  1. Aug 20, 2024 at 6:43 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    If you think it does, then it does. :rofl:
    But from me knowing what my truck sounds like during cold starts and revs, I’m sure there’s a sound difference to my ears.
  2. Aug 20, 2024 at 7:15 PM
    centex
    centex New Member
    Oil change after 7868 miles. Apparently I also rolled over 70k miles 79 miles ago. I don’t even look. Just turn the key and go.
    bulldog93 and grant.ducckk like this.
  3. Aug 20, 2024 at 7:22 PM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    Don't know, haven't driven the truck yet.
  4. Aug 21, 2024 at 4:58 AM
    I just watched the videos on their site. Waiting to see your thoughts on it after installation and driving.
    pvn.beluga[QUOTED] likes this.
  5. Aug 21, 2024 at 5:31 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    After watching those videos too, I think it’s valid that a cooler IAT will result in somewhat of an increase performance. Considering you’re in FL too George, might be worth a shot!
    The install also looks simple! After taking my air box out yesterday, I noticed one of the threads that the Stillen box uses that was a bit rusted. Luckily I was able to use some PB Blaster and screw on the bolt for the air box to clear out the debris. Feeling pretty smooth now for the most part. May spray PB blaster while I’m doing the install to make sure the threads glide.
    bulldog93 likes this.
  6. Aug 21, 2024 at 5:34 AM
    I'm thinking it might be as well. I was just out at the truck moving it and my IAT is 104 degrees and its been sitting for about 2 hours since I got to work.
  7. Aug 21, 2024 at 5:50 AM
    AREDRIG
    AREDRIG New Member
    Luis
    18 tundra double 6.5 barcelona
    Not today but last week. Wednesday installed 1" spacers to make my wheels/tires poke out a lil bit after the extended flare install and Thursday night took it to go see Deadpool & Wolverine at Becky's Drive in 1.5 hours from home. So worth it and we get to finally use our camping zero gravity chairs side by side vs when we tried with my 07 Ridgeline the bed wasnt wide enough. We can now sit side by side comfortable in the much better wider Tundra dc 6.5 bed. Also check out the swivel ladder gf loves it! No more using the tire step to get back in
    Tundra-XP, OHwendTrd, Lassie and 17 others like this.
  8. Aug 21, 2024 at 5:58 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I have the stillen tube on my modded box and can confirm it in fact lowers iat temps significantly
  9. Aug 21, 2024 at 6:15 AM
    centex
    centex New Member
    At idle or low speed I’ve seen 140* IAT with the stock box. Anything above 30mph I’m 3-5* above ambient. $400 to maybe drop that to ambient and maybe pick up 1-2hp just ain’t worth it.
  10. Aug 21, 2024 at 6:59 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Finally found a source to run a full spool in the rear end. Will be ordering that soon. New 4.0x18s, king bumps and bedcage ordered. Hopefully here by the end of Sept depending on kings lead time.
    Abell207, BreyTundy, Cfincke and 4 others like this.
  11. Aug 21, 2024 at 7:08 AM
    FireFinder44
    Albany, OR
    Seems like it does. Charged my Samsung S21 Ultra from 95% to 100% in 2 minutes.
    thedoodab1des likes this.
  12. Aug 21, 2024 at 7:37 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Me too....spacer w/ 295/70R 18's
  13. Aug 21, 2024 at 7:48 AM
    AREDRIG
    AREDRIG New Member
    Luis
    very nice! everyone tells me 1" or any spacer is no bueno on truck. i had xj cherokee with jk wrangler wheels and that was with 2.5" spacers. yea they were fat ones so i was def ok with 1" on Tundra. my s2000 had 1.5" spacers with the widebody and 10.5" wheels but got rid of the wheels for 11" all around so no need for them anymore:militarypress:
  14. Aug 21, 2024 at 9:35 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    do you have a link to the swivel ladder?
    HulkSmurf14 and koditten like this.
  15. Aug 21, 2024 at 9:42 AM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    I did the same switch of the gasket and it made a new horrible noise at all RPM lol
    Any issues on your end?
    My screened one makes a slight noise at low RPM but I live with it
  16. Aug 21, 2024 at 9:44 AM
    JrJrOffroad
    Anthony
    That ladder is rad
    HulkSmurf14 likes this.
  17. Aug 21, 2024 at 9:59 AM
    AREDRIG
    AREDRIG New Member
    Luis
    https://www.amazon.com/gp/product/B09Y1RGF9Y?ie=UTF8
    had to add the rough country shock for weight support so it goes down easy. also bolted most of it on the heavy duty panel in tailgate so its not all on the tailgate itself. no problems with how its holding up but gota go back one day to add the bolt/nuts on the missing holes as seen in pictures. lol
  18. Aug 21, 2024 at 10:05 AM
    Sleeper16plat
    Near Vancouver
  19. Aug 21, 2024 at 10:16 AM
    AZBoatHauler
    So.Arizona
    Did you stop by Lake Como?
    Terndrerrr likes this.
  20. Aug 21, 2024 at 11:16 AM
    AREDRIG
    AREDRIG New Member
    Luis
    not a problem, any questions let me know. i might have some for you later on your suspension details in your signature
    Sleeper16plat[QUOTED] likes this.
  21. Aug 21, 2024 at 11:44 AM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    That ladder is the cat's meow, just ordered one off of Amazon.
  22. Aug 21, 2024 at 1:10 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    So after driving today for some groceries, the throttle response is definitely there. I was on tow/haul mode as well, but it wasn’t as zippy as before without the 2 mods.
    It felt more controlled as I stepped on the gas going through uphill, turns, and on ramps.
    So if anyone is justifying whether or not to do this, I’d definitely say do it.
    Tripleconpanna, bulldog93 and reywcms like this.
  23. Aug 21, 2024 at 2:19 PM
    This is gonna be you :boink:
    https://americasbestpics.com/video/1Eal0ushB?s=cl
  24. Aug 21, 2024 at 2:56 PM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
  25. Aug 21, 2024 at 3:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Tundra234[QUOTED] likes this.
  26. Aug 21, 2024 at 4:14 PM
    JrJrOffroad
    Anthony
    I always make fun of the ford's little step up system but honestly I need a better way to get into the truck bed lol I might look at these
    Fobroader and Tripleconpanna like this.
  27. Aug 21, 2024 at 4:28 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Legit!!
    Rgross2112 and JrJrOffroad like this.
  28. Aug 21, 2024 at 5:27 PM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    Got front camera installed. Cheap Amazon Wifi camera that I see the image on my phone. So convenient. Why didn't I do this earlier. LOL
  29. Aug 21, 2024 at 5:28 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Took advantage of some of the 25% off Toyota parts with free shipping and upgraded the A/C blower motor to 87103-60560 from the Land Cruiser.
    Key differences being brushless motor, quieter, more linear in adjustment, and more powerful airflow.
    Parts look slightly different - Land Cruiser on left, Tundra on right. Wiring plugs right up and mounting locations fit with no issues. Great plug-and-play solution.
  30. Aug 21, 2024 at 5:34 PM
    VUDUBLU
    VUDUBLU New Member
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Replaced mine about 3 months ago. Wish I would have thought about the upgrade before I swapped for same one.
