  1. Sep 3, 2024 at 8:32 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I've been planning on pulling my RCI's to clean and repaint the frame, which I hadn't done prior to install and I regret. Did you drill the additional holes as RCI recommends?
    pvn.beluga and 300BLK[QUOTED] like this.
  2. Sep 3, 2024 at 8:45 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
  3. Sep 3, 2024 at 8:58 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I didn't when I installed mine. I haven't felt any need to during daily use or as actual rock sliders, they seem pretty stout as they are just using the factory holes.
    250000yota[QUOTED] and 300BLK like this.
  4. Sep 3, 2024 at 9:52 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    I already love them. They're extremely well built and designed. I already dented my door and was lucky not to damage the cab on a trail without sliders so I learned my lesson. This gives me huge peace of mind.
    I actually did not see those recommendations in the instructions I looked at. I purchased these second hand and just used the existing bolt locations that the previous owner used. He did not do any drilling and wheeled the truck a fair bit. Do you have a link? I'd like to see where they recommended to drill.
    bulldog93 and BreyTundy[QUOTED] like this.
  5. Sep 3, 2024 at 10:23 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Ordered a set of Perry parts bump stops. Now to decide which skid plates to go with.
    BreyTundy likes this.
  6. Sep 3, 2024 at 10:26 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Wished that was the case when I installed my WKOR sliders. Took one to the side of my eye when I was drilling holes for the sliders.
    But, they’re an extremely nice set of sliders. I’m going to need to pull them off and repaint them. Still haven’t repainted my trans skid yet.
    300BLK and bulldog93 like this.
  7. Sep 3, 2024 at 11:01 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Yeah i tried to drill for mounts when I installed sliders on my old taco and said fck it after the first hole and ended up welding them. Not a fan
  8. Sep 3, 2024 at 11:52 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    My brother had to get himself (2016 SR5) winched out of this earlier today...
    He was just south of Springtown, TX
  9. Sep 3, 2024 at 12:01 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Excellent excuse to buy a winch bumper now. Except it looks like winching forward would have just dug him in deeper, but still
  10. Sep 3, 2024 at 12:08 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    They winched him forward, with the trailer: https://youtu.be/x80Mt1ldKTk?si=BEG1T0tjW2VtSaqY
  11. Sep 3, 2024 at 12:15 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you use Sport shift?
  12. Sep 3, 2024 at 12:16 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
  13. Sep 3, 2024 at 12:58 PM
    FWC
    FWC New Member
    Frank
    Upstate NY
    2019 Tundra Black Platinum
    Traded the old girl in! I had been looking for a new ride all summer and last week while on vacation my '19 became a Jeep Wrangler. Probably just getting broken in with 56k miles on her but a few things that needed attention soon were enough to push me along. I will still be around as i enjoy the bourbon thread.
  14. Sep 3, 2024 at 1:09 PM
    No words.....
  15. Sep 3, 2024 at 1:42 PM
    250000yota
    Russ
    Berthoud, CO
    My truck is my light duty wheeler, I've got a T100 I'm solid axle swapping for the big stuff, but I'd still like the piece of mind that they're on as securely as possible.
    https://rcimetalworks.com/wp-content/uploads/2020/07/07-20-Tundra-Slider-Installation.pdf
    Step 9. I haven't done it yet, Like I said I'm going to pull mine back off, clean and paint the frame, and reinstall them and drill the lower holes as well. I bought some conical washers like some of the aftermarket skid plates come with to protect the lower bolts.
    I did, but didn't see much gain from it. In sport/4 with tow haul on, my scangauge showed 6-7 mpg, and it kept locking/unlocking the converter, and the converter temps kept spiking above 240 degrees when the converter was unlocked. With it in tow haul, and drive, it shifted between 4th and 5th at 65 mph, but when in 5th with the converter locked the temps stayed right around the 200-205 range and that is where I got the best mileage. It downshifted when needed for passing and hills but I was able to find the sweet spot in the throttle to maintain 5th/locked at 65 mph on the flats.
  16. Sep 3, 2024 at 2:22 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Good thing it wasn't a 3rd Gen. No front tow hooks!
  17. Sep 3, 2024 at 3:03 PM
    coTony
    Tony
    Montrose, CO
    I added a set to my 2010 years ago, wry good quality. The only tip I can give is make sure the new leather is nice and warm so it stretches easier. I did it in triple digits in Arizona and it was not bad. I thought the company had a good video but it was years ago.
    Hammerdog[QUOTED] likes this.
  18. Sep 3, 2024 at 3:05 PM
    koditten
    Kirk
    Midland of the Mitten
    You are reported...
  19. Sep 3, 2024 at 4:07 PM
    AZTundra
    Paul
    Phoenix, AZ
    Finally received the upgraded Land Cruiser blower motor. Will get that installed this next weekend. Noco Boost XL GB50 finally arrived also. Amazon lost the first shipment so I had to cancel and reorder. Opted for the Noco carry case as well.
  20. Sep 3, 2024 at 4:26 PM
    I still need to figure out where to order one from.
    Wallygator and BR73 like this.
  21. Sep 3, 2024 at 4:27 PM
    RobertD
    Robert
    DFW, Texas
    Do the cables fit in that case as well?
  22. Sep 3, 2024 at 4:27 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
  23. Sep 3, 2024 at 4:29 PM
    AZTundra
    Paul
    Phoenix, AZ
    I used Serra Toyota. They were pretty slow to ship though. I had ordered back on 8/10/24 and just received it today. Looking at the labels on the box I’m betting they didn’t have it in stock as it appears to have been shipped from another dealership in MO over to Serra Toyota on 8/21/24 then probably headed my way after.
    bulldog93 likes this.
  24. Sep 3, 2024 at 4:31 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Order from here and part number
  25. Sep 3, 2024 at 4:31 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    thanks for sharing pics of the RCI sliders. They are next on my list and after seeing your truck, I may have to get them sooner! Just went through your build thread...Good job! Quite the transformation!!
    300BLK[QUOTED] likes this.
  26. Sep 3, 2024 at 4:34 PM
    AZBoatHauler
    So.Arizona
    :eek2:
    I just got to help pull the intake off a jeep with 19k miles replacing a fuel injector. The intake manifold is held together by what looked like wood screws going into ABS plastic. Craziest shit I’ve ever seen on a $50k vehicle.
    texasrho83, Terndrerrr, BR73 and 2 others like this.
  27. Sep 3, 2024 at 4:34 PM
    AZTundra
    Paul
    Phoenix, AZ
    Yes, there is a pocket on the other half that fits the bag, jumper cables, charging cord, and 12v adapter. The case also has a handle on it. I think it was $25 on Amazon.
  28. Sep 3, 2024 at 4:36 PM
    RobertD
    Robert
    DFW, Texas
    Nice! Thanks for the additional photos.
    AZTundra[QUOTED] likes this.
  29. Sep 3, 2024 at 5:12 PM
    :eek:
  30. Sep 3, 2024 at 5:18 PM
    Azblue
    The Dirty T ( ^_^)_且
    19k, no warranty?
    250000yota likes this.
