Hi, 2015 Toyota tundra, crew max cab. big problems with brakes!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by jamkey, Aug 30, 2024.
  1. Aug 30, 2024 at 5:45 AM
    jamkey
    jamkey [OP] New Member
    James
    2015 crewmax tundra, silver
    none
    what is the best way to bleed brakes???? opened bleeders but nothing comes out, tried a hand held manual vacuum pump but that did not help!!!
  2. Aug 30, 2024 at 7:02 AM
    rcsbguy
    rcsbguy New Member
    Push the brake pedal down then open the bleeder?
    WFD473 likes this.
  3. Aug 30, 2024 at 7:06 AM
    Bleeders get crudded up and blocked sometimes. Spray some penetrating oil in the hole when it’s closed and let it sit. Then crack the bleeder and depress the brake pedal. Should clear. If not, go buy another set of bleeders and swap ‘em out. Easy as unscrewing the old one and screwing in the new one. A little messy and brake fluid is caustic, so be ready for cleanup on aisle 3 and have some soap and water handy.
    yakeng and WFD473 like this.
