In case anyone cares
Discussion in '3rd Gen Tundras (2022+)' started by ARB1977, Aug 27, 2024.
  1. Aug 27, 2024 at 6:02 AM
    ARB1977
    ARB1977 [OP] New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    IMG_0350.jpg IMG_0351.jpg IMG_0352.jpg Swapped out intake tubes. Already have AFE Prodry air filters and charcoal filters ripped out. Will report back on how it sounds and does. AFE makes a similar setup which is what I should have gone with and would of been a little cheaper too.
  2. Aug 27, 2024 at 6:26 AM
    Breathing Borla
    AZ
    Is this just a sound thing? Or does their dyno show some gains ?
    Ausfahrt likes this.
  3. Aug 27, 2024 at 10:11 AM
    ARB1977
    Anthony
    DFW
    I think AFE has some numbers, I could be wrong. I haven’t dropped the hammer down yet. Normal cruising it does seem a little more responsive.
  4. Aug 27, 2024 at 10:19 AM
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    I like it.
    ARB1977[OP] likes this.
  5. Aug 27, 2024 at 10:28 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I noticed a tiny bit of a sound increase...nothing like when I removed the carbon pillows though
  6. Aug 28, 2024 at 4:48 AM
    ARB1977
    Anthony
    DFW
    A little update on the morning drive. No noticeable change in turbo noise that I noticed. Throttle seems a bit more responsive in normal mode. My trip average remained the same. Wasn’t expecting much. Haven’t floored it yet.
  7. Aug 28, 2024 at 5:40 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    They look cool and if they make fun noises that's great...if you actually want more power you will need a piggyback ecu from Stillen or JB4. The Stillen is completely plug and play, 2 under hood connections and takes literally 10 minutes to install. You must run 93 Premium on any map over 1 there is 0-7. You can switch maps from your phone on the app or under the hood with a simple button push. I think JB4 requires 1 connection into the cabin through a grommet. Map 7 is probably 7 psi more boost than stock. Cost not much more than the cold air setup from AFE or Stillen about $650. 10x the gains 5x less labor...yes I have both Stillen intakes and exhaust but not yet installed...having too much fun in stealth mode with no extra noise right now
  8. Aug 28, 2024 at 7:27 AM
    ARB1977
    Anthony
    DFW
    I know bolt on alone won’t do justice. It needs a tuner. At some point after warranty is up I may consider. I’m hoping to get tig weld creations exhaust next.
