Anyone know/remember how to remove this?
Discussion in '1st Gen Tundras (2000-2006)' started by fishordie, Aug 26, 2024.
  1. Aug 26, 2024 at 10:07 AM
    fishordie
    fishordie [OP] New Member
    Earl
    East Texas Piney Woods
    2002 SR5 AC 2WD 210K Grocery Getter
    Middle of Timing Belt - Possibly Cam seals
    Working on timing belt replacement, this sensor clip (im sure thats not what it really is but sounds good) that has to be pulled through the LH timing cover that has the black plastic clip piggybacking on the connector that snaps into the cover...anywho, I'm not going to volunteer how much time I have spent on it and cant get it off. I have inserted pick, micro screwdriver, etc..no dice. Im trying not to break it but Im about ready to.
    Also, I'm assuming all the various plastic clips are OEM only? I broke one of a different kind yesterday.
    THANKS
  2. Aug 26, 2024 at 10:11 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    If I remember. You push up with a smal pick on this little plastic tab. IMG_5023.jpg
    fishordie[OP] likes this.
  3. Aug 26, 2024 at 11:15 AM
    bfunke
    bfunke Tundra Curmudgeon
    here is the clip
    shifty` and fishordie[OP] like this.
  4. Aug 26, 2024 at 12:15 PM
    fishordie
    Earl
    FishNinja, ill keep trying...i may need to quit trying break it so much...
    BFUNKE!! Thanks a million.... sometimes trying to find these little parts or describe them to someone onver the phone is the real headache and time killer..TY!!
    Best forum ever
    bfunke likes this.
  5. Aug 26, 2024 at 12:56 PM
    bfunke
    this is the other clamp on my cam cover. It’s useful because it closes around a wire or cable
  6. Aug 26, 2024 at 3:04 PM
    fishordie
    Earl
    just got and went out to shop.... I think whatver lever is supposed to be in there to release is gone.....maybe previous owner or mechanic broke when he put it on last time...i shined a lite directly in there and its hollow all the way under there with just those two plastic side rails...kind like looking under a catamaran. Just going to break it ...argggh..thanks
