2018 tundra jbl system
Discussion in 'Audio & Video' started by csunday, Aug 31, 2024.
  1. Aug 31, 2024 at 1:35 PM
    csunday
    csunday [OP] New Member
    Hi there! Does anyone know exactly what I need to gain more output (louder sound) by adding a second amplifier to the stock jbl amplifier? If possible. I purchased a 4 channel 400 watt Skar amplifier to try to accomplish this. No sub woofer. Thinking I need an adaptor of some sort.
    Thanks!
  2. Aug 31, 2024 at 1:40 PM
    csunday
    Also considering the Skar Active Line Output to add to the amplifier. Maybe this is all I need to add to the JBL amp, to boost sound volume?
  3. Aug 31, 2024 at 1:43 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    csunday[OP] likes this.
  4. Aug 31, 2024 at 2:09 PM
    Snert
    Snert New Member
    2021 SR5
    2018 with JBL everything is powered off the factory JBL amp, wiring diagram looks like this:
    The separate channels are:
    Front door woofers
    Rear door woofer and tweeter wired together
    Center speaker
    Sub
    Dash corners
    With a 4 channel amp you can power any 4 of those channels besides the sub. Depending on how powerful the amp is, it might be too much for the factory speakers power handling.
    Depending on the amp, you may or may not need a line output converter.
    In short, if you're using it in addition to the factory amp, you'd basically be taking 4 channels of input/output from the factory amp and replacing that input/output with an aftermarket amp.
    In addition to an amp, you'll need a wiring harness. Check out AutoHarnessHouse.com, you may need to email them for a JBL specific harness.
    First step is figuring out how much power your amp puts out, and how much power the factory JBL speakers/tweeters can handle. If I had to guess, the woofers are no more than 50 watts at 2 or 4 ohms and the tweeters are probably about half that. Feeding them a bunch of extra power will get them louder, but only for a short while until they blow.
  5. Aug 31, 2024 at 3:25 PM
    csunday
    Ok, thanks for the info!
    So in conclusion, if I’m over powering the stock speakers, I could replace them with aftermarket speakers that match the power of the amp? If it’s a 4 channel amp, then I can replace 4 speakers of my choosing? Like the door speakers?
  6. Aug 31, 2024 at 4:27 PM
    Snert
    Snert New Member
    2021 SR5
    Kind of. The front door speakers are each their own channel, while the rear doors have the tweeters and woofer wired together. You could replace all the door woofers with 4 coaxial speakers, or you could replace both the front and rear doors with component sets.
    csunday[QUOTED][OP] likes this.
  7. Aug 31, 2024 at 5:33 PM
    Snert
    Snert New Member
    2021 SR5
    What Skar amp did you get? I can help with speaker recommendations to match it and how you would wire it.
  8. Aug 31, 2024 at 6:06 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Replace everything with aftermarket. All of it.
  9. Aug 31, 2024 at 8:11 PM
    csunday
    I got a 500 watt 4 channel Skar audio rp75.
    I’d like to start over and redo it all. But with a tight budget, I’m trying to do something with this amp to increase volume.
    thanks for all the input.
  10. Aug 31, 2024 at 8:14 PM
    Welcome from NY.
