Missing Relays Secondary Air Injection P0418
Discussion in '2nd Gen Tundras (2007-2013)' started by SurgeUkrainian, Sep 1, 2024.
  1. Sep 1, 2024 at 7:35 PM
    SurgeUkrainian
    SurgeUkrainian [OP] New Member
    2007 Tundra 4.7L - replaced secondary Air injection pump by Passenger fender, replaced both driver and passenger Air injection check valves. All codes cleared except the P0418 - Secondary Air Injection System Relay "A" Circuit.
    Some Internet search pointed to look for relay. Fuse box diagram shows 2 relays but the truck is missing them. Where are they?
  2. Feb 26, 2025 at 9:09 PM
    T.O. Joe
    T.O. Joe New Member
    2012 Toyota Tundra SR5 4x4 Crew Cab 4.6L
    I'm getting this same 0418 code. Trying to figure out if it's just a "RELAY" that's not there, or if I need to just replace both Secondary air pumps. Did you get anywhere with this?
  3. Feb 28, 2025 at 8:59 PM
    lr172
    lr172 New Member
    07 DC
    Looks like those relays are under a cover
  4. Mar 9, 2025 at 5:44 PM
    T.O. Joe
    T.O. Joe New Member
    I never did find out or understand what "relay" meant as it relates to this 0418 trouble code. So, I did some digging on YouTube and 2007-2013 Tundra owners have had problems with water getting into the secondary air pumps. There's also a problem with a foam type filter inside the air pumps that degrades over time and gums up the fan. I just replaced both pumps today. I opened the old pumps up and found the latter. Foam had gummed up the pump (see image). As of now, I have no check engine light anymore. I hope this helps other Tundra owners.
