  1. Sep 6, 2024 at 10:07 AM
  2. Sep 6, 2024 at 10:26 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I only had it cause they give you one when you open an Amazon credit card. :rofl:It was burning a hole in my screen so I had to use it.
  3. Sep 6, 2024 at 10:48 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    You got a part number on those? They were the bane of existence when I was a tech, I'd love to delete them...
  4. Sep 6, 2024 at 10:48 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ah ok then I think I got one at some point :rolleyes:
    Silver17[QUOTED] likes this.
  5. Sep 6, 2024 at 10:59 AM
    More like the wife got it lol :ballchain:
    BR73 and Silver17 like this.
  6. Sep 6, 2024 at 11:02 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Haha not a chance. We have separate accounts on everything :yes:
  7. Sep 6, 2024 at 11:05 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I’m due (overdue) for a rebuild on the TRD Pro shocks.
    Since it’s my daily driver, I can’t be down for the time it takes to send them in for rebuild, so I have to swap in something at least temporary for that time period that has the same amount of lift and clearance for my tires, etc. The price of a second set of TRD Pro’s is substantial, and there’s a few other tweaks I’ve been contemplating anyway so, in typical fashion I have decided to double down and overhaul all of it while I have it apart…
    Icon RXT leaf pack (currently planning option 1)
    8112’s up front, 8100’s in the back
    Icon billet UCAs
    CB tie rod kit
    CB front shims (to keep the 3” lift and keep the 8112’s “in the zone”)
    Keep the RAS
    Keep the 2” CB rear shackle (aiming at about 1” rake when empty)
    New brake pads and fluid change (hoping I don’t have to replace pistons, and still deciding what rotors)
    Upgrade to SS brake lines
    1” Bora wheel spacers for just a touch more width and UCA clearance (not letting go of the BBS wheels)
    ABS sensor guards
  8. Sep 6, 2024 at 11:22 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Sumo springs..Got the CAI direct from Shillen and accelerator from Toyota
  9. Sep 6, 2024 at 11:25 AM
    Gotcha.
    BR73[QUOTED] likes this.
  10. Sep 6, 2024 at 1:18 PM
    ghott86
    ghott86 New Member
    VA
    ‘21 Super White SR5 CM 4x4
    Installed some air bag helpers for when towing the toy hauler. And the diff breather relocation to behind the tail light housing.
  11. Sep 6, 2024 at 1:22 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    There’s only 2 models of the Stillen. Dry or Oil and with or without block off plate for water seepage.
    But can confirm that TRD intake accelerator does fit nice and snug with the Stillen air box.
    No modifications needed.
  12. Sep 6, 2024 at 1:25 PM
    You got in in without trimming the intake tube on the box didn't you?
    BR73 and pvn.beluga[QUOTED] like this.
  13. Sep 6, 2024 at 1:25 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Filled the power tank and cleaned the rig up, added a few more recovery gear items.
  14. Sep 6, 2024 at 1:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Just some Hawk Tuah probably
  15. Sep 6, 2024 at 1:28 PM
    AZTundra
    Paul
    Phoenix, AZ
    The ARB kit is nice. I’ve got mine routed up front into the engine bay.
  16. Sep 6, 2024 at 1:32 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Yessir! Didn’t trim or cut anything. The only PITA was the top 10mm bolt with the bushing holding the box in place. I’m going to have to remove it and replace the bolts since it’s rusty.
    Gotta also anti-seize everything.
    bulldog93 likes this.
  17. Sep 6, 2024 at 1:38 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    That kit is definitely nice. Thought about running it to the front too, but I think this will suffice.
  18. Sep 6, 2024 at 1:57 PM
    Nice. I ordered the accelerator from Amazon since the dealer never called me back. At least I'll know it will be here in 2 days. Did you ever find the replacement bolt part numbers?
    pvn.beluga[QUOTED] likes this.
  19. Sep 6, 2024 at 1:58 PM
    reywcms[QUOTED] likes this.
  20. Sep 6, 2024 at 2:11 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    LOL
  21. Sep 6, 2024 at 2:24 PM
    Bergy24
    Bergy24 New Member
    Does this look like it is a part for the Tundra? Found it laying on the ground in my driveway. Close to the driver side rear bumper. Looks like a cap with foam inside.
    1794TX likes this.
  22. Sep 6, 2024 at 2:49 PM
    Looks like something that probably rolled down the street from someone's trash can or something kids could have been playing with.
    Tundrastruck91 and HulkSmurf14 like this.
  23. Sep 6, 2024 at 2:56 PM
    1794TX
    Steven
    N.TX
    '20 1794
    It's the filter for the blinker fluid.
  24. Sep 6, 2024 at 3:18 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Found the same exact thing on my garage floor years ago lol. It sat on my toolbox for years after. Never figured out what it was for.
  25. Sep 6, 2024 at 3:31 PM
    Bergy24
    Bergy24 New Member
    Not likely considering where I found it.
    koditten likes this.
  26. Sep 6, 2024 at 3:53 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Yeah I did! It’s about $6 a pop.. hopefully that’s what shows at the parts center.
  27. Sep 6, 2024 at 4:51 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Thanks for the heads up on the discount.... Applying a 10% discount to my order.....YES
  28. Sep 6, 2024 at 5:12 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
  29. Sep 6, 2024 at 5:14 PM
    Terndrerrr
    Music City
    6UR-FE
    This is nearly what I’ve settled on, except I was thinkin Deavers in the rear and JBA UCAs.
    Bilsteins, Boras, RAS, etc. Yep!
  30. Sep 6, 2024 at 5:51 PM
    French Avocado
    Utah / Wyo
    Ordered two of the accelerators from Lewis Toyota on Monday (the holiday). Arrived on Thursday. 15% off sale ends tomorrow.
    HulkSmurf14 and bulldog93 like this.
