2008 Toyota Tundra V8 with check engine light on.
Discussion in 'General Tundra Discussion' started by YotaMan101, Sep 6, 2024.
  1. Sep 6, 2024 at 8:57 AM
    YotaMan101
    YotaMan101 [OP] New Member
    2008 Toyota Tundra V8 with check engine light.
    I have a 2008 Toyota Tundra V8 with 191k miles on it. Check engine light popped on the other day, had it read at a parts store. This is what it said on the paper they handed to me. Is this a big deal to get fixed? I’ve been told it’s not a huge deal? But it sure looks like a big deal to me. (not a car guy) Plz help!
  2. Sep 6, 2024 at 9:32 AM
    JC’sTundra
    JC’sTundra New Member
    JC
    ‘09 Sequoia SR5 Nautical Blue Metallic
    No mods (YET!)
    YotaMan101[OP] likes this.
  3. Sep 6, 2024 at 9:37 AM
    YotaMan101
    Is this a major issue to get fixed? I’ve heard conflicting reports on how serious it is. And okay thank you!
  4. Sep 6, 2024 at 9:40 AM
    Sometimes you can clean the pumps, sometimes you can simply replace the faulty component. You can repair it reasonably, or do the bypass kit.
  5. Sep 6, 2024 at 9:42 AM
    JC’sTundra
    JC
    No mods (YET!)
    Bear in mind, I’m no mechanic, just passing on what I’ve read over the last 3-4 years on this forum. It is major enough that it will run you $2k+ at the dealer. If you search around the forums you’ll find that the air injection system doesn’t do much after the first 30-60 seconds after startup. Hewitt Tech has a system to bypass the air flow injection system. If you’re not mechanically inclined (I’m not) you may have to find someone to install it, but at the end of the day it’ll still run you less than a whole new system.
  6. Sep 6, 2024 at 9:43 AM
    YotaMan101
    Would I ruin the engine if I kept driving it?
  7. Sep 6, 2024 at 9:49 AM
    JC’sTundra
    JC
    No mods (YET!)
    That I don’t know. My sequoia (used) came with the Hewitt bypass already installed so I didn’t have to mess with it. I do know that it’s a very popular solution on these forums.
  8. Sep 6, 2024 at 10:00 AM
    YotaMan101
    From what I gather, it mainly regulates emissions on cold starts? Where I live, we have no emissions test for registration, and not overly concerned about it if it don’t hurt the engine. Just annoying I can’t remove the engine light on the dash.
  9. Sep 6, 2024 at 10:02 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    It will not ruin your engine but the truck will run in limp mode when it sets the code. That is annoying.
    My 2008 did this very thing about two months ago. I just installed the bypass kit.
  10. Sep 6, 2024 at 10:06 AM
    YotaMan101
    What do you mean “limp mode” ? So far it seems to be driving fine and starting fine etc.
  11. Sep 6, 2024 at 2:12 PM
    huntertn
    huntertn New Member
    Tennessee
    Mine would be slow to accelerate when I was trying to go above about 45mph. Kinda like it was being held back. Felt like pulling a trailer. Once I cleared the codes and the check engine light was off, it drove fine.
    But let me circle back. Are you getting lights other than the check engine light? I had a P2440 (valve stuck open). In addition to the check engine light it would get a flashing 4Lo and VSC OFF.
  12. Sep 6, 2024 at 3:04 PM
    YotaMan101
    Mine says it’s stuck closed, and I’m only getting check engine light. So far I don’t notice a limp mode. I read if it’s stuck open it can cause limp. So no idea if it’s different if it’s stuck closed like mine. I just ordered a code reader so I can hopefully clear the code. A buddy of mine did it a few months ago when it popped up 1st
  13. Sep 6, 2024 at 3:53 PM
    huntertn
    huntertn New Member
    Tennessee
    If you don't have to do emissions testing and it doesn't go into limp I would be tempted to just drive it. I have a Veepeak Bluetooth plug in tool that I use with the Car Scanner app on my IPhone that I would use to reset the code. Most days, it would only act up in the morning. After I reset it, it would be good the rest of the day. I think mine was sticking more than stuck.
  14. Sep 6, 2024 at 5:01 PM
    YotaMan101
    Yeah, there is no emission testing where I live to renew registration. So I’m thinking I might just reset it (if it don’t go into limp mode) if it does…then idk what to do.. I only use the truck as a work truck. So I try not to drive it a ton.
