Help I messed up my 11 tundra 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by Dbcreator11, Sep 6, 2024.
  1. Sep 6, 2024 at 5:38 PM
    Dbcreator11
    Dbcreator11 [OP] New Member
    2011 tundra
    Hi guys I have a 2011 tundra 5.7l that has 282k on the motor. The timming chains had the death rattler to the tensioners! And cam towers had major leakage. So I thought I could fix them. I took it all apart and I marked both cams and the chains and the links and changed out the tensioners and fixed the leaks. So I put it all back together and somehow I got the exhaust cam chain off a tooth because I got it all back together and it missed and throw a P0017 code bank b. So I took it all back apart reset all the chains with all the corsponding marks on the chains and put it all back together. It run for a bit and started missing again and died on me when driving once. But not cel lights. People on the tundra fb group saying I might had messed up the cylinder head. So today I did a compression test on that side of the motor they all held at 150psi ‍♂️ correct me if I'm wrong but if the valves got bent from it begin out of time the first time wouldn't the compression leak out the head and not hold at 150psi? Since I did the compression test today it starts up now runs smoth for about 30 sec then starts missing again and flash the cel light at me which it only started this since I didn't the compression test. I got new plugs but fixing to buy new coils to rule that out before I take it all apart again. Any suggestions u guys might have or something I might had missed? I triple check all my wires and everything is plugged back in.
    Tundrastruck91 likes this.
  2. Sep 6, 2024 at 8:24 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Did you accidentally swap the plug wires to the VVT oil control solenoids? There are two on top of each valve cover near the front of the engine, one each for the intake and exhaust cams. The wire connectors are exactly the same so they can get plugged in opposite of the way they’re supposed to.
    Pig Rig, hagrid, Mdl and 3 others like this.
  3. Sep 7, 2024 at 3:02 AM
    Retired...finally
    If you have that amount of compression you didn't bend a valve.
    huntertn, Mdl and hagrid like this.
  4. Sep 7, 2024 at 7:39 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Sounds like you are already above my head in the engine knowledge department.
  5. Sep 7, 2024 at 7:46 AM
    That seems like an engineering miss. I’m blaming the accounting dept. for that choice.
    FrenchToasty and Tbrandt[QUOTED] like this.
  6. Sep 7, 2024 at 9:55 AM
    Tbrandt
    Tristan
    Kansas City
    They’re different colors, but the same style connectors.
  7. Sep 7, 2024 at 10:49 AM
    Dbcreator11
    2011 tundra
    Yeah got the dang cam plugs crisscrossed. That was it :) it runs great now. Going to have to mark them better in the future save me alot of head aches
    MTRock, mtucker, Fobroader and 13 others like this.
  8. Sep 7, 2024 at 11:00 AM
    Tbrandt
    Tristan
    Kansas City
    That’s awesome! But man that sucks, sorry you had to tear into the engine twice for such a simple thing.
  9. Sep 7, 2024 at 1:07 PM
    Dbcreator11
    2011 tundra
    O No the 2nd time I tore back into it cause it was out of time. I had the plugs right the first time and 2nd time got it crossed. But luckily I didn't tear into it again and that's all it was.
  10. Sep 7, 2024 at 1:15 PM
    jaxadam
    jaxadam New Member
    So far this has been a very impressive thread and we are only 10 posts in.
  11. Sep 7, 2024 at 2:41 PM
    AZBoatHauler
    So.Arizona
    @Tbrandt delivered.
    :hattip:
  12. Sep 7, 2024 at 2:48 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Tbrandt and KNABORES like this.
  13. Sep 8, 2024 at 7:00 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    @Dbcreator11 What reference did you use to do this job? This seems like a HUGE job to DIY, impressive work!
  14. Sep 9, 2024 at 12:29 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Yep learned about these two plugs which are the same, after pulling the intake not once but twice after rodent damage within 2 weeks. If you aren't paying attention, its very easy to screw it up.
  15. Sep 24, 2024 at 9:40 PM
    Dbcreator11
    2011 tundra
    I followed a couple YT videos there's a Russian guy who dose timing chain replacement it's a pretty stright forward video to follow and there's a toyota tech video on how to set the timming that I used the video to reset my timming. Other then that everything else was just taken everything off which wasn't to hard
    blackdemon_tt and Rph74[QUOTED] like this.
  16. Sep 24, 2024 at 10:01 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    This forum is solid
    I appreciate Y'all
    Tbrandt likes this.
  17. Sep 26, 2024 at 3:57 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    Nicely done man!
