Aligning/adjusting caster and camber.
Discussion in 'Suspension' started by max_ellis74, Aug 24, 2024.
  1. Aug 24, 2024 at 11:44 AM
    max_ellis74
    max_ellis74 [OP] New Member
    Max
    How do you adjust the camber and caster on these trucks. And yes I have an alignment machine I can use. If I do a lift kit I’d like to adjust everything to where it should be. Is there a video that shows how to adjust them?
  2. Aug 24, 2024 at 1:25 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    If you don’t know how, this isn’t the truck to practice on. Even experienced techs have trouble aligning these trucks.
    SoCal_Tundra21 likes this.
  3. Aug 24, 2024 at 1:27 PM
    max_ellis74
    Max
    Is there video on how to do it though
  4. Aug 24, 2024 at 1:30 PM
    Danman34
    Danman34 New Member
    Danny
    Maybe. Look on you tube. But these trucks are hard to align, especially when lifted. The smallest bit out has dramatic effects on the driving Characteristics of these trucks. If you don’t know where to even start on adjusting these trucks, don’t attempt it yourself. You’ll end of breaking the cam tabs or just making eveything worse.
  5. Aug 24, 2024 at 1:36 PM
    max_ellis74
    Max
    I work at a tire shop.
  6. Aug 24, 2024 at 1:39 PM
    Danman34
    Danman34 New Member
    Danny
    Ide advise someone who knows how to do alignments do the work. You wouldn’t go on the internet and ask people how to replace a 200 amp service because you have some screwdrivers and a multi meter. This is basically the same level of experience.
    reywcms likes this.
  7. Aug 24, 2024 at 2:38 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I wish I had an alignment thingamajig...I recently upgraded from using strings to a DIY alignment tool
    SAGE63 and SoCal_Tundra21 like this.
  8. Aug 26, 2024 at 10:22 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    To answer the OP’s question, you will only need to adjust a couple things. All at the same time…
    Your LCAs will adjust the camber and caster, but that will also adjust the toe. You’ll correct this via tie rod adjustment, which will skew the camber and caster again! Then you’ll slightly move the LCAs to fix the camber and caster, which will once again affect the toe….
    Yes, you can DIY this with the proper tools. Absolutely worth paying a coworker that knows what they’re doing since you work at a tire shop. Amazing what a 12-pack of beer will get you…
