2022+ 3.4TT Engine Recall statistics
Discussion in '3rd Gen Tundras (2022+)' started by Wtundra2023, Aug 21, 2024.
  1. Aug 21, 2024 at 6:54 AM
    Wtundra2023
    Wtundra2023 [OP] Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    I recently purchased a 2023 Tundra Limited with a build date of 5/23 putting it outside the recall window. Looking into all the information and posts on this forum, it appears a failure is still possible but am unable to get a sense of how probable it is.
    I have looked at the google doc provided on this forum and the threads concerning this and wanted to know if anyone has compiled any recent statistics on the number of failures across the build dates after the end of the recall and the overall % or ppm of engines affected from 2022. I would do it myself and I would likely get it wrong (I was horrible at stats in college) and was hoping someone in this forum with better knowledge and skills may have the numbers at hand.
  2. Aug 21, 2024 at 6:56 AM
    Breathing Borla
    AZ
    just drive your truck man and don't worry about it
    there is enough speculation to read here for the next 30 years and its all meaningless.
    toyota is NOT going to release any true data.
    boost on:burnrubber:
  3. Aug 21, 2024 at 7:09 AM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    All we really know is that anything built has the potential to fail. That's just life. If you buy Toyota's recall reasoning and believe it was worked out around 2/2023, then anything after should just have a regular "acceptable" failure rate. Those in the recall are certainly more likely to fail, and at this point may be more when than if. We've speculated on this for so long that even with Toyota stating a "safe" date, we still get itchy after hearing newer builds fail, even though some will always fail no matter what and may not be a related root cause. We roll the dice on everything we do in life.
    Before the internet you wouldn't even know it was a concern worth thinking about before getting a letter in the mail. Here we were concerned about a year before the recall.
  4. Aug 21, 2024 at 7:21 AM
    Wtundra2023
    You're not wrong. The age of information that we live in makes it easy to get a bad impression. In the past, the current level of communication from Toyota would have been acceptable. Today, the level of communication seems sub par simply due to how easy it its to research and get data (both bad and good). Its also easy for a few to skew the perceived data one direction or another by being "louder" than the rest. All that makes creating an informed position rather hard.
    I appreciate the responses already given, I still am interested in the numbers of anyone has something. I think those would add perspective. If not, then I will "Boost On".
  5. Aug 21, 2024 at 7:21 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Couple things...shouldve done/asked this before buying if it was something it would deter you from buying. Second, at what failure rate would it make you want to jump ship? Youre already in it, you already know its very possible that you could blow the engine, might as well just drive it and let it do its thing. Hopefully you bought an extended warranty because there is no % of probability @ XX,XXX miles...its a crap shoot.
    75tranzam likes this.
  6. Aug 21, 2024 at 7:31 AM
    Wtundra2023
    I purposely waited until the recall was announced and found a vehicle outside of the recall window. Reports of failures outside that window are concerning and a overall impression of the bell curve from the resulting numbers showing the ppm of failures does help assuage those concerns. I have the option to purchase an extended warranty and am considering it but haven't pulled the trigger yet. I may sometime in the near future as the truck has 6k miles on it and almost 2 years of warranty left.
    In the in end was I aware of what i was getting into, yes. Did I still purchase one, yes. Does the failure probability interest/concern me, yes. You make that investment, you'd be a fool not to be prepared and get a greater understanding both before and after purchase.
    Look at me justifying myself to someone on the Internet for asking a question, I'll stop now...
  7. Aug 21, 2024 at 7:39 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    I canceled my extended warranty. If mine does blow, in or out of warranty, I believe Toyota will cover it. Why pay for the warranty.
    To answer the OPs pondering, the google doc is locked down, only the owner has access to compile. There is a little data there- 83 22’s, 17 23’s and 3 24’s. But lacking the most important datapoint imo… date of failure.
    Stats can be spun a million ways though, even with accurate data.
    Wtundra2023[OP] and Jaypown like this.
  8. Aug 21, 2024 at 7:39 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Even if you did compile the numbers to a spreadsheet, it wouldn't be conclusive data. Failures keep happening and they will continue to keep happening until every engine covered by the recall is replaced.
    I am a data person and like to see this stuff but it's also not going to change much for you other than just the "know". But I agree, it's nice to see data even if it doesn't change the present.
    The only data that will truly paint a picture of % or PPM will be IF Toyota shares that information as it keeps changing.
    In the meantime, keep driving and enjoying your truck.
  9. Aug 21, 2024 at 8:24 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    No one has any data. If you’re looking for a MTBF type calc or 5 9’s burn down you’re not going to get it
    I’m the same build month. Just drive and enjoy your truck.
  10. Aug 21, 2024 at 8:55 AM
    Wtundra2023
    Again thanks for all the responses, time to let it go and just drive it.
    Rcflyersd and oddhours like this.
