jumped with a jump pack now check eng, skid light, 4lo light flashing What did I do?
Discussion in '2nd Gen Tundras (2007-2013)' started by tundrayoshi, Aug 27, 2024.
  1. Aug 27, 2024 at 8:27 AM
    tundrayoshi
    tundrayoshi [OP] New Member
    Joshua
    2005 tundra sr5 4.7 2010 tundra 5.7
    Battery went just low enough not to start used my jump pack. Started now skid light and check engine light or on and 4lo light flashing. I have never used the 4lo? I have a reader just in another town in another car. Truck seems to drive normal no issues. Tried cycling through 2wd 4hi 4lo and back. turned off and on twice. Haven't had a chance to remove battery lead. Any ideas? Did I fry something upon jumping?
  2. Aug 27, 2024 at 8:30 AM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    If your battery is weak/ old, it can cause all sorts of weird stuff.
  3. Aug 27, 2024 at 8:37 AM
    tundrayoshi
    Joshua
    Thanks. There is that. I left a door open last night. I am not sure how old this battery is I would have to look. I cant remember if I replaced it since I bought this truck or not but haven't had any issues with it.
  4. Aug 27, 2024 at 8:45 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Solid check engine, vsc and a flashing 4lo indicates a weak battery. See if you can get the battery load tested?
    If it has a good charge you can try disconnecting the battery terminals for 10 minutes to see if it clears. If you have a weak cell it will still keep the Christmas tree effect going.
  5. Aug 27, 2024 at 11:00 AM
    tundrayoshi
    Joshua
    Thanks!!! Will do!
  6. Aug 27, 2024 at 11:19 AM
    If it's close to 3 years old or older, replace it. An old battery will quit on you very quick. It will start great one day, and the next day it's dead.
  7. Aug 27, 2024 at 3:56 PM
    tundrayoshi
    Joshua
    Thanks to everyone after it sat at work for the day everything was fine started right up no lights on or flashing. Thanks for all the info. I do love my jump packs for exactly the time you mention Tundra 234 I always try to get every day out of a battery.
