TRD skid plate issue
Discussion in '3rd Gen Tundras (2022+)' started by Azrael_Cervale, Sep 6, 2024.
  1. Sep 6, 2024 at 9:04 AM
    Azrael_Cervale
    Azrael_Cervale [OP] New Member
    Caught a rock wrong on my drive yesterday and found out the hard way that the TRD skid plate will deflect up into the front drive axles if bent. Now i'm trying to find a way to bend it back. The only way i can think of is to remove it completely and try and flatten it out some. There's nothing safe to pry against while its installed.
    Yaboy likes this.
  2. Sep 6, 2024 at 10:25 AM
    Observer
    Observer New Member
    I would just take the skid plate off and pound it back in shape with a hammer or or sledge. They seem pretty stout. At least the skid plate did it's job.
    Tundrastruck91 and RobertD like this.
  3. Sep 6, 2024 at 1:49 PM
    Azrael_Cervale
    I've got to figure something out. I dont think it will damage the axle as its steel vs aluminum but i'm hoping to bend it somehow and get some space back between the two.
  4. Sep 6, 2024 at 1:56 PM
    HLR_NM
    HLR_NM New Member
    Harry
    The safest path is to remove it, repair it (with a BFH), replace it.
    Trying to pry it back into shape while still on the truck is a good way to start a new thread, “CV Axle Replacement”
    Lee.M and AZBoatHauler like this.
  5. Sep 6, 2024 at 1:58 PM
    Azrael_Cervale
    Yeah when I was looking to pry on it I didnt see anything that I could pry against that wasnt cast aluminum.
  6. Sep 6, 2024 at 1:59 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Block of wood and a big hammer like the other guy said.
    That must have been one hell of a rock in the driveway.
    Black widow TRD and AZBoatHauler like this.
  7. Sep 6, 2024 at 2:01 PM
    AZBoatHauler
    So.Arizona
    And some speed.
    Tundrastruck91 and Black@Blue19 like this.
  8. Sep 6, 2024 at 4:02 PM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Skid plate is very easy to remove. Just like at every oil change.
    Tundrastruck91 likes this.
  9. Sep 6, 2024 at 6:18 PM
    Azrael_Cervale
    Here's the normal side, the bent side and the after. I didnt have much luck with the hammer. The aluminum was a bit too springy. I ended up putting a jack on the back side of the dent and putting the trucks weight on it, still not enough to flaten it but it did help.
  10. Sep 6, 2024 at 6:23 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    If your local, I can stand on it for ya
  11. Sep 6, 2024 at 6:26 PM
    scarecrow87
    scarecrow87 New Member
    Shane
    Silver 2023 Tundra SR5 TRD
    Yikes! How thick is the TRD skid plate?
  12. Sep 6, 2024 at 6:48 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Now put it back before dad finds out.
    scarecrow87 likes this.
  13. Sep 7, 2024 at 10:01 AM
    Azrael_Cervale
    Looks like about 1/4 inch but its aluminum.