  11. Aug 21, 2024 at 10:29 AM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    Still have my college statistics textbook, "How to Lie with Statistics", professor spent a lot of his lectures explaining how statistics can be spun to "prove" whatever it was that you wanted to prove.
    Lee.M, Tunrod and Tundrastruck91 like this.
  12. Aug 21, 2024 at 10:31 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Pharma is #1 in this with skewed BS and the lawsuits prove it.
    22whatwedo and NateMob like this.
  13. Aug 22, 2024 at 9:58 AM
    Tom976
    Tom976 New Member
    Tom
    The engine recall is one thing... I have a 2023 (build date is 2/10/2023 and toyota doesnt list my ride as part of the recall)
    That being said by front active airdam recently died. Gave me a lovely message on the dash about it.
    Brought it to the dealer and they diagnosed the motor in it failed. How much just for the motor? $850
    Luckily I am under factory warranty. I've got the extended warranty too and aside from the engine.. every other part in this truck is expensive too! 2k for 120k miles and 10 years with zero deductible. One or two trips to the dealer will easily cover the cost of the warranty.
    Tunrod likes this.
  14. Aug 22, 2024 at 10:20 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That's why I like to have the raw data and then work with it myself. Output is only as good as what the input is.
  15. Aug 22, 2024 at 12:11 PM
    MaineTundy
    Yep, good points, especially with the tech. I gambled that things like your airdam motor would go during factory warranty.
  16. Aug 22, 2024 at 12:48 PM
    Wtundra2023
    I may end up with an extended warranty if the powertrain warranty won't cover the engine in the event of a failure (I need to look into it a bit). At the very least the extended warranty would cover many of the electronics that may fail. I have a good bit of time before I need to make up my mind so I can at least research it a bit more and I can also wait out the recall a bit to see if they expand it.
  17. Aug 22, 2024 at 5:42 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    I thought all 2023’s are on the recall except the hybrid models. Is yours a hybrid?
  18. Aug 22, 2024 at 6:07 PM
    Wtundra2023
    It's not a hybrid. Only the 2023's with a February build date and before are under recall. Mine was built 5/23.
  19. Aug 22, 2024 at 6:10 PM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    2/23 build date and not in the recall.
    Soupbean77 likes this.
  20. Aug 22, 2024 at 6:33 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Another thread of "I'm gonna die and want to know when." Just drive it. Get an extended 10 yr warranty with zero deductible and stop worrying. If you still own it in 10 years and it has not shit the bed you won, and if
    it shit the bed your warranty will make a whole lot less remorseful about the initial purchase and getting a warranty. Enjoy the truck, it's still better than any competitors option. 5/23 build date here with Platinum zero deductible extended warranty coming before 3yr/mileage service date to cover the unknown (look for the thread and do it).
    Tundrastruck91 likes this.
  21. Aug 22, 2024 at 6:50 PM
    Wtundra2023
    Help me out on the premium warranty. When I search for the warranty options on Toyota's website, I get the options of Powertrain, Gold, and Platinum but no premium. The only one that offers 10 years is the Platinum. Is this the one you are referring to?
    And yes, the other options for a 1/2ton are not as good, its cold comfort.
  22. Aug 22, 2024 at 7:03 PM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    He is referring to the platinum warranty. That is the top warranty that Toyota offers.
    303Gen3 likes this.
  23. Aug 22, 2024 at 8:03 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    I thought that the cut off date was 3-24 and not on 2-23
  24. Aug 23, 2024 at 4:33 AM
    Wtundra2023
    Just checked my VIN again to see if there are any open recalls against it, currently there are none.
  25. Aug 23, 2024 at 5:11 AM
    MaineTundy
    All filed on NHTSA.
  26. Aug 23, 2024 at 6:48 AM
    303Gen3
    Golden Colorado
    Platinum Zero deductible is what I meant to say. I'd not bother with the Toyota Web or Dealer to secure this product - There are a few mentions in the Extended Warranty Thread that provide contact information - No pressure, no fluff, no overcharging like the Dealer tries to pull on you at purchase. GL and drive on!
  27. Aug 23, 2024 at 6:41 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    This is the guy you want to call for extended warranty’s. My 24 SR5 4x4 5/24 buildIMG_0322.png is only 3/36K. I’m debating on calling this guy.
    Wtundra2023[OP] likes this.
  28. Aug 23, 2024 at 7:15 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    And yet another reworded thread about engine failure. This will never end,,,,,,, until they reach 102,000 trucks!
    It is virtually an impossible task to figure out numbers without having ALL and I mean ALL data collected going thru one point.
    Toyota says it could affect 102,000 vehicles so until they hit that number everyone is suspect!!! HA!!! :)
    Once they hit that number then everyone can rest!!!!:) Yup that’s the ticket!!!!!:)
    Give or take a few thousand????:)
  29. Aug 23, 2024 at 7:25 PM
    Wtundra2023
    Says the guy who drives a doge....lol
  30. Aug 23, 2024 at 7:53 PM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    Ram! trust me there is a difference
