35" Tires on '22 Limited w/ Leveling Kit
Discussion in 'Wheels & Tires' started by Talkin_Tundras, Aug 29, 2024.
  1. Aug 29, 2024 at 11:38 AM
    Talkin_Tundras
    Talkin_Tundras [OP] New Member
    ‘22 Tundra Limited
    Hey everybody. So I've been watching a lot of YT videos, and trying to research this and can't seem to get a straight answer. I'm in the market for new tires, and was wondering if I could get away with 35's on my truck, which is a '22 Limited with a leveling kit installed, 20" wheels.
    Most of the stuff I've seen mention guys running 35's with a lift, or that Westcott designs collar (which I believe gives you a little more lift in the front vs a leveling kit, right?). Do you think I could get away with 35s with just the lift? Maybe a little bit of rub?
    Anyway, just curious to hear some thoughts from anybody on this.
  2. Aug 29, 2024 at 11:45 AM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Yes…whatever level collar/kit you get will enable you to run 35 without issues.
    You should have zero rub (or at least only minor ones which you pin back the mudflaps or liner).
    good luck.
    Talkin_Tundras[OP] likes this.
  3. Aug 29, 2024 at 4:01 PM
    Coronerrpm
    Coronerrpm New Member
    Bob
    22 tundra red sport
    Non yet
    I spoke with westcott about this last month They said a 1” spacer would be needed for 35’s In there video they made a 3mm or something spacer l but in talking to them it was just for the video and not safe. 1” spacer for the 35’s per them To clear UCA. I went with 295/65-20.
  4. Aug 30, 2024 at 7:09 AM
    bigjuice
    WA State
    2024 Terra TRD Pro
    Yes…It’s also possible to get one of the skinny 35’s
    Those would be either at was just mentioned or 35 x11.5 or like a 285 x 65 (true 35’s are mostly 12.5 wide - sometimes it’s just manufacturers dependent if their true 35’s will clear the UCA or not)
