(Intermittent) BRAKE Light on Dash Stays On
Discussion in '2nd Gen Tundras (2007-2013)' started by tscholz2001, Jul 24, 2024.
  1. Jul 24, 2024 at 5:19 AM
    tscholz2001
    tscholz2001 [OP] New Member
    Thomas
    2010 Tundra SR5
    Stock
    I have absolutely no idea what could be causing this at this point. 2010 Tundra 4.6, brake fluid level is right at the max line, flushed a couple months ago by the Toyota dealer (issue was happening before this as well), brake pad level appears to be fine as well, no leaks spotted around the hubs or the firewall, so all of the common issues that cause this light to come on seem to be okay. Light normally comes on after driving a few minutes. Some days it comes on every day and some days it stays off. Is there anything else to check? Does this light throw a code / can it be read by a code reader? I’m not too sure where to go from here so any help would be great. Thanks!
  2. Jul 24, 2024 at 3:40 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Sounds like the sensor that reads the brake fluid level may be going bad. Have someone sit in the car while you move the level sensor up and down to see what the light does
  3. Jul 24, 2024 at 4:20 PM
    tscholz2001
    Thomas
    2010 Tundra SR5
    Stock
    Ah gotcha, is that the sensor that plugs into the bottom of the brake reservoir? Or is there another sensor to move around that I'm missing?
  4. Jul 24, 2024 at 4:37 PM
    Danny3737
    I’m talking about the one in the cap
  5. Jul 24, 2024 at 4:38 PM
    tscholz2001
    Thomas
    2010 Tundra SR5
    Stock
    Oh duh, makes sense. I'll test that out and see if that shows any results
  6. Sep 3, 2024 at 7:34 AM
    tscholz2001
    Thomas
    2010 Tundra SR5
    Stock
    So bit of an update, went ahead and replaced the brake fluid reservoir that houses that sensor in the bottom and all was well for about a month or so, then after a long drive over the weekend the light came back on. I'll be checking for corrosion in the connector but does anyone else have any ideas on where to look? I'm at a loss with this one.
