Changed my brake fluid today
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joe333x, Aug 9, 2024.
  1. Aug 19, 2024 at 6:17 PM
    #61
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
  2. Aug 21, 2024 at 6:22 AM
    #62
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    the reservoir adapter is from Speedi-Bleed
    https://speedibleed.com/product/c800-toyota-lexus-brake-bleeder-adapter/
    and I also bought the female quick-connect from Speedi-Bleed and attached that to the hose from the Motive tank
    https://speedibleed.com/product/fc02-female-coupler/
    I did have an issue with fluid leaking out of the Speedi-Bleed cap when I tried to transfer fluid from the Motive tank to the reservoir so I don't do that anymore, I just check the fluid level after each caliper and add fluid. With the quick-connect it's very easy and the Motive tank doesn't loose pressure so you don't have to pump it all the way back up again.
    AndyTex and Joe333x[QUOTED][OP] like this.
