Diesel in Gas Tank
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyotaSubArctic, Sep 6, 2024.
  1. Sep 6, 2024 at 1:23 PM
    ToyotaSubArctic
    ToyotaSubArctic [OP] New Member
    2017 Toyota Tundra
    I just got a used 2017 tundra after my Ram 1500 Ecodiesel motor seized. My wife I guess wasn't aware that it wasn't diesel and when I was on a work trip she put diesel in it. Drove it a few hundred feet before it threw a check engine light and shut off.
    She was able to get it to a shop. They inspected everything, dropped the gas tank, drained it, flushed everything with gas. Now the truck is running like it was before. No codes, no odd noises etc. I guess we got lucky.
    Now my question is, should I preemptively replace anything? I was reading some stuff on forums that the fuel pump and spark plugs might need to be replaced. Do you guys agree with that? Is there anything else I should take a look at?
    Update: 1 week later and I got a P0420 code. I know the truck was good before this. Passed smogged 2 weeks ago. No previous history of any emissions issues. So I'm thinking the diesel gummed up something. I'm hoping to maybe try the CRC cat cleaner or seafoam and get rid of it. If not then I guess o2 sensors and worst case the driver side cat assembly.
  2. Sep 6, 2024 at 1:24 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    If it runs perfectly, why bother?
    Black@Blue19 and NatesNightMare like this.
  3. Sep 6, 2024 at 1:25 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Hail the 3UR, by the way ;)
    dondino, Black Wolf, blenton and 4 others like this.
  4. Sep 6, 2024 at 1:27 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would send it and not lose any sleep!
    Kung, JrJrOffroad and NatesNightMare like this.
  5. Sep 6, 2024 at 1:28 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    If this happened to me I'd take a peek at one plug for shits and grins and take it from there.
  6. Sep 6, 2024 at 1:31 PM
    How did she get the diesel nozzle into the gas filler neck? Thought it would be too big.
  7. Sep 6, 2024 at 1:32 PM
    ToyotaSubArctic
    2017 Toyota Tundra
    Yeah I guess that makes sense. I guess since I got it only a few weeks ago I just want to make sure it lasts as long as possible. But yeah these are great from everything Ive been reading. Especially coming from the terrible design of a 2016 Ecodiesel.
    Thanks guys!
  8. Sep 6, 2024 at 1:35 PM
    ToyotaSubArctic
    2017 Toyota Tundra
    Hahah this was my exact question. She said it was extremely difficult and she had to hold the pump lever the whole time. I was thinking maybe there's a reason that its not working as it normally would..
    Retired...finally likes this.
  9. Sep 6, 2024 at 1:54 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    When dedication does not pay off... :)
    AZBoatHauler likes this.
  10. Sep 6, 2024 at 1:59 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  11. Sep 6, 2024 at 2:04 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    But boobz!
    PRNDS, ScootARoot, Kung and 4 others like this.
  12. Sep 6, 2024 at 2:24 PM
    Echo5Golf
    Echo5Golf New Member
    Phil
    Tundra Hunter
    I’m sorry but this is hilariously similar to my life with my wife! I feel you brother!
    vtl likes this.
  13. Sep 10, 2024 at 10:37 AM
    Dowloader
    Dowloader New Member
    Now my question is, should I preemptively replace anything? I was reading some stuff on forums that the fuel pump and spark plugs might need to be replaced. Do you guys agree with that? Is there anything else I should take a look at?[/QUOTE]
    Replace the wife. :D
  14. Sep 10, 2024 at 10:39 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    For what? A new wife will again put diesel in it. Old one is trained.
  15. Sep 10, 2024 at 10:40 AM
    When I used to work this happened a lot. All guys...even worse.
  16. Sep 10, 2024 at 10:41 AM
    Dowloader
    You're right brother :D:D:D:D:D
  17. Sep 10, 2024 at 12:08 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    This happens at work often with our side by sides. We have a constant revolving door of both gas and diesel ones, depending on what the leasing company drops off.
    Tanks get drained and all is good.
    Don't worry about it.
  18. Sep 10, 2024 at 9:17 PM
    ToyotaSubArctic
    2017 Toyota Tundra
    So trucks been running good for about a week. Then yesterday it threw a code P0420. Any one have any recommendations from here? I'm hoping there's just some leftover diesel floating around that cause an o2 sensor to trip up but I cleared the code by disconnecting the battery for 15 or so min. Then the code came back after about 30miles of driving. I'm hoping the cat isn't actually damaged but I'd love recommendations on anything I could try before going to a mechanic.
  19. Sep 10, 2024 at 9:22 PM
    18" TRD Off Road Wheels
    The non high flow nozzles are the same size as a gasoline nozzle. The Tundra also has a large opening in the fuel neck.
  20. Sep 10, 2024 at 10:01 PM
    Or his truck just wants an edible with tossing that code. :D
  21. Sep 11, 2024 at 11:19 AM
    ToyotaSubArctic
    2017 Toyota Tundra
    No kidding. Funny code number for an emissions related fault.
  22. Sep 11, 2024 at 11:29 AM
    Chip_Tundra
    Chip_Tundra New Member
    Honestly, just change the plugs and be done with it
  23. Sep 11, 2024 at 1:30 PM
    ToyotaSubArctic
    2017 Toyota Tundra
    And just live with the P0420?
  24. Sep 11, 2024 at 3:48 PM
    Chip_Tundra
    My bad didn't see that your truck threw a code. Maybe change the O2 sensors and go from there.
  25. Sep 11, 2024 at 7:04 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    I have a friend who tinkered with running gas diesel mixes in his trucks for a while. He eventually found that the diesel was partially washing into his oil. Seems it was coating the cylinder walls rather than burning.
    Anyway, anytime someone needs to run out a partial fill of diesel in a gas tank, change the oil soon after. It may be thinned and over filled.
