Dark chrome chips on Platinum
Discussion in '3rd Gen Tundras (2022+)' started by jtram, Aug 22, 2024.
  1. Aug 22, 2024 at 5:08 AM
    jtram
    jtram [OP] New Member
    I have a 23 platinum. I noticed lots of tiny chips on the dark chrome(maybe from small rocks). When looking closer, that dark chrome is just a regular chrome with a layer of tint paint. Disappointed on the quality they used here.
    Jettster likes this.
  2. Aug 22, 2024 at 6:01 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Agreed, my 23 1794 is getting tiny chips in the plastic chrome on the mirrors and grille too...my old Toyotas either have higher quality thermo-plastic trim or actual stainless steel or chrome metal (1997 4Runner or 2003 Tacoma) Let's be honest...nobody puts vehicles together like Japan did from the late 90's to mid 2000's. My 2002 LS430 blows away any new Lexus or high end Euro car in build quality. That era of glass headlights, real bolts and screws holding things together is sadly gone. Everything is plastic, pop rivets and pushpins now...oh and bio-degradable so rodents will enjoy the chew...like my intake vapor mats that were eaten up on the dealers lot.
  3. Aug 22, 2024 at 7:20 AM
    Breathing Borla
    Northern Illinois
    reason #600 chrome should be removed:burp:
  4. Aug 22, 2024 at 7:48 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    glad i covered mine with bumpershellz
    Timmy23 likes this.
  5. Aug 22, 2024 at 8:58 AM
    KuehnMK
    KuehnMK New Member
    2023 Tundra Crewmax 4X4 Platinum
    2023 Platinum owner here: I have noticed the same. Its obvious when you look at any chip in the grille, that it is obviously the same chrome grille they used on the 1794 but with another layer of dark chrome coating on top.....making any chip WORSE since now the chrome is noticeable!
    Toyota does not make a touch up paint for the dark chrome. My Platinum is Magnetic Grey....I just used a tooth pic and tapped in the MGM paint color into any chip I get in the grille.... Its not a perfect match, but it gets rid of the chrome and makes it 90% less noticeable!. I did paint protection film on my Tundra on the whole front end, they couldn't do the Grille since its too complicated. So I don't get chips in the mustache pieces thankfully!
  6. Aug 22, 2024 at 9:02 AM
    Breathing Borla
    Northern Illinois
    color match the stash for the win and not worry about plastic chrome chips, HA
    SWFL23TRDOR likes this.
  7. Aug 22, 2024 at 1:59 PM
    jtram
    Nice! But the grills (chain link style) of your platinum is also prone to this chipping. Was about to wrap the moustache too, but noticed the grilles are also affected. So no go
    Woodrow bangs likes this.
  8. Aug 22, 2024 at 2:22 PM
    jtram
    Good but the grilles are made from the same exact material and finish. There would be chips there as well.
    Slrrepair likes this.
  9. Aug 22, 2024 at 2:24 PM
    Breathing Borla
    Northern Illinois
    I dont think they are, its seems different
  10. Aug 22, 2024 at 3:52 PM
    jtram
    Here the picture of my grille
  11. Aug 22, 2024 at 3:58 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    I took this pic on 4/20/24. It was at the dealer for repair, Platinum MY23.
  12. Aug 22, 2024 at 5:07 PM
    Breathing Borla
    Northern Illinois
    I’ll take a closer look at mine but the material seemed different for the grill , my surround is completely different now though as the parts were ordered then painted then installed and you start with no chrome when your going to paint
  13. Aug 22, 2024 at 7:06 PM
    jtram
    Yes it is the same material. Plastic dark chrome. Unless your 2023 platinum is different than ours. Check the pic posted above by MaineTundy . I have the same
  14. Aug 22, 2024 at 7:07 PM
    jtram
    Yes this is the same as mine.
  15. Aug 22, 2024 at 7:22 PM
    biebs96
    PA
    it’s hard to see any damage or chipping with the rain water present.
    not trying to be a d**k, but I even went to get my ipad and I don’t see anything.
  16. Aug 23, 2024 at 4:58 AM
    MaineTundy
    Maybe this will help. The ‘arrow’ is at the bottom of a 3” section of chipped paint. It’s on the stash, not the grill.
  17. Aug 23, 2024 at 10:46 AM
    Just_Tito
    Just_Tito New Member
    23 Tundra
    Same here… I purchased an extended warranty when I first bought it, it’s supposed to cover paint defects. I’m taking it in this weekend and I will see what they say.
    jtram[OP] likes this.
  18. Aug 23, 2024 at 10:58 AM
    Breathing Borla
    Northern Illinois
    do you guys have any chips on the grill portion?
    I looked at mine and it's clean, but so is my grill surround.
    but that is not painted over chrome, it was base black parts ordered specially to be painted by a professional body shop
  19. Aug 23, 2024 at 11:00 AM
    Just_Tito
    23 Tundra
    I looked over mine before I took the pics and it’s only the surround. I got quoted 1k to color match it by a local body shop
  20. Aug 23, 2024 at 11:01 AM
    Breathing Borla
    Northern Illinois
    the black unfinished replacement parts are cheap. They weren't quoting some prep to the current chrome one right?
    maybe get another quote to see if you can do any better.
    its looks so much better color matched anyways
  21. Aug 23, 2024 at 11:10 AM
    Just_Tito
    23 Tundra
    It was for stripping and paint. This shop is where I take my Audi for work. I’m sure I can get it cheaper somewhere else, but I trust these guys. Hopefully this extended warranty will do something about it. This is clearly a defect
    Tundrastruck91 likes this.
  22. Aug 23, 2024 at 11:11 AM
    Breathing Borla
    Northern Illinois
    don't dick around with striping, prep, and paint.
    new OEM parts unpainted and ready are cheap, and then your not messing with the previous chrome ones.
  23. Aug 23, 2024 at 11:35 AM
    jtram
    woah! this is not good. I feel like we're all in the same boat :( Anywhere to report this? or this is not a known issue at all?
  24. Aug 23, 2024 at 2:04 PM
    aj350925
    aj350925 New Member
    My dealer was nice enough to replace my grill and mustache for free when it started to flake.
  25. Aug 24, 2024 at 5:29 PM
    jtram
    Replace with what? The same dark chrome material? Or the replacement is now with a different material?
  26. Aug 24, 2024 at 6:50 PM
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    maybe bumbershellz will consider a dark chrome mustache??? OR EVEN DARK CHROME TO COVER PLATINUM ON THE DOORS. Sorry. I have a few small chips on the Stache but haven’t noticed much on grill.
  27. Aug 24, 2024 at 7:49 PM
    jtram
    Some of us here are not so lucky. We had chips on both stash and grille. Even if bumpershellz do a stash, what about the grille?
  28. Aug 27, 2024 at 4:43 AM
    aj350925
    aj350925 New Member
    Replaced with the exact OE dark chrome grille.
    Kerktam likes this.
