2023 Capstone - Key Fob Issues
Discussion in '3rd Gen Tundras (2022+)' started by JMM23FT52523, Aug 19, 2024.
  1. Aug 19, 2024 at 2:13 PM
    JMM23FT52523
    JMM23FT52523 [OP] New Member
    2023 Capstone Tundra
    My original key fob worked for about 1 year, then I started using the 2nd one that finally arrived 8 months after purchase. Now they conflict each other and unless you put one to sleep they cause communication issues with doors and lock and starting truck.
    Anyone else having similar issues?
  2. Aug 25, 2024 at 6:04 AM
    1sttoyotundra
    1sttoyotundra New Member
    2023 Capstone
    I don't have my second fob yet, but how do you put one of them to "sleep"?
  3. Aug 25, 2024 at 6:51 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
  4. Aug 26, 2024 at 7:46 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    After 14 months of my original fob I received "low battery on remote key" on my dash cluster on fire up.
    So I got lazy and just swapped out key fob components with battery intact from the new fob to existing one verses toying with the battery itself and because I have a AJT fob.
    The truck didn't seem to recognize the programing in the newer second fob,meaning to unlock the doors by grabbing drivers side or passenger front door or locking it by touching the handle.
    It would unlock/lock and start by physically using the remote. I wonder if when programing the front end of "do's and don't of the truck itself programs the remote at hand simultaneously.
  5. Aug 26, 2024 at 9:04 AM
    JMM23FT52523
    Press the lock button twice on remote and hold it down, at same time with other hand hold down the unlock button. You will see a red light slowly blink and then it will go out and remote will be asleep.
    To re-activate just press any button on fob.
  6. Aug 26, 2024 at 10:54 AM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    Did you link the (now swapped) key to your profile is or is simply in a generic mode where it functions by the default values?
  7. Aug 26, 2024 at 11:10 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    No, I just re-swapped the guts to original housings and stole the battery from #2 and put it in #1.
    All is good now.:thumbsup:
    pwpblue likes this.
