Thermostat Housing FIPG vs Gasket
Discussion in '1st Gen Tundras (2000-2006)' started by bfunke, Aug 26, 2024.
  1. Aug 26, 2024 at 1:07 PM
    bfunke
    bfunke [OP] Tundra Curmudgeon
    Toyota uses only FIPG here but Felpro sells a gasket. Anyone have any experience with this gasket?
  2. Aug 26, 2024 at 1:20 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    On first Gen Tacoma OEM FIPG failed leading me to buying a water pump as I thought it was coming from weep hole. Instaled new water pump and FIPG only and about a year later FIPG failed again. Reinstalled original OEM pump and used both FIPG and Gasket that came with second pump and no more issues. I just applied very thin layer of blue gasket maker to both sides of gasket.
  3. Aug 26, 2024 at 1:51 PM
    Jack McCarthy and 87warrior like this.
  4. Aug 26, 2024 at 2:23 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Bro I used freight o harbor red. Zero issues
  5. Aug 26, 2024 at 4:38 PM
    Flex seal (as seen on TV). Because….why not?:notsure:
  6. Aug 26, 2024 at 5:10 PM
    bfunke
    Crazy thing is it’s not leaking but I have to remove it to access front and rear water crossover pipes where those gaskets are leaking.
  7. Aug 26, 2024 at 5:16 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I don’t remember that when I did mine
  8. Aug 26, 2024 at 5:30 PM
    bfunke
    Leaking here
  9. Aug 27, 2024 at 7:55 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    When I did the timing belt on my truck there was a paper gasket on the thermostat housing. It showed no signs of leaking.
    I've also seen folks polish the groove and install a Buna-N or Vitron 2-034 o-ring with some silicone grease in place of FIPG with good luck. If you buy a new thermostat housing from Toyota it comes with an o-ring like material already in the groove. I might give the o-ring a try in a couple of years when my Land Cruiser needs the t-belt done again.... if I remember.
    That said, I have used Permatex Anaerobic Gasket Maker five times on the 2UZ thermostat housings without a leak.
