Should I be worried about this leak?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jacksondk18, Aug 25, 2024.
  1. Aug 25, 2024 at 9:46 PM
    Jacksondk18
    Jacksondk18 [OP] New Member
    Just got king 2.5 installed and cv axel replaced, noticed a small popping noise and saw this when I went under the truck.
    should I be worried? Or can I keep driving on this.
    I’ll put pictures of both sides, driver side is the one that looks worse.
  2. Aug 26, 2024 at 4:54 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    What’s leaking? Just looks like residue that wasn’t cleaned during install
  3. Aug 26, 2024 at 5:05 AM
    Penetrating oil used to loosen fasteners during install?
  4. Aug 26, 2024 at 5:14 AM
    timsp8
    NY
    What they said. Is it liquidy or greasy? Spray it off real good and see if it returns.
    Jacksondk18[OP] and Medicineman like this.
  5. Aug 26, 2024 at 8:56 AM
    VUDUBLU
    VUDUBLU New Member
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Check the lower ball joint. Mine looked like that, but I was able to clearly see that it was torn/leaking so I had both sides replaced.
  6. Aug 26, 2024 at 1:01 PM
    Jacksondk18
    It’s like greasy thick residue. IMO it looks like a cracked lower ball joint.
    my install guy said it looked worn out but nothing major and should be fine, do you guys agree? Can’t tell if he just wants me to wait for some new lowers haha
  7. Aug 26, 2024 at 1:17 PM
    VUDUBLU
    VUDUBLU New Member
    2019 TRD PRO Tundra
    The ball joint itself can be replaced. Parts weren’t crazy expensive. I think like $70 a pop. Install will vary but I’d say 2-3 hour job for most shops.
  8. Aug 26, 2024 at 1:27 PM
    Jacksondk18
    Here’s another picture, idk if this helps anymore.. but let me know.
  9. Aug 26, 2024 at 4:24 PM
    d33pt
    d33pt New Member
    Personally I don't think it's a big deal unless you find a crack or hole in the LBJ boot. Those things always ooze a little grease.
