Which OBD2 Module to pick?
Discussion in '2.5 Gen Tundras (2014-2021)' started by JohnWhicker, Aug 20, 2024.
  1. Aug 20, 2024 at 6:13 AM
    JohnWhicker
    JohnWhicker [OP] New Member
    I plan to use OBD Fusion for basic monitoring and I need to make a decision on which hardware OBD2 module to use. Looks like Veepeak OBDCheck BLE+ and OBDLink MX+ are the best 2 options and I was wondering which one got the most PID's for a Tundra 2021 with a supercharger? Price is not an issue.
    https://www.obdsoftware.net/software/obdfusion
  2. Aug 20, 2024 at 7:16 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  3. Aug 20, 2024 at 7:22 AM
    JohnWhicker
    Thanks you Sir. Do you have good PID's for the supercharger monitoring? I am just looking for basic stuff, the important stuff. I don't like the idea of wiring the ScanGauge 3 so this looks like a good option.
  4. Aug 20, 2024 at 7:34 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Pic of what I monitor. The trans items you’ll need to enter the pid manually.
  5. Aug 20, 2024 at 7:41 AM
    JohnWhicker
    Nice and thank Sir
    reywcms likes this.
  6. Aug 20, 2024 at 6:57 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I use OBDlink.
    Fairly easy to use and app gives you all the Toyota stuff.
  7. Aug 20, 2024 at 7:07 PM
  8. Aug 21, 2024 at 7:31 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
  9. Aug 21, 2024 at 9:04 AM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
  10. Aug 21, 2024 at 9:25 AM
    Status of lock up / off or on
    Pmac[QUOTED] likes this.
  11. Aug 21, 2024 at 9:32 AM
    Pmac
    Pmac New Member
    Thank you. Turns out there was an update I had not added, did that and found it right away.
    KNABORES[QUOTED] likes this.
  12. Aug 21, 2024 at 10:21 AM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    I've been running the blue ELM adaptor from Amazon for years with no issues. Using the torque pro app and I like it. Have mine set to monitor fuel trims, AFR, coolant temp, IAT etc. Just need to input the pids manually for trans temp stuff.
  13. Aug 21, 2024 at 11:39 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The OBDLink MX+ comes with all the PIDs included like trans temp, gear and status of lock up, no extra cost and they have a great customer service. I do not know if there are specific supercharger PIDs.
    Jefejrs likes this.
  14. Aug 26, 2024 at 6:19 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    When I downloaded the OBDLink app, it didn't show the Veepeak as an option to connect to. Are they not compatible?
  15. Aug 26, 2024 at 10:05 AM
    Joe333x
    Joe333x Member
    Boston
    Not sure but my guess would be you need an OBDlink device to use the OBDlink app.
  16. Aug 26, 2024 at 10:07 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Must be. I didn't realize some apps were exclusive.
  17. Aug 26, 2024 at 10:19 AM
    Joe333x
    Joe333x Member
    Boston
    The OBDlink app includes a lot more PIDs than the free ones, they make their money by selling their adapters since the app is free but a lot easier to use than the ones that require you to add all the PIDs yourself. Worth it in my opinion.
  18. Aug 26, 2024 at 10:34 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Ummmm, the one that lets you watch Netfilx? :rolleyes:
  19. Aug 26, 2024 at 10:56 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I was just about to ask if the obd2 modules will pickup tpms readings and saw your pics.
    Which OBDII module do you have? or is it based on what app is installed on the head unit?
  20. Aug 26, 2024 at 11:02 AM
    SD Surfer
    Bruce
    So Cal
    So you have to get the iDatalink Maestro interface module in order to retain your steering wheel controls, and the Maestro harness taps into the OBD.
    The gauge pack, TPMS, etc. is a function of the Maestro.
    *Sidenote* Just yesterday on a Tundra FB page, someone posted that their '21's TPMS would only display up to 50 PSI, and anything higher just showed dashes. Now I have to air up to 50+ to see if it's a thing.
    purplenova[QUOTED] likes this.
  21. Aug 26, 2024 at 1:52 PM
    Joe333x
    Joe333x Member
    Boston
    Unless you're running E rated tires 44 is max psi so that makes sense since i assume the stock system would give you a too high alert
  22. Aug 26, 2024 at 2:04 PM
    SD Surfer
    Bruce
    So Cal
    The Michelins on my '19 ( Which I thought were OEM, but not sure) are 50 max cold inflation.
    Even at 44 cold, on a hot day 50 miles down the road are gonna' go over 50.
    I shall conduct some science.
  23. Aug 26, 2024 at 2:17 PM
    On my truck I have noticed that the PSI displayed on my Pioneer is off from my SG3 and the dash display.
  24. Aug 27, 2024 at 8:12 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    I have E rated tires and my dash and PID on OBDLink will display pressures over 50#
    SD Surfer[QUOTED] likes this.
  25. Aug 27, 2024 at 10:23 AM
    SD Surfer
    Bruce
    So Cal
    Is it a consistent difference? Like HU always a couple lbs. high for example, or all over the place?
  26. Aug 27, 2024 at 10:45 AM
    I'll look but the headunit always seems to be high consistently.
  27. Aug 27, 2024 at 11:03 AM
    SD Surfer
    Bruce
    So Cal
    I actually kinda' forgot I have that in the gauge cluster, I was thinking it just alarmed if they went low.
    I'll have to compare and see if mine match.
  28. Aug 27, 2024 at 2:34 PM
    SD Surfer
    Bruce
    So Cal
    Just checked at lunch and they're in agreement to 1 lb. of each other.
  29. Aug 29, 2024 at 6:41 AM
    JohnWhicker
  30. Aug 29, 2024 at 7:21 AM
    roughfisher
    JP
    Northern Minnesota
    Your phone should be able to handle multiple simultaneous bluetooth connections. I don't have a wireless carplay dongle on my rig, but I don't see how it would interfere with the OBD module. the plus side is you bought the module that in theory doesn't have the potential to drain your battery so you can just leave it plugged in and forget about it.
