeeast New Member
    Just went through every page, this was a quality build! glad your still going at it with the truck as well!
  14. Mar 6, 2025 at 8:41 AM
    #104
    Downytide
    GTA
    Next up is z-pipe, I've finally seen one in person and I dig it, with Sniv's help the truck is consistently hitting low 4s for 0-60mph, for a 7000lbs brick it's impressive.
    Eventually I'd like to re-do suspension one more time and get glass fenders, I've learned from past mistakes where I'd finish up a car then get bored quickly, this truck connects with me so I'm trying to break each phase down so I have something to do every year.
    I love how these things drive, if it's up to me I'd have multiple of 2nd gen.
    ZPhilip and enve46[QUOTED] like this.
  15. Mar 24, 2025 at 10:46 AM
    #105
    Downytide
    GTA
    so the 46 gallon tank did not fit, if you have a post 2016 and 38 gallon tank from stock, or TRD exhaust, it will not fit.
    If you have a crossmember that goes above the driveshaft, it fits, like this:
    If your cross member goes under the driveshaft, like mine, it will not fit.
    Oh well, part of this truck's important function is ability to tow a travel trailer, previously it towed "Razorcrest", a Winnebago Micro Minnie FLX, it has factory lithium system (not a good one), it's a 21ft x 7ft box, bought it during the Covid craze and very quickly I crash course on trailer wirings, but we still enjoyed every trip we've taken with the trailer, and I also quickly learn the difference of needs vs wants in a trailer, originally we wanted a smaller trailer so we can camp more in the wilderness, but quickly learned that we needed more interior space the way we camp.
    So this was Razorcrest.
    And the replacement, we'll name it The Voyager, it's a winnebago again but this is a larger model 2730RL, 27ft long box and 8ft wide, I wanted azdel sidings and this layout works for us , but this time the electrical system will be all victron vs xantrex (I do not recommend using Xantrex), almost everything is from Explorists minust the batteries, one benefit going from "faux-offraod" trailer suspension to leafs is how much smoother it tows compared to the smaller trailer.
  16. Jul 10, 2025 at 12:02 PM
    #106
    Downytide
    GTA
    The trailer project is done for the year, at 1160AH or around 14kwh of batteries, it's good, will be updating the solar throughout winter, the goal is to get solid 1kw of solar on the roof so I no longer require a small generator for top offs when using lots of juice.
    The upgrade in size is incredible, when weather was bad we can actually sit inside and wait out the weather.
    Truck wise, spent a lot of effort, here's a detail description on what I was trying to fix:
    So that took a lot of time in finding someone who was willing to remove the headers + carefully measure the length of o2 sensors in stock position, thankfully Fusion Motorsports Fabrication was willing to do it.
    Truck has been running great since, no drama, which is how I like it, it doesn't mean the mind sometimes wander off and thinking about how 1000hp is a need vs want.
    I did get a set of billet hooks that was matched to the sway bars from Teton workshop, it's as cliche as it gets, but I like it.
    kinda matches my shocker hitch too..................
  17. Aug 11, 2025 at 8:08 PM
    #107
    martiartisan
    martiartisan New Member
    North Texas
    2020 Tundra DC, 2006 Tundra Crew Cab
    Adv fiberglass, king suspension, cbi armor, RLD Cap
    Love the gauge mount. Is this 3D printed? How can I get one!
  18. Aug 12, 2025 at 5:51 AM
    #108
    Downytide
    GTA
    martiartisan[QUOTED] likes this.
  19. Aug 12, 2025 at 9:15 AM
    #109
    martiartisan
    North Texas
  20. Aug 12, 2025 at 9:29 AM
    #110
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Clean setup! What mufflers did you use? And any sound clips? Any drone under 3k?
  21. Aug 12, 2025 at 1:06 PM
    #111
    Downytide
    GTA
    Yes, love the bars, they really make the ride better, I haven't had any issue with them but then I'm not like some guys who jump their trucks.
    Borla Pro XS
    It boogeys
    https://youtube.com/shorts/WDxVUomIV6Y
    It's the most fun in the tunnel.
    https://youtube.com/shorts/8paAQGUhEW8
    During normal driving, it won't drone, but when towing and it's in 6th under 2000rpm it can be very annoying, so I usually keep it above 2000rpm when towing.
  22. Aug 16, 2025 at 5:02 PM
    #112
    Downytide
    GTA
    I love bed cap's functionality, but I'm not a fan of their look on gen 2.5 CM, they look goofy as hell to me. Soft topper is cool, but I wanted something that does bit of everything, thankfully the wife found something, it's called RazorTop.
    Now, this thing functionally is amazing, BUT, the installation is on par with the headers, it's frustrating.
    Popped:
    Retracted:
