Weird Click - Steering Wheel
Discussion in '2nd Gen Tundras (2007-2013)' started by JeffraKing, Aug 21, 2024.
  1. Aug 21, 2024 at 9:02 PM
    JeffraKing
    JeffraKing [OP] New Member
    Jeff
    2008 Tundra SR5 TRD Offroad - 5.7L
    None that I know of
    Hi all, 08 Tundra SR5 Double Cab with the 5.7L. 150k on it.
    Weird problem. Randomly I get what sounds and feels like a plastic sounding click in the steering wheel. I don't think it's binding the wheel but I can feel it and hear it.. Happens going down the highway while just normally staying in the lane, turning sometimes as well. I can't make it happen, it just does it randomly. Really noticed it while pulling my small camping trailer (15' T@B 320s) but that may just be because it requires a bit more slight wheel turining to keep it straight. I lowered the wheel a little and that seems to have lowered the number of noticeable instances.
    Any thoughts?
  2. Aug 22, 2024 at 6:37 AM
    koditten
    Kirk
    Midland of the Mitten
    Does the horn work?
    If not, the ribbon cable could be the issue.
    Another cause could be a failing turn signal assembly.
    Just like you, I'm just tossing darts.
    Please report back if you figure it out.
  3. Aug 22, 2024 at 8:21 AM
    JeffraKing
    Jeff
    None that I know of
    Horn works, no airbag light and cruise control works. A few people on Facebook and other areas still seem to think it's the clock spring. Seems like a simple enough replacement, I might throw that dart and see if I get a bullseye.
    Turn signal assembly is an interesting suggestion. I will definitely look into that.
