0W vs 5W engine oil
Discussion in 'Performance and Tuning' started by Voto, Aug 24, 2024.
  1. Aug 24, 2024 at 9:45 AM
    Voto
    Voto [OP] New Member
    2022 tundra SR5 double cab rwd
    As per owner’s manual 5W can be used as long as 0W is used at next oil change. Being that I live on the gulf coast in southern United States and temperatures can reach 100 degrees during the summer I am thinking of running 5W-20 all year except winter months from January to March. Has anyone been running 5W-20 and if so what is your experience with it?
  2. Aug 24, 2024 at 10:01 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    5/20 & 0/20 will be the same thing once it's hot...run it if it makes you feel better but it's literally the "same" thing at higher temps
    ARB1977 and Breathing Borla like this.
  3. Aug 24, 2024 at 10:11 AM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    filler cap says 0w so I will follow that...
  4. Aug 24, 2024 at 11:49 AM
    60centenergy
    60centenergy I'm not superstitious, but I am a little stitious
    Zack
    GVL
    2024 Lunar Rock SR5 Tundra TRD Sport
    I thought I’d have to run 5w-20 based on what I could find but then found that Mobil 1 has a 0w-20 so I’ll run with that. Always ran Mobil in my vehicles and had great success with them.
    Voto[OP] likes this.
  5. Aug 24, 2024 at 12:15 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    In my commuting days I ran 2 Camrys 800 miles per week along the I15 through some of the most extreme Mojave Desert summer time temperatures possible. The world's largest thermometer displayed 120+ on multiple occasions running 80+ up that massive grade coming out of Baker California.
    Changed oil when service indicator notified me which always was around 5k and averaged every 1.5 months.
    Royal Purple 0/20 with a couple 5/20 when 0 wasn't available.
    Sold 6th gen I4 at 170k to get V6 Xse 7.5 gen currently at 147K no issues.
    Sean492, Voto[OP] and oddhours like this.
  6. Aug 26, 2024 at 6:22 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Why bother?, "0" and "5" is the viscosity for cold oil/motor. "20" is the viscosity when the oil/motor is hot. You do not gain anything by using 5w-20 instead of 0w-20 besides potentially not sufficient lubrication when the motor is cold, might be no issue for TX but still, why bother?
  7. Aug 26, 2024 at 6:42 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    The only insufficient lubrication with the thicker oil at cold would be when the oil froze completely. Under all other circumstances thicker oil provides better lubrication.
    That said, use 5w30.
  8. Aug 26, 2024 at 7:44 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    It absolutely does not matter in your part of the world.
  9. Aug 27, 2024 at 3:37 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
  10. Aug 27, 2024 at 3:39 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    a few moons ago, I posted a comparison of 0w-20 & 5w-30
    in my engine.
    and Blackstone commented the 5w-30 had remarkably less wear indicators.
    5w-30 it is.
  11. Aug 27, 2024 at 6:48 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I believe it was first muttered at The Alamo: "Give me 5W-30 or give me death."
  12. Aug 27, 2024 at 6:49 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    :thumbsup:
    AZBoatHauler likes this.
  13. Aug 27, 2024 at 7:00 AM
    Breathing Borla
    Northern Illinois
    Not really commenting on the mechanical portion of your recommendation but I’m not sure with all the engine bs going on it shouldn’t be noted that I would stick to whatever is supported by the manual.
    I haven’t looked yet but I don’t think that is in there is it?
  14. Aug 27, 2024 at 7:10 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    As an engineer myself, I understand marketing and regulations BS pressure other engineers see every day. If not that, the engines would still use 20w50, purely for longevity purpose. From practical point of view, 5w30 is a bit thicker version of 0w20. Barely enough to show less wear materials in the samples. It does not affect oil pressure buildup times, VVT or hydraulic valve lifter function. Many of 5w30 break down into w20 range after only 1k miles, even in port injection engines.
    GAMark, Voto[OP], Terndrerrr and 2 others like this.
  15. Aug 27, 2024 at 7:16 AM
    Breathing Borla
    Northern Illinois
    that’s fine not questioning any of that , just saying it worth noting I don’t think that is supported in the manual
    but alas, maybe that doesn’t matter who knows
  16. Aug 27, 2024 at 7:18 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Go with a boutique expensive 0w20 then, like Red Line. It will be thicker than some of 5w30 in couple of months. It is considerably thicker than Toyota 0w20. I was using Red Line for years, until we've got our third baby.
  17. Aug 27, 2024 at 7:21 AM
    Breathing Borla
    Northern Illinois
    I can understand that. Good to have recommendations
    For me I just go with whatever my dealer puts in and do every 5k, but I’m not a 200-300k owner anymore either so that’s a factor
    OldGuy03 likes this.
  18. Aug 27, 2024 at 7:23 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yeah, makes no sense then. Actually, paying $100+ for oil change makes no sense anyways, since modern machinery is not designed for a very long run anyways :)
    Mr Badwrench and OldGuy03 like this.
  19. Aug 27, 2024 at 7:37 AM
    Breathing Borla
    Northern Illinois
    lol, some truth to that, my dealer isn’t that expensive either which is nice
  20. Aug 27, 2024 at 7:42 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I still remember that night 200 miles away from home when the engine full of Red Line blew up at 2 am =) Certainly makes you reconsider how much time, money and efforts you put into a vehicle that would still break. And whether you really need a neat cabin and super-comfy lounge-grade chairs, or crappy plastic and cloth seats running for as long as you put gasoline and do oil changes is good enough (the answer: it is good enough and all you need).
  21. Aug 27, 2024 at 7:47 AM
    Breathing Borla
    Northern Illinois
    for sure , with what you do you have the perfect rig
    same here
    vtl[QUOTED] likes this.
  22. Aug 27, 2024 at 2:20 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I assume your past warranty period. If that’s the case go with a 0W30. All your changing is start up flow when you go 5W or 10W.
  23. Aug 27, 2024 at 11:25 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    My understanding is the 20w portion is for gas mileage purposes to satisfy the all knowing Federal government. That being said, I run Amsoil 0w-20 in mine. I previously had F-150 Ecoboost's that called for 0w-30 oil, but ran 5w-30 because it seemed to like it better, with no decrease in mileage. I may consider going 0w-30 at my next change, but who knows? I'll be moving to Wisconsin next year, so I don't know if I'll see a benefit once I'm out of this Phx heat.
  24. Aug 28, 2024 at 3:14 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    We saw no measurable MPG decrease going 0w20 to 5w30 in our V8 Tundra and Sequoia in Massachusetts, with winter trips further north to Maine and Canada.
  25. Aug 28, 2024 at 6:01 AM
    Voto
    Owner’s manual for Land Cruiser with same engine from Toyota.ae website.
    Mr Badwrench and vtl like this.
  26. Aug 28, 2024 at 7:25 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Question every V6TT engine owner should ask himself and give an answer: "Do I drive in 0 F temperatures and below? No? 10w30 is good for me".
  27. Aug 28, 2024 at 7:37 AM
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    Link to post and thread?
    GAMark likes this.
  28. Aug 28, 2024 at 7:44 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
  29. Aug 28, 2024 at 7:48 AM
    Voto
  30. Aug 28, 2024 at 7:55 AM
    bucketlintels02
    NW Georgia
    Thank you, and I am very impressed, particularly considering that I still have trouble navigating the search functions effectively.
    I just saw the Kirkland oil during my Costco run on Monday, very interesting seeing your report on it. Is that what you use now?
