    0 vote(s)
    0.0%
  2. Yes - roll/swipe on
    10 vote(s)
    100.0%
  3. Yes - areosol
    0 vote(s)
    0.0%
  1. Aug 21, 2024 at 11:46 PM
    18" TRD Off Road Wheels
    Is yours still intact, or did you delete the DEF? Will you have that option with a "commercial" truck?
    OldGuy03 and T-Rex266 like this.
  2. Aug 21, 2024 at 11:51 PM
    My truck emissions will always be as it came from the factory. No deletes for this guy. If you drive these trucks as designed you mitigate most problems.
  3. Aug 21, 2024 at 11:53 PM
    Oh! I thought you had deleted it? Maybe I'm mixing up a convo we had about deleting the AFM on the gassers? It all blurs together on night shifts. LOL
    Blue Thunder, OldGuy03 and T-Rex266 like this.
  4. Aug 21, 2024 at 11:55 PM
    Outbound
    Aaron
    Northern Alberta
    OldGuy03, T-Rex266, NWPirate and 4 others like this.
  5. Aug 21, 2024 at 11:57 PM
    I'm short too. I think I might be your same height, or an inch taller? Depends on if you're height is in your torso or your legs. Mine is legs, so I don't have my seat real close. Could be a slight difference all these years later from what yours was as well. Unless you still have the problem with the '21 you drive? IDK how similar the interiors are.
    OldGuy03, T-Rex266 and Tripleconpanna like this.
  6. Aug 21, 2024 at 11:58 PM
    Maybe. I am tuned on the ECM/TCM but that actually improves my exhaust regen mileage as long as I drive reasonable. Yesterday I went 730 miles between regens when factory it was usually 4-425 miles. I have done 810 miles where it force regens regardless of exhaust soot level.
  7. Aug 22, 2024 at 12:10 AM
    And the regen is a DEF dump to super heat everything and burn it clean, right?
    Perhaps the tune is what I confused with a DEF delete. IDK. My brain does weird shit.
  8. Aug 22, 2024 at 12:26 AM
    A regen injects diesel fuel into the exhaust, raises temps and burns all the soot buildup into ash. Then the ash is blown out of the exhaust. DEF is always being injected when the truck is running. A complete regen takes about 1-1.5 gallons of diesel fuel. This is why increasing regen mileage is important. Passive regens is the key.
    You may have seen it from a diesel truck and thought the head gasket is blown due to the white ash being dumped out.
  9. Aug 22, 2024 at 12:31 AM
    Ah, ok. I thought the DEF was what was used for it. I knew it was trickled through out use. Never messed with a DEF pickup, but the large rolldeck I drove had DEF. With the fuel capacity they have I never noticed a regen cycle beyond the notice on the dash. Easy to ignore it when you aren't buying the fuel. :D
  10. Aug 22, 2024 at 1:08 AM
    LOL. Tell me about it. I filled up in ND yesterday with 47.5 gallons. 175.00.
  11. Aug 22, 2024 at 1:14 AM
    Oof. Definitely hurts. That's one thing I'll miss about the Taco. Smaller tank meant my brain didn't flinch because the fill ups were never triple digits. Now that I have a 36 gallon I try to fill up before a half a tank to make it seem let costly.
    Though, the Taco didn't really get any better mileage than the Ferd, so I'm still coming out ahead or even I guess.
  12. Aug 22, 2024 at 2:04 AM
    It's just a mind trick. I personally don't focus on fuel economy much. I drive, it uses fuel, I fill. My Mom is with me and she just loves taking the Dmax. After I put on the King Shocks, she loves it even more. Normally she can't take long trips without a lot of pain. In this truck, not even a problem.
    She is gonna be mind blown on the next interior and seat options.
  13. Aug 22, 2024 at 2:13 AM
    Oh? What are you planning for it?
    T-Rex266 likes this.
  14. Aug 22, 2024 at 2:22 AM
    New truck will have even nicer seats. Been looking at High Country trim packages.
  15. Aug 22, 2024 at 2:26 AM
    Ooooh, I thought you were upgrading the interior of the current truck. My bad.
  16. Aug 22, 2024 at 2:56 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    They do reactor catalyst changeouts under inert atmospheres.
  17. Aug 22, 2024 at 2:58 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    As long as you're not paying for fuel. :D
    OldGuy03, T-Rex266 and GODZILLA like this.
  18. Aug 22, 2024 at 3:50 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Can some of y'all more worldly folks explain to me why young folks get giant arm/neck/visible tattoos and then try to enter the corporate world?
    and speak in such a way that you are easily understood.
    see, when I draw the Venn diagram of smart/valuable folks & tattooed folks, those circles barely, if at all, intersect.
    and if you are one of those tattooed folks...I don't need you to defend it....I need you to explain it.
  19. Aug 22, 2024 at 4:06 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    My wife has two full sleeves and works in the corporate world, it's never once been an issue for her, but she can completely cover them up with a long sleeve shirt and nobody can tell she has anything. The why is because she wants them, simple as that. What I think you're referring to is the latest Gen Z getting random small, very cheaply done tattoos all over sporadically, which I think is something completely different. They why for that is the same reason that the younger generation eats tide pods and snorts condoms, they think it's cool and will get then credit with their friends, simple as that. Honestly, i blame Tik Tok, it encourages more and more extreme behavior for likes and comments, which leads us to young 20's kids with neck tattoos. I try not to be that grumpy old guy (I'm only 30) looking down at the younger generation, but man it's hard at times.
    Beach Toy, OldGuy03, kirkb and 2 others like this.
  20. Aug 22, 2024 at 4:45 AM
    I disagree with this. Plenty of smart and valuable people get tattoos. Look at military, first responders, security oriented individuals, etc. and there's no shortage of some type of ink. Now, are they often getting neck and face tats or doing extreme piercings that make it look like they lost a fight with an automatic stapler? Probably not.
    As for an explanation of why the "kids" are doing it these days.... attention. Going back to previous discussions in this thread, parenting has been shit for a couple generations. Impulse control is a dirty word. Earning something is a foreign concept. Everybody is special and has value, even useless asses. They grew up without ever facing consequences, learning to think for themselves, or hearing that the world doesn't owe you shit. That's why they do it. The can't differentiate feelings from logic/reality so they can't wrap their head around why it would be a bad idea. They're special and have value, haven't you heard?
    Beach Toy, OldGuy03, NWPirate and 4 others like this.
  21. Aug 22, 2024 at 5:07 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Ford’s version of “kinks worked out” still means owners don’t go past 100-120k miles.
  22. Aug 22, 2024 at 5:09 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I got my 100k mile club Toyota sticker yesterday!!
    only took a week.
    now working on the 200k sticker.
    sbxx312, OldGuy03, NWPirate and 5 others like this.
  23. Aug 22, 2024 at 5:10 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    sbxx312, NWPirate, 1794TX and 3 others like this.
  24. Aug 22, 2024 at 5:15 AM
    Terndrerrr
    Music City
    6UR-FE
    The simplest explanation: it is generational. The correlation of low socioeconomic status and tattoos decreases every generation and is now all but gone. It’s not just for military, ne’er-do-wells, drunks making a rash but permanent decision, and gang members anymore.
    Edit to add: the quality and appearance of tattoo work has also increased dramatically.
    This is probably not a shock given where I live, but 100% of the highest net worth people I know have tattoos. Not just friends in the music biz; finance and medicine as well.
  25. Aug 22, 2024 at 5:15 AM
    Plenty of 200K 5.0 Liters out there.
    nobodyintexas and T-Rex266 like this.
  26. Aug 22, 2024 at 5:46 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm not sure I understand why someone would need to spend the majority of their adult life trying to lift a house and be forced to wear abnormally sized clothing... and then enter the corporate world thinking they look and act like the rest of us ;)
  27. Aug 22, 2024 at 5:49 AM
    I have a full sleeve on one arm, and a flag on the other…never been an issue.
    GODZILLA, OldGuy03, NWPirate and 2 others like this.
  28. Aug 22, 2024 at 5:50 AM
    Tripleconpanna
    What about shaving your legs; that's freakin' weird too, right??? :D
    GODZILLA, OldGuy03, NWPirate and 3 others like this.
  29. Aug 22, 2024 at 6:09 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Couldn't agree more. Say I own a business, and I have one goal in mind: make as much money as I can. How would I best accomplish that goal? Hire the best people for any given position, regardless of appearance.
  30. Aug 22, 2024 at 6:10 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    ok.
    poor comparison.
    We do it for health. the human body is an adaptation machine. it beautifully adapts to whatever stresses placed upon it.
    we become exceptional. more capable. and are generally happier.
    I get the "do whatever makes you happy" thing. and I am tolerant.
    I'll continue my quandary...I'm not judging - I'm just inquisitive
    so, is it just decoration? or, generally, does it mean something. EX; I got this because I like new zealand tribes.
