  1. Aug 20, 2024 at 11:46 AM
    Pretty aggressive for an AT. Has that "BFG" sidewall lug design
    BroHon[QUOTED] likes this.
  2. Aug 20, 2024 at 11:47 AM
    Will be ordering in the next couple weeks. Gotta get the new camper and get the 2019 sold.
    bmf4069 and FrenchToasty like this.
  3. Aug 20, 2024 at 12:39 PM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    I must have missed the post where the truck sale fell through :cool: bummer
    EDIT: I think I confused that with the BIG camper, my bad.
  4. Aug 20, 2024 at 1:11 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Negative it's the factory ground for the head unit and 6 discharge changer that was an option for these trucks
  5. Aug 20, 2024 at 1:13 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    IMG_3466.jpg IMG_3470.jpg IMG_3469.jpg IMG_0164.jpg I got everything installed! It only took about a year to find and buy the right truck and accumulate all the parts. Almost everything I bought was after careful consultation with this group I can’t thank all you first gen experts enough. I’m thinking about starting a build/VSC brake system support thread for future owners to reference that will have all my measurements and specs. SPC UCAs, 6112’s at c-clip 6/4, new OEM LBJs and LCAs with new OEM cam, 255/85r16 Toyo MT E-load tires at 41psi, power steering fluid flush, soon to be brake fluid flush with Bosch 5.1, replaced tailgate, LED head/fog/interior lights, greased driveshaft and extended sway bar links. The horrible grinding noise I had after installing my pad/rotors was the junkyard dust cover after all and not the break-in period noise, thanks for the tip shifty. I can’t recommend enough these EBC slotted rotors and Extra Duty + truck pads designed for large heavy tires. I brake faster and smoother than I ever did with stock P tires and oem rotor/pads. I have 5160 rear shocks on back order and still need to change the fluid in front diff, transfer case, transmission, and rear diff with a breather valve relocation. Because I have an auto LSD that isn’t a real limited slip (just automated braking) I will be looking into a selectable locker and maybe re-gear to get back to stock ratios with these 33’s. Thanks again for everyone’s advice the truck handles great and I couldn’t be happier.
    I do have one more question for everyone though, the 5160 rear shocks say they require a 1-1.5” lift (is this confirmed?) but I have perfectly good leaf springs and think the rear height is fine. I was going to go with ATS hd leafs but don’t need the extra stiffness. Any suggestion on how to get the 5160’s mounted cheaply while changing the rear ride quality as little as possible? Thanks
  6. Aug 20, 2024 at 1:16 PM
    VR6T
    For all you other tundra guys here I found this at San Antonio Wrench a Part today. It's in really good condition. Full bench in an 06 RC LB V6 work truck
    If anyone wants it, lmk I'm sure we can work something out.
  7. Aug 20, 2024 at 1:51 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    That looks really nice.
    Your LBJ dust boot looks funky to me. Like the bolts aren't threaded through it. I may have missed something in the discussion leading up to your work though.
    Nice looking tires. I had to run them through the tire size comparison to see what they were. 33 skinnies! Same width as my tires but a couple inches taller. I've got 255 70 16. Those look great on your truck.
    oscardog86 and Bed Tundy[QUOTED] like this.
  8. Aug 20, 2024 at 2:25 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Thanks, the LBJ dust protector really doesn’t do much. Maybe I did something wrong on install, like the LBJ bolts go inside the rubber? We also have different year LBJs. Or are you talking about my dented up hub dust cap that I just smeared sealant on because I didn’t want to buy a new one?
  9. Aug 20, 2024 at 2:49 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't worry @VR6T , he didn't take all of my wood. He might've been able to handle it all, if we had upgraded his rear. But alas, dat ass is saggy. :thumbsup:
    bmf4069 likes this.
  10. Aug 20, 2024 at 2:52 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i'm gonna share. Aint no way i can use all the pecan for smoking.
  11. Aug 20, 2024 at 3:18 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    IMG_3472.jpg IMG_3473.jpgDirty DOT 3 fluid or fresh Bosch 5.1? First time changing fluid since owning
  12. Aug 20, 2024 at 3:24 PM
    had an offer and a date and time setup for the sale. Spoke on the phone, previous Tacoma owner, loves Toyotas. Then, the Buyer vanished. It was not to be.
  13. Aug 20, 2024 at 3:25 PM
    MT-Tundra
    Montana
    Bolts thread through the dust cover.
    Yours
    Mine
    I agree it doesn't do much, so you're likely fine.
  14. Aug 20, 2024 at 3:28 PM
    I think if you’re driving through fields with stobs sticking up or off road in the woods you could take a stick through the boot and the dust protector may or may not help deflect that. They are not very sturdy rubber, so I doubt they offer much protection. I’ve never had them before, but I put them on this time.
    Bed Tundy likes this.
  15. Aug 20, 2024 at 3:30 PM
    MT-Tundra
    Montana
    Yeah my Tacoma didn't have them and I drove a lot crazier roads with it than I'll drive with the Tundra. I did crazier roads than I'll be able to in the Tundra. Too wide, too long.
