Anzo Headlights Taillights
Discussion in '3rd Gen Tundras (2022+)' started by Churchill1001, Aug 22, 2024.
  1. Aug 22, 2024 at 11:56 AM
    Churchill1001
    Churchill1001 [OP] New Member
    Patrick
    2022 SR5 T-SS 4X4
    275 60 20 Falken Wildpeak AT3W, JBL 10" subwoofer, switchback LED turn signals front
  2. Aug 22, 2024 at 12:30 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Looks good. Are the headlights noticeably brighter?
    ps I can read you plate in the other thread with killer pictures
  3. Aug 22, 2024 at 12:46 PM
    Churchill1001
    Patrick
    2022 SR5 T-SS 4X4
    The new headlights are not as bright as factory, which was a bit of a disappointment. The light they put out is decent, just not quite as good as the ones it came with. They do still adjust with the controls inside and that is helpful when it has a heavy load. The Anzo lights have a more defined line at the edge of the beam instead of dispersing the light. I noticed that about plates soon after and fixed images - thank you!
    MaineTundy likes this.
  4. Aug 23, 2024 at 6:36 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Have you seen the morimoto evo+ lights for the 4Runner? Apparently they are working on a set for the tundra… output looks unreal. Heated headlights, can change the drl color and indicators between sequential or fade. They need to make all their products for tundra!
  5. Aug 23, 2024 at 12:41 PM
    Churchill1001
    Patrick
    2022 SR5 T-SS 4X4
    The tail lights were a breeze to install in just minutes, but the headlights and turbo vents took half a day to finish because the bumper and grill has to be removed. I had not seen the Morimoto lights for the 4runner and they look nice! The Anzos have dynamic/sequential amber lights and the DRLs can be amber or white. I like that the Anzo DRLs are angular and have the same aesthetic as the stock fog lamps, so they look cohesive.20240415_224408.jpg
