Serpentine Pulleys
Discussion in '1st Gen Tundras (2000-2006)' started by fishordie, Aug 23, 2024.
  1. Aug 23, 2024 at 7:46 PM
    fishordie
    fishordie [OP] New Member
    Earl
    East Texas Piney Woods
    2002 SR5 AC 2WD 210K Grocery Getter
    Middle of Timing Belt - Possibly Cam seals
    Looking to replace all the serpentine pulleys after I complete timing belt replacement. I started down the OEM path and the firs OEM pulley I googled, tensioner I believe, was around 80. So, I thought I would see if anyone had any aftermarket recommendations that would be acceptable.
  2. Aug 24, 2024 at 2:17 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Rockauto.com
    Look for Aisin parts, and if none available, denso, and dorman is good too
    Riverdale21 likes this.
  3. Aug 24, 2024 at 5:08 AM
    bfunke
    bfunke Tundra Curmudgeon
    If you want to save money can replace the bearings in you old ones.
  4. Aug 24, 2024 at 5:53 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Gates is also a great brand for belts and pulleys.
