Help…gas leaking from gas tank
Discussion in '2.5 Gen Tundras (2014-2021)' started by kbayashi, Aug 27, 2024.
  1. Aug 27, 2024 at 9:30 AM
    kbayashi
    kbayashi [OP] New Member
    Kevin
    2018 White Tundra Platnum CM
    Amp power steps, Backflip Mx4, Interior LED's, Black mirrors, Pop N Lock Tailgate,TRD front & rear sway bars, lots of tint
    Good morning,
    I recently noticed a strong smell of gas. I crawled under the truck and noticed the front area of the fuel tank was wet. I’m planning to get a camera along the top of the gas tank to see what’s going on. I’m not a mechanic, but I have researched and reviewed how to drop the tank if needed.
    Anyone have any input or suggestions? Any advice or expertise is appreciated.
    Thanks In advance ,
    2018 platinum crew cab
  2. Aug 27, 2024 at 11:27 AM
    If it's coming from the top of the tank it's possibly a seal where the fuel pump drops in. Check all the way up to the filler neck to make sure it's not coming from above the tank. I'm also wondering if it could be a saturated Evap canister. Post pics once you pinpoint where it's coming from.
    reywcms likes this.
  3. Aug 28, 2024 at 4:03 PM
    kbayashi
    Kevin
    Thanks for your input. Couldn’t find my endoscope camera but I stuck my head under the truck and tried to see where it was coming from. It was hard to see but it looked like it was coming from one of the two hoses from the fuel pump. There’s not much room at the top of the tank so it’s still hard to say. I will probably have to drop the tank to locate it.
    Is it recommended to replace anything once I drop the tank? Fuel pump…fuel filter?
  4. Aug 29, 2024 at 5:59 PM
    kbayashi
    Kevin
    I was able to drop the gas tank. it was a bit tricky, but it was fairly straightforward. There. was a quarter tank and it was still heavy. The top was completely drenched with gas. The leak didn’t appear to come from the fuel pump or gasket area. Possibly from One of the two lines or from the pink plug.
    I figured I’d stop and take a break and post my progress. Any comments or suggestions would be appreciated.
  5. Aug 29, 2024 at 6:05 PM
    I'm wondering if you could use low PSI air pressure to check the lines. @reywcms any ideas?
    reywcms likes this.
  6. Aug 29, 2024 at 6:13 PM
    Azblue
    The Dirty T ( ^_^)_且
    It's hard to tell, but it appears to be coming from the lines. Also, while it's probably fine and would last many more years, If I had gone to all the trouble to drop the tank, I'd just go ahead and replace the pump while I was at it.
  7. Aug 29, 2024 at 6:55 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    You can definitely check the lines with some air pressure and see for leaks. I’d definitely drop a new pump and filter while it’s apart why not
    Azblue likes this.
  8. Aug 29, 2024 at 9:27 PM
    kbayashi
    Kevin
    Thanks for all for the replies. I took the lines off and used my compressor to try to pressurize the lines but I didn't use the proper nozzle and it was hard to tell. I'll double check tomorrow.
    Thanks for everyone's help!!!
    Tundra234 likes this.
  9. Aug 29, 2024 at 9:45 PM
    yakeng
    yakeng 3URFE Apologist
    This is actually your truck telling you to replace the fuel pump with a high flow fuel pump and install a supercharger.
    Jaypown and Retired...finally like this.
  10. Aug 30, 2024 at 2:54 AM
    Retired...finally
    This is a stretch but would the emissions warranty cover any of this?
  11. Aug 30, 2024 at 6:05 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    From Picture #4, it definitely looks like that line on the right is leaking. It's drenched. If the lines are cheap, I'd replace both and replace the pump like others have said.
    Unless you can pinpoint a leak somewhere else more definitively.
    WFD473 likes this.
  12. Aug 30, 2024 at 9:00 AM
    kbayashi
    Kevin
    Just got off the phone with the local dealer. The fuel lines are 200+ miles away. Dealer wants $145 for both lines and they will be here tomorrow. On line they are $35 each but will be available for pickup Tuesday (because of the holiday weekend) which is not gonna work. Fuel Pump was $300+ on line (Fuel Pump Assembly was $450+).
    My truck is 6 years old and only has 70K. Dropping the fuel tank was initially intimidating but it was easy enough to do if I need to replace the fuel pump in the future. Supercharger would be fun but definitely not in the budget.
    Thanks again everyone
    Tunrod and yakeng like this.
  13. Aug 30, 2024 at 9:11 AM
    yakeng
    That was mostly in jest (and I'm in the same boat man, outside my budget), but applaud you for dropping the tank and handling it yourself. That type of work is outside the realm of most peoples capabilities, especially with the size of this tank.
    WFD473 likes this.
  14. Aug 30, 2024 at 11:35 AM
    2mchfun
    The way to find this type of leak is with a low pressure smoke machine. You use low pressure air mixed with smoke as the indicator. Check out some YouTube.
    Retired...finally and Tunrod like this.
