2010 tundra transmission full fluid filter change
Discussion in '2nd Gen Tundras (2007-2013)' started by Filo, Dec 12, 2023.
  1. Dec 12, 2023 at 12:34 PM
    Filo
    Filo [OP] New Member
    2007 Tundra 5.7
    Is worth to change the fluid and filter on a tundra with 150k miles? Toyota wants $530 here in ks
  2. Dec 12, 2023 at 12:51 PM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    Don't drop the pan for the filter change, more than likely to break more than half of the bolts. I broke 9 of the 12.
    Drain and fill x3 to get most of the old fluid out. Then drain and fill every 30k or so, more if you are actually using the Tundra as a truck.
    Zebruaj likes this.
  3. Dec 12, 2023 at 12:59 PM
    turk
    turk New Member
    greg
    millersville pa
    2011 platinum
    i had my 2011 crewmax changed at 150k by a shop that has been doing transmissions for 50 plus yrs. black as hell broke 5 bolts off bit only had to put a helix coil in one of them. i had it flushed because it was so dirty. runs great i had it done 30k later but just drained thats all they recomend. oh i had the filter changed the first time. i am the 3 rd owener of this truck and love it. the cost was 300 for the whole job.
  4. Dec 12, 2023 at 6:06 PM
    Filo
    2007 Tundra 5.7
    Well if they brake the bolt i will get charged?
  5. Dec 15, 2023 at 7:32 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Don’t mess with dropping the pan to change out the filter it’s unneeded and a risk to break bolts. With older transmissions it’s a good idea to do a drain and fill ( about 4 qts) every 50-60k miles. You don’t want to get the fluid too clean as the internals of the transmission wears the tolerances increase the “stuff” in the fluid will help the clutch’s in good working order. It is possible that the transmission will start to slip if you remove too much
  6. Dec 16, 2023 at 5:13 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    +1 on not dropping the pan. I only broke 2 bolts but there is just a strainer inside. If it gets stopped up you have more issues than changing fluid would fix.
  7. Dec 16, 2023 at 8:34 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Drain pan. Pump in same amount as drained through cooler return line or fill port. Then Pump out a gallon at a time from the transmission cooler line (cooler thermostat pinned open) by starting and running the truck. 1 gal gets pumped out, You pump 1 in through return line. Do this three times and then perform the level check procedure. This will essentially replace all of the fluid with little mess. Took me about a 1.5 hrs first try. The filter is a screen, so likely no need to change.
  8. Dec 17, 2023 at 4:24 AM
    hinds90
    hinds90 New Member
    Just recently did mine. I hit what I could of the threads on the nuts with pb blaster a couple of day before. The day I did it I test broke loose every nut right after getting home from work while everything was still hot and no broken nuts.
    My truck spent it's life in the south though and nuts looked to be in good shape with only one having a little surface rust.
    Simply put if you think the nuts look okay test them out while it's hot and drop pan to change filter. You want to keep the fluid as clean as you can. Could avoid a valvebody or solenoids issue down the line.
    You can also get more ATF out by bropping the pan. I got about 7qts out of mine dropping pan, changing filter, and and letting it drain over night.
  9. Dec 17, 2023 at 4:27 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Drain/fill, life is good.
  10. Dec 22, 2023 at 8:33 PM
    Filo
    2007 Tundra 5.7
    Did the gasket and filter at Toyota they broke 3 bolts, had “ a warmer hose leaking “ total damage $980.
    I still have a leak i think is the cooler housing or warmer maybe, has anyone had the same leak?
  11. Dec 27, 2023 at 12:49 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    To those saying "don't get the fluid to clean" that is just terrible advice and the logic is from 30 years ago. Stop!
    Fluid technology isn't what it was circa 1950 to 1990 when fluid would varnish creating a physical buildup around moving and reciprocating parts. And ya, ATF is extremely high in detergent and fresh ATF could *back in the day* rinse the varnish away making internal leaks, and yes, fresh fluid could take an old transmission out of service. But those rules no longer apply to WS fluids of today...
    PS if your truck is from the rust belt, soak the bolts with with your favorite product starting a week before you plan to drop the pan. Do it at lesst twice and drive it. It works magic.
    IMO - drop the pan and filter to get the most fluid out possible. From my days at AAMCO Transmission, they are rebuilt/assembled with ATF. You fill the pan with 3 to 4 quarts and fire them up, and start filling ASAP.
    Point - ATF will do its job keeping the reciprocating parts lubricated once it's started but not fully filled and that starting the engine with an empty pan is not going to harm the trans for the 5 seconds it's running. What it will do (with the filter off) is get another 1 to 2 quarts of oil out getting more than half the fluid out of the pan which means more new fluid can be pumped in.
    If you have the tow package, don't forget to push the bypass valve in and pin it when checking the level.
    Cheers
  12. Jan 19, 2024 at 10:50 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    I kept getting conflicting temperature ranges for when to check the trans fluid. Each Youtube video or service recommendation had different temperature ranges for when to open the overflow port and when to plug the port and let the fluid cool before checking.
    I opened each of the attachments that Brums provided above.
    Here are the temperatures in Fahrenheit for each transmission type.
    TIS shows 5 different code transmissions for 2012:
    A750E - 97 - 115
    A760E - 127 - 138
    A760F - 127 - 138
    AB60E - 99 - 111
    AB60F - 99 - 111
    You can find the code for which transmission is in your truck of the inside of the driver's door. It is in the lower left corner of the sticker.
  13. Aug 23, 2024 at 9:12 AM
    2010SR5NIC
    2010SR5NIC New Member
    2010 Salsa red pearl DC
    Dobinson lift front and rear, SPC UCA’S, icon add a leaf, coach builder shackles, 18x8 method wheels with 295/75 falken wildpeaks.
    What fluid is everyone using for transmission? Since it holds 11 quarts is it okay to mix fluids? Idk what’s in mine so if I drain 4 quarts can I add 4 quarts of whatever I want into it?
  14. Aug 23, 2024 at 11:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    In a pinch you could since they are supposed to be "WS" compatible. I'm in the camp of only using Toyota WS in the transmission but will use Idemitsu or AISIN WS fluid too if Toyota is unavailable.
  15. Aug 23, 2024 at 11:57 AM
    2010SR5NIC
    so should I dump and fill every 500 miles like 3 times of that so I know it’s got good oil in it?
  16. Aug 23, 2024 at 2:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    From the different threads seems like some do a partial pan drain/fill and it does fine. I do a complete drain and fill when it's time.
  17. Aug 23, 2024 at 5:10 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    That's what I had done for my 2013 Tundra 5.7L by the shop this year (drain and fill) at the 91,000-mile. I don't know it is my imagination, but the transmission shifting is quite smooth now (feels strong without any hiccups). Since I don't drive it very much I will have the same work done again a couple of years from now.
    Mdl[QUOTED] likes this.
