Custom Aluminum Wheel Wells
Discussion in '2.5 Gen Tundras (2014-2021)' started by ASV_Tundra, Aug 12, 2024.
  1. Aug 12, 2024 at 5:16 PM
    ASV_Tundra
    ASV_Tundra [OP] Adventure Sports Vehicle (ASV)
    Shane
    Beastly Mall Crawler
    Motor/Drivetrain: - Runnin4tacos Exhaust - Tk421tuning Overland Tune - Nitro 5.29 Gears - Balanced Performance Shaft Suspension: - Coachbuilder Ekstrom Front Spacer - SPC Upper Control arms - IVD Suspension Stage 9 Suspension - Camburgracing Racing rear lift shackle - Timberen rear bump stops - Total Chaos Diff Drop Spacer Overland/Other: - Warn Industries Winch - Factor 55 Fairlead - UpTop Overland Bedrack - Prinsuracks Roof Rack - Roam Adventure Storage Boxes - Gofsr High Country 63 Tent - Huracan Fabrication Tailgate cabinet - Decked Bed cargo slider and pan - Center counsel safe and rear seat safes - Weathertech Floor Matts - Rago Dash Mount - 8 Gallon WaterPort Wheels/Tire/Other: - Nitto Ridge Grappler 37” tires - Tremor Wheels 17" - Coachbuilder Ekstrom rear brake relocate kit Electrical/Lighting: - Sierra Wireless - WeBoost - PCI Icom Radio - Kenwood DMX1057xr - Race Siren with 200-watt speaker - Rago Tundra mount - ARB Dual Onboard air system w/ internal bed hookup - Ram mount tablet holder with RAM hub for power supply. - 12v and USB, power ran and installed into the bed of the truck. - ATAK Android Base Station - Switch-Pros - 4 Baja Designs LP 6s - 2 Baja DesignsXL Sports - 2 Baja DesignsSquadron Pros - 4 Baja DesignsS1 camp lights - 7 Baja Designslinkable kit for light bar - 2 Baja Designs IR Lights - 2 Baja Designschase strobe lights - Alpharexusa Headlights - Alpharexusa Taillights - Anytime front and rear camera - Sharkee Mimo Body: - CBI Offroad Hybrid Front Bumper - CBI Sliders - CBI front skids - CBI Rear Bumper - CBI Full Armor Kit - Retrax Bed Cover XR Bed Cover w T Slots - UltraSwing™ Mega-Fit Spare Tire Hitch Mount @rigdsupply - Tailgate Camera Relocation Kit RiGd - License Plate Light Kit RiGd Supply - Bed Molle left and right side with HiLift mount bracket - CBI Lower Control arm Skids - Evil Manufacturing 3rd break light with Antenna
    After countless trips through the desert and trudging through snow and water, I got fed up with the cheap rubber wheel well liners constantly getting shredded. I’ve lost count of how many I’ve had to replace. So, I teamed up with my brother-in-law to create something better—custom aluminum liners. We carefully designed them to avoid snagging any lines, hitting the frame, or interfering with other parts. The initial results are promising! We’re also adding a vent at the front for improved cooling to the fan. I’ll post updates as we make more progress.
  2. Aug 12, 2024 at 5:32 PM
    ASV_Tundra
    Shane
    Working on the front rear now and it’s complete.
  3. Aug 12, 2024 at 5:50 PM
    ASV_Tundra
    Shane
    Looking so
    Good
    snivilous and AdamK like this.
  4. Aug 12, 2024 at 5:58 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Those are awesome!
    ASV_Tundra[OP] likes this.
  5. Aug 12, 2024 at 6:03 PM
    ASV_Tundra
    Shane
    Ben says it needs a rear vent so we’re adding that now to match it up to the front. Then trace the pattern for the other side and done. Was going to paint but this raw looks really clean.
    BlueRibbon4x4, KNABORES and snivilous like this.
  6. Aug 12, 2024 at 6:21 PM
    Looks amazing, excellent craftsmanship. I do think they need to be able to give a little when off-roading as the body and frame are not directly attached to one another and experience some flex. They appear to only be attached to the body correct? Are you gonna paint them ala @BlueRibbon4x4 style?
    BlueRibbon4x4 and ASV_Tundra[OP] like this.
  7. Aug 12, 2024 at 6:31 PM
    ASV_Tundra
    Shane
    correct we added to the body and made sure it has clearance to the frame and away so it won’t smash on any impact. I’ll post more when it’s completed. As for the painting. I’m going to leave raw right now as I kinda like the look. I can always take off and paint it black or a dark grey and leave the vents raw.
