Max towing without a trailer brake?
Discussion in 'Towing & Hauling' started by Eurodriver, Aug 21, 2024.
  1. Aug 21, 2024 at 4:26 PM
    Eurodriver
    Eurodriver [OP] New Member
    I have towed a 10,000lb trailer equipped with brakes without much of an issue but this setup below is only about 8,000lbs and it is super sketch.
    Coupled with 35s I was standing on the brake pedal and didn’t even feel like there was a connection between the pedal and brakes. I’ve never experienced anything like it except on a ‘98 4Runner with a bad master cylinder.
    I assume this is “normal” but I wanted to ask anyway.
    Is it? How are guys towing so much weight safely if so?
    Also, fun fact, if you get a tractor you don’t need to use your 1/2 ton as a work horse around the farm and you can keep it clean! Who knew?!? @hagrid
  2. Aug 21, 2024 at 4:49 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I dont really get the question? If it's a newer trailer it will have brakes and you just need a brake controller.
    An old raggety trailer like that, either find an electric brake kit that fits or put new axles under it.
    If your gonna ignore all that, drive slower and cross your fingers. Or borrow a 3/4 ton or larger truck.
  3. Aug 21, 2024 at 5:12 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    8000 lbs am no brakes? Yes, there is something wrong with the truck.
    The driver. :anonymous: :boink:
  4. Aug 21, 2024 at 5:30 PM
    Eurodriver
    Im a big giant dummy.
    GODZILLA likes this.
  5. Aug 21, 2024 at 5:34 PM
    18" TRD Off Road Wheels
    Yeah, I wouldn't tow anything over 3-4K lbs without trailer brakes. It's just too much white knuckle with all the derps on the roads these days. Even a 3K lbs trailer gives enough extra momentum that you definitely feel it when trying to stop. I'd rent a better trailer or upgrade that one as @Half Assed suggested.
  6. Aug 21, 2024 at 6:11 PM
    Ericsopa
    Ericsopa Old man and the sea
    Different states have different laws concerning trailer brakes. In Texas, max trailer weight without brakes is 4500#. Coincidentally, my boat trailer loaded weighs 4500#. :rofl:
    AZBoatHauler likes this.
  7. Aug 21, 2024 at 8:46 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Pretty sure the law here is anything over 2000 lbs needs brakes.
  8. Aug 21, 2024 at 9:01 PM
    koditten
    Kirk
    Midland of the Mitten
    We in Michigan require trailer brakes at 2999 lbs.
  9. Aug 21, 2024 at 9:52 PM
    AZBoatHauler
    So.Arizona
    3,000 requires brakes in AZ
    Terndrerrr likes this.
  10. Aug 21, 2024 at 10:09 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    Truck ain't heavy enough
    and you need trailer brakes with a piece of equipment loaded
    Big Double axle trailer needs it's own breaks, it weighs like 2K+ empty
    I have driven plenty of heavy trailers with no brakes, usually with a dually and it can still be sketchy...Not wise even though I never wrecked
  11. Aug 21, 2024 at 10:18 PM
    blenton
    blenton New Member
    As other have said, your state will usually set a max trailer weight without breaks; however, some states have a max UNLADEN weight, instead of LADEN weight. Most of the single axle trailers around me come with an un-braked 3500 lb axle, a GTW of 2995, and an unladen weight of ~1100 lbs. Anything over 1500 lbs unladen needs brakes, any double axle axle trailer needs at least the front axle braked, and triple axles need two axles braked.
    That said, I had a 6x12 v nose that didn't have brakes. I had it loaded to the max more than once and braking was... sufficient... Since I pulled it year round, I decided to put a brake kit on it (I was lucky and the axle came with flanges for brakes) for a better balance on snowy roads. Even with the brake controller set quite low, it made a noticeable difference in balance and handling. The truck was fine stopping it without brakes, but it was better with brakes on the trailer.
    I pulled that trailer about once a week or more and never had an issue bringing it to a stop. I did have a panic stop with it on the freeway once which was pretty white knuckle, but it did stop it.
    I've also had intermittent brake failure on a double axle car hauler I borrowed from a friend. I had a sedan on it for a four hour drive including a 5 mile decent at 10% grade. A brake wire on the second axle had snagged and torn (not my doing, but I fixed it the second I got back to my shop); brake controller would read continuity through the first axle but as soon as you apply brakes and voltage, it would trip a 'No Brake' warning and they brakes didn't work. So at 5-6k lbs total, the truck was still able to slow and stop the trailer without trailer brakes. I didn't need to stop in a big hurry, but it handled the descent (I engine brake anyways) and normal highway speeds and "traffic" without issue.
  12. Aug 22, 2024 at 12:20 AM
  13. Aug 22, 2024 at 5:13 AM
    koditten
    Kirk
    Good info.
  14. Aug 22, 2024 at 5:24 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    You need a trailer brake kit. And also— probably a trailer brake kit.
    But don’t forget to add a trailer brake kit either.
    (The repetition helps my kids)
  15. Aug 22, 2024 at 6:59 AM
    Eurodriver
    Great info guys. The trailer isn't mine, I am just doing some tractor work and the guy who asked me to help had a trailer.
    It's SKETCH. Had no idea trailer brakes made such a big difference because I'm dumb.
    GODZILLA, Terndrerrr and koditten like this.
  16. Aug 22, 2024 at 9:08 AM
    Terndrerrr
    Music City
    6UR-FE
    You know we love you and your “yeet first ask questions later” style. :cheers:
  17. Aug 22, 2024 at 9:59 AM
    Eurodriver
    Life is too short to do research for things that can save your life.
  18. Aug 25, 2024 at 6:47 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Your life? Not conspiracy to commit vehicular murder? I've actually stopped an old guy with a lumber load hanging out the back
    of his pickup. Completely unsecured. When I see stuff like that my brain hurts. Glad you understand now
    Cpl_Punishment likes this.
  19. Aug 25, 2024 at 6:57 PM
    centex
    centex New Member
    My 16’ dual axle came without brakes. First time I towed my rzr I ordered the brake kit when I got to the off road park. No way in hell I’d tow 8k without trailer brakes. Not even an HD would handle that well. $300 for the brake kit and it makes stopping not even a question these days.
  20. Aug 25, 2024 at 9:45 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    It’ll tow that trailer just fine without brakes.
    Won’t stop it fer shit, but will tow it fine.
  21. Aug 25, 2024 at 10:01 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    All brakes ever do is slow you down. Ain’t nobody got time for dat.
    Terndrerrr and Cpl_Punishment like this.