    Mine already had them and they were in decent shape, so I reused them. If they had been trashed, I'm not positive I'd have replaced them.
    oscardog86 and Bed Tundy like this.
  16. Aug 20, 2024 at 3:47 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    IMG_3474.jpgBrand new 5.1 left, used unknown brake fluid right. Is it Just full of used 5.1?
    oscardog86, FirstGenVol and BroHon like this.
  17. Aug 20, 2024 at 3:52 PM
    and moisture
  18. Aug 20, 2024 at 3:57 PM
    VR6T
    @Mr.bee needs more leaf springs
    bmf4069, Mr.bee, BroHon and 1 other person like this.
  19. Aug 20, 2024 at 4:04 PM
    VR6T
    Pretty sure when I did mine in 21 it was the first time it had been changed since 2000. Brakes like a champ now. @455h0le_dachshund and his superior bleed methods
  20. Aug 20, 2024 at 4:06 PM
    VR6T
    This guy over here with his boogie dust covers trying to be a Lexus or something...... Dust covers psssssh we die of LBJ failure like men on the forum sir
    oscardog86, JakeJake, bmf4069 and 2 others like this.
  21. Aug 20, 2024 at 4:22 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't give me too much credit. I don't know shit about brakes. Just how to mash em.
  22. Aug 20, 2024 at 4:24 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
  23. Aug 20, 2024 at 5:43 PM
    It's a 2006 thing. Our LBJ are different than yours.
    Woohoo! I got something right for a change! :rofl:
    j/k
    Looks good. 6/4 with 6112, did you take before/after measurements up front? It looks very level, I'm shocked to hear you've got stock springs.
    Bed Tundy[QUOTED] likes this.
  24. Aug 20, 2024 at 6:06 PM
    MT-Tundra
    Montana
    Ah, I see it now. That shiny silver screw looked like light coming through a gap between the top of the dust cover and the bottom of the ball joint plate in the first photo. But seeing the closeup, it all makes sense and looks right.
    They do look nice. I only replaced my upper & lower ball joints a few months back, but they've already lost that glossy black look.
  25. Aug 20, 2024 at 6:08 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Some of mine have had a nice Green tint when flushing:anonymous:
    Water=algal bloom, go figure. I thought it was green from metal components in the system.
    Lately I've done it solo with a hose on the bleeder/high looped/then into a jar with some fluid in it. Jar at or above caliper level.
    Been pretty pleased with the results. Push at least a whole quart (big bottle) through the system.
  26. Aug 20, 2024 at 6:36 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Whats the deal with the slip yoke on 2wd'? Grease it, or does it use atf?
    Edit: because of the carrier bearing, the slip yoke doesnt seem to slip for suspension.
    The offset lift (lowering) block bugged someone for some reason, and w/e, i understand its not as supported as possible.
    the black block has the pin/pin hole in line, and is offset. So ordered the lowering kit block, with offset pins/holes, but that doesnt change the overhang on the block. If we move the axle off the original pin, its gonna sit wonky in the wheelwell.
    455h0le_dachshund likes this.
  27. Aug 20, 2024 at 6:47 PM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    oscardog86, bmf4069, Weejub and 3 others like this.
  28. Aug 20, 2024 at 7:24 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    I didn’t get “before” measurements because I already had a spacer lift in the front of unknown height. But whatever height it was, the 6112s at 6/4 seem exactly the same from my eyeball measurements, it just rides so much smoother now. Look how thick the stock springs were compared to the 6112s. I will take measurements tomorrow and post them from top of hub/bottom of hub and where I estimate the center of hub to be. Then measure again in a month or so once it settles. I was distracted with brake flushing today.
    shifty are you saying you’re surprised I went with the springs from the 6112 kit instead of the 700# springs?
    bleeding the brakes with Bosch 5.1 was super easy because of my VSC system. I had a neighbour just press on the brake pedal and hold because the motor would pump the fluid right out no pumping the pedal. I have a huge brake fluid reservoir so I ended up using almost 2 quarts and hitting every corner twice. I did not want to run the res dry so I the first bleed was about 80% new 20% old. I have no rear portioning valve to bleed, and I still have enough fluid left to go lock up the brakes and cycle the fluid in the ABS system on some dirt road and flush the last little bit but I already had 5.1 in it apparently and it was not as bad as I expected. IMG_3476.jpg
    First (R to L) jar was turkey basted from the res, second bottle from all corners, and the last one was really clear from the second round of bleeding to make sure the diluted fluid was pushed out.
  29. Aug 20, 2024 at 7:47 PM
    Nope. I meant if it’s level I’d be shocked if you have stock LEAF springs out back. Guess the word leaf is important! My bad. Or maybe you have a block out back?
  30. Aug 20, 2024 at 8:19 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    @Bed Tundy What springs are those that you have with the 6112s? Are they 650#? Looking at suppliers, some seem to not even mention any spring spec, which I must admit is a little dismaying.