    KNABORES[QUOTED] likes this.
  8. Aug 12, 2024 at 6:36 PM
    AZTundra
    Paul
    Phoenix, AZ
    Any plans to mass produce? My drivers side front just tore where the push pins go so I’m needing to replace. Figured I’d ask as I’m sure many others would also be interested.
  9. Aug 12, 2024 at 6:36 PM
    ASV_Tundra
    Shane
    Cut completed. Adding bolt patten now and mounting.
    KNABORES likes this.
  10. Aug 12, 2024 at 6:39 PM
    ASV_Tundra
    Shane
    If we get enough interest and about x15 trucks to order we can CNC and laser cut, bend them, hardware, and install guide and ship.
    AZTundra[QUOTED] likes this.
  11. Aug 12, 2024 at 6:48 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I'd like a set, can we have them in black?
    AZTundra and ASV_Tundra[OP] like this.
  12. Aug 12, 2024 at 6:52 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Following….id like to see some real world use first
  13. Aug 12, 2024 at 6:54 PM
    ASV_Tundra
    Shane
    I’m going to hit the trails in the High Sierra’s next week so will shove a GoPro down there for everyone.
    AZTundra and Shanet421[QUOTED] like this.
  14. Aug 12, 2024 at 7:04 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Nice work!
    RobertD likes this.
  15. Aug 12, 2024 at 7:04 PM
    ASV_Tundra
    Shane
    Rear section complete
    RobertD and AZTundra like this.
  16. Aug 12, 2024 at 7:06 PM
    ASV_Tundra
    Shane
    All completed!
    PolishedTRD, Cruiserpilot and RobertD like this.
  17. Aug 12, 2024 at 7:32 PM
    blenton
    blenton New Member
    Interesting.. Might be in for a group buy. How do you see these handling snow, muck, and wintery weather?
  18. Aug 12, 2024 at 7:37 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Following as well. Impressive craftsmanship.
  19. Aug 12, 2024 at 7:43 PM
    ASV_Tundra
    Shane
    I’ll know for mud and water here in the next week. Snow we have to wait.
    blenton[QUOTED] likes this.
  20. Aug 12, 2024 at 7:44 PM
    ASV_Tundra
    Shane
    all the credit goes to Ben my brother in law. He’s a wizard
    OldGuy03[QUOTED] likes this.
  21. Aug 13, 2024 at 6:03 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    These powder coated black in a bolt on application would be perfection.
  22. Aug 27, 2024 at 12:38 PM
    ASV_Tundra
    Shane
    Ok everyone I have tested in the desert, mountains, a small amount of water and these hold up, no rubbing at all and kick ass! If you guys want to put in an order which would include:
    - Product
    - Product Color Option
    - Logo Stamp Option
    - Vent Options
    - Hardware
    - Install Instructions
    Let me know and if we get a group order of at least 8 - 10 its worth Ben's time to knock this out and get it done. Let me know in the next 30 days.
    AZBoatHauler likes this.
  23. Aug 27, 2024 at 12:41 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    I’m interested. What kind of price point are we thinking??
    armygreentundra likes this.
  24. Aug 28, 2024 at 4:34 PM
    Hiking_Yota
    Hiking_Yota New Member
    Definitely interested, keep us posted.
  25. Aug 28, 2024 at 4:36 PM
    ASV_Tundra
    Shane
    This is what he would like to charge.
    - Product $500 (Front Left & Front Right) - includes two pieces per fender. Comes in raw aluminum that is brushed and polished.
    - Product Color Option $100 (Any Color)
    - Logo Stamp Option $50
    - Vent Options $75 for both sides
    - Vent Colors (Any Color) $30 for both sides
    - Hardware $ Included
    - Install Instructions $ Included
    - Shipping $ Included
  26. Aug 28, 2024 at 5:26 PM
    AZBoatHauler
    So.Arizona
    I was interested. :(
    OldGuy03 and 1987saleen like this.
  27. Aug 28, 2024 at 6:03 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Bypasses and remote resi’s make great blockers lol
    AZBoatHauler and BlueRibbon4x4 like this.
  28. Aug 29, 2024 at 4:05 PM
    seydou
    seydou Distinguished Member
    So we are looking at ~$600 for a full set with vents?
    Yeah, I'm going to go with an OEM or DIY rubber flap(s) screwed in. But good luck with selling them.
