Oil pressure - what’s your reading?
Discussion in '3rd Gen Tundras (2022+)' started by bballjames, Sep 4, 2024.
  1. Sep 4, 2024 at 6:39 AM
    bballjames
    bballjames [OP] New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    I have a 2022 hybrid that I bought new a couple there ago. Been watching all the recall stuff and reading as much as I can about it. I only have 12,000 miles on my truck as I work from home and just don’t drive much.
    Anyway, on to my question. Since new, my oil pressure gauge has never gone past the first 1/4 marker. Is that the normal operating range? I looked around in the manual but it wasn’t much help. The pictures that show the gauge show oil pressure right in the middle of low and high. Curious if my engine really does have low oil pressure or if others see the same in their trucks?
  2. Sep 4, 2024 at 6:58 AM
    Tundrareb
    Tundrareb New Member
    I believe that’s the normal now. If not someone will post different.
  3. Sep 4, 2024 at 7:04 AM
    Voto
    Voto New Member
    2022 tundra SR5 double cab rwd
    When you first start your engine it will read about 1/2 way or higher until it reaches operating temperature than a 1/4.
  4. Sep 4, 2024 at 7:12 AM
    Tundraaa3
    Tundraaa3 New Member
    Mine sits a little under the half way mark.
    Breathing Borla and 60centenergy like this.
  5. Sep 4, 2024 at 8:05 AM
    aj350925
    aj350925 New Member
    Once operating temperature is reached, mine stays just under 1/4 if under 2200 RPM.
    As the RPM climbs upward of 2200 RPM, the oil pressure will increase somewhere between 1/4 - 1/2 on the gauge.
    That's how my truck reads.
  6. Sep 4, 2024 at 8:08 AM
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    Mine never drops below 1/2
  7. Sep 4, 2024 at 1:16 PM
    aj350925
    aj350925 New Member
    You running 0-20?
    STEPBRO[QUOTED] likes this.
  8. Sep 4, 2024 at 1:32 PM
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    Mine also sits normally just under the halfway mark and I have been running 0W-20 oil as well. Been this way since I picked it up new. When I really hit the pedal, it can get it up to 3/4 but it drops back down when staying at constant speed.
  9. Sep 4, 2024 at 3:02 PM
    bballjames
    Inland PNW
    Interesting to see the diversity. It's hard to know how precise the gauge is. Would be more helpful to have numbers to compare. Appreciate everyone's response in reporting. I just started wondering if my reading was lower compared to others. I have had two oil changes done at the dealer with the standard recommended oil weight. And it never seems to fluctuate with driving or on first start up. I'll try to pay attention, but seems like it has never budged from that 1/4 mark.
  10. Sep 4, 2024 at 3:36 PM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    Mine reads just below half at idle and fully warmed up
  11. Sep 4, 2024 at 3:38 PM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    I think my 2024 sits just under half, but who knows how accurate it is. I think there was an update that adjusted it to sit closer to half so it’s more or less a dummy gauge.
  12. Sep 4, 2024 at 3:40 PM
    NVspearo
    NVspearo New Member
    S. NV
    2022 Lunar Rock Tundra SR5 TRD Offroad CM 6.5
    There was a TSB to fix this or software update. I had the same problem, oil pressure gauge always read low. Took it to dealer now it sits right below a half at idle, higher for higher RPMs. That was 20k miles ago. Sitting at 50k now. 2022 SR5
    Ausfahrt, Rcflyersd and pwpblue like this.
  13. Sep 4, 2024 at 4:53 PM
    Breathing Borla
    AZ
    Mine runs a c-hair under 1/2 all the time unless cold start or hammer throttle
  14. Sep 4, 2024 at 4:59 PM
    Hella Krusty
    Hella Krusty New Member
    You described exactly what my 22 Hybrid does....and has done for 2 years. Dont over think it
  15. Sep 4, 2024 at 5:00 PM
    Hella Krusty
    I didn't think you could say c-hair anymore ????
  16. Sep 4, 2024 at 5:12 PM
    Breathing Borla
    AZ
    I can, I have special permission from the old guy club :burp:
  17. Sep 4, 2024 at 5:49 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    I just went for a ride, interesting findings. First, what trim/display are you guys looking at? SR5 is different than Limited for example. If the upper trim ‘multi display’, are you looking at the oil pressure on the left below? The right is the trailing temperature view. I guess.
    The trailering view seems to stay static, at the highest temp achieved.
    My regular pressure view, to the left, definitely fluctuates. It never goes below 1/3 and there under normal load. But when given gas it goes up to 3/4.
    Pic 1 truck is off. Notice trailer view retains highest mark from last running. Also notice zero oil pressure since truck is not started.
    Pics 2 is truck idling. Notice left hand at about 1/3. It only goes to 3/4 with a heavy foot. I’m on original oil.
  18. Sep 4, 2024 at 11:47 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    You appear to be in the normal range. My truck is the roughly the same. The oil pressure showing no pressure is when the engine is off and under battery power on a hybrid. I wouldn't worry about it. If it shows fine on the dipstick, I believe you're good to go.
  19. Sep 5, 2024 at 4:10 AM
    MaineTundy
    Yeah mine seems normal, what I’d expect. I’m wondering if the folks with gauges that don’t move are reading the temp gauge by mistake. Or perhaps if the analog gauges are the difference.
  20. Sep 5, 2024 at 4:40 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    The 2023+ MY has the updated software so they usually sitting under half mark. The 2022, if you haven’t had updated software, was sitting just under the quarter mark when the oil was up to operating temperature before the TSB update. I had the software update done cause my fuel gauge was reading incorrectly and the oil pressure gauge was sitting under a quarter. Now the oil pressure gauge sits just under half.
    It’s all normal. I’d be concern if it shows nothing at idle or it doesn’t move when accelerating. You can have dealer update the combination meter software. Just show them the TSB and your oil pressure gauge at idle and should be under warranty.
    TSB 0022-23
    https://static.nhtsa.gov/odi/tsbs/2023/MC-10238134-9999.pdf
    bballjames[OP] and 60centenergy like this.
  21. Sep 5, 2024 at 5:33 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    2023 1794. Cold start at 70°. 0W20. When at operating temp, 1/4 at idle and just under 1/2 at 2000RPM or cruise speed.
  22. Sep 5, 2024 at 6:40 AM
    bballjames
    Inland PNW
    Mine is a 2022 platinum hybrid. Reading the oil pressure gauge on the bottom left. Sounds like what I’m seeing is normal, although I am going to check if it fluctuates while under load etc. I tow my boat all the time and still cannot ever recall seeing the gauge move (unless as stated above the engine turns off to use the electric motor - then reads 0).
  23. Sep 5, 2024 at 6:43 AM
    bballjames
    Inland PNW
    Thank you - super helpful. I just picked up the truck yesterday as they replaced the squealing brakes. Wish I had them do this at same time but not a big deal. I’ll ask about it next time I’m in.
  24. Sep 5, 2024 at 7:03 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    The right screen is also showing oil temp, not pressure.
  25. Sep 5, 2024 at 7:09 AM
    MaineTundy
    Yes. That is why I italicized the words ‘temperature’ and ‘pressure’. And in my second post wondered if folks might be confusing the two… the little symbols are similar.
  26. Sep 5, 2024 at 7:32 AM
    SnrDisregardo
    Wade
    IL
    Gotcha. I didn't pick up on that and just wanted to make sure you knew too.
  27. Sep 6, 2024 at 8:41 AM
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    Yes!
