Gen 3 New Fog Light Install Won’t Work
Discussion in 'Electrical' started by Matlax, Sep 1, 2024.
  1. Sep 1, 2024 at 9:56 AM
    Matlax
    Matlax [OP] New Member
    Hi all, trying to install some Diode Dynamics SS6 fogs on my 2024 Tundra SR5 Off Road. It came with the factory lift so no fogs. The plugs are there but I’m not getting power. The only fuse diagram I’ve found says they’re called LED BEAM but none of my fuse box lids show that one. Any thoughts? Thanks!
  2. Sep 1, 2024 at 12:40 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Unless you have a switch in the cab for the fog lights, the circuit isn’t there. The plug may be, as Toyota doesn’t change a lot of the exterior components. But if there’s no physical switch in the cab, it’s non functional.
  3. Sep 1, 2024 at 12:56 PM
    Matlax
    Embarrassed to say I had the polarity reversed on the plug. ‍♂️ At least it was an easy brain fart to fix! Still curious where the fuse is if anyone knows.
