Front end upgrades on 2023 Tundra Limited
Discussion in '3rd Gen Tundras (2022+)' started by jhuseby, Oct 27, 2023.
  1. Oct 27, 2023 at 9:17 AM
    jhuseby
    jhuseby [OP] New Member
    Johannes
    2023 Tundra Limited Lunar Rock
    18" Black Rhino Wheels, 35" Toyo Open Country ATIII, King Shocks
    We recently got a 2023 Limited lunar rock and wanted to delete all the chrome, and install the PRO grill with marker lights, main light bar and also the secondary lower light bar (in amber). I have a friend who has a paint shop and was able to paint the grill surround/moustache to match and then we painted the rear bumper corners black. Getting all the lights dialed in is always the trickiest part for me as I don't have a ton of electrical experience. I connected one of the light bars to a Cali-Raised factory switch. That worked well and light works perfectly. I tapped the marker lights into the fuse panel on the driver's side of the engine. These come on with the ignition. For the third (lower) light bar, I ultimately want to connect those to the fog light circuit. I am having a tough time with this as I don't know if I can tap in to the fuse panels to do this or if I have to get the Canbus that I have seen a few others use. Any suggestions or thoughts are appreciated.8D17F800-D80D-4299-A096-FDC983058F81_1_201_a.jpg
  2. Oct 27, 2023 at 9:40 AM
    Bailey1794
    Bailey1794 New Member
    Houston
    2023 Smoked Mesquite Hybrid 1794 Tundra
    Diode Dynamics Ambassador & Talons Garage Affiliate (See Below for discounts) Use code Bailey for Diode Dynamic free shipping Current Build & Pics Instagram.com/Bailey1794 Discounts & Affiliate links below https://linktr.ee/bailey_1794?fbclid=PAZXh0bgNhZW0CMTEAAaYH-pwfNz76E_oAQekLat2ZdcSY0VrV7a8O3_UxaU15mlBifUGV3lGaU4s_aem_Aamyw5XakyTlp6h_WyGSA8wBSO-cFzK1Z0t3EQBBaXEgDCnQI49fSwGFqQNWOCNd5OxDNGhVrMYRcfs_DEuuCXSy
    I am in the same process as your build. Waiting on delivery of painted parts/grill/markers to do the swap.
    Few questions if you don't mind me asking.
    • Where did you get the marker harness from?
    • How is the DD light bar output? Was leaning on ordering this on BF sales
    • Did you have any pics of the wiring setup for the LB?
    Keep us updated on the Stealth light bar install! Sick build!
  3. Oct 27, 2023 at 10:19 AM
    jhuseby
    Johannes
    I just got the markers from eBay - https://www.ebay.com/itm/234934865560
    I feel like the DD light bar has some good power. Maybe not the same as a Baja Designs, but still really good. Both light bars are Diode Dynamics. I was happy with the install and all the parts they have seem to be high quality. I will send some pics of the wiring for the light bar shortly. There are some really good Youtube videos as well that I have watched, but I'll send some photos later. One of the trickier parts was getting the harness for the switch through the fire wall. It's not that hard, but you really need to push hard to get the fabric insulation underneath the drivers side/steering column out of the way. Once you do that, it's easy. There is one harness that goes to the positive and negative on the battery, one that goes to a relay, and one that goes to a switch. The one thing I still would like to do is tuck the harness that crosses the engine at the back under the cowling as opposed to how I have it now zip tied in place.
    One thing I'll mention to be careful with on the grill install is the grill shutter can easily become detached when you're removing/installing, so make sure it is all connected correctly. There is a bar that helps orient all of the shutters in the same plane. Make sure everything is clipped into place. Also, there are ALOT of screws/fasteners. Make sure to remember where they all go when you put them back on. I had a Gen 2 Tundra where I replaced the grill and it was so much easier, more straight forward.
    Thanks for the message.
  4. Oct 28, 2023 at 9:19 AM
    jhuseby
    Johannes
    OK, here are the pics of the wiring set-up for the light bar. First pic is of the wire going through the small grommet through the firewall to under the drivers side to be wired to the Cali-Raised switch on the left side of the dash with other factory switches.
  5. Oct 28, 2023 at 9:33 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    I would recommend heat shrinking over the connector butts. Also I put my relay under the plastic shroud to hid it, and make it look cleaner. You could make the wiring look quite a bit cleaner, if that matters to you.
    Another thing I did was got the DD duel harness. That way there is only one negative/positive wire to connect to the battery. But also on one switch.
  6. Oct 28, 2023 at 10:35 AM
    jhuseby
    Johannes
    Big thanks! That is a good suggestion for the harness. I didn't see that when I ordered it. I definitely plan to clean up the wiring and put beneath the shrowd. I do have some heat shrink I'll cover up the butt connectors with. Good suggestion as well. Thanks again
  7. Oct 31, 2023 at 12:06 PM
    Bailey1794
    Houston
    Much appreciated!
  8. Oct 31, 2023 at 12:09 PM
    Bailey1794
    Houston
    so from my understanding the duel harness allows you to run 2 light bars under the same switch in conjunction?
  9. Oct 31, 2023 at 2:41 PM
    Ipaddick
    Ipaddick New Member
    Canada
    correct
  10. Oct 31, 2023 at 5:25 PM
    jhuseby
    Johannes
    I created my own dual output harness from the two harnesses that I had and now both light bars are running off the same switch.
  11. Dec 21, 2023 at 9:18 PM
    22black_platinum
    22black_platinum New Member
    Joe
    How did you mount the marker lights? I got a similar set and without a bracket like the OEM TRD ones come with I can’t figure it out and would like to know before I start the swap. Is it just double side tape ?
  12. Dec 22, 2023 at 8:13 AM
    jhuseby
    Johannes
    I actually used epoxy to glue them in place and did an OK job. They're obviously stuck on there now for good and super solid, but might have been able to do a little cleaner with VHB tape. I don't think one needs the bracket as the lights fit pretty nicely in the spots where they are.
  13. Dec 22, 2023 at 12:57 PM
    jdietrich
    jdietrich New Member
    Kansas City, Mo
    2023 Platinum Wind Chill Pearl
    TRD Pro Grille, Diodedynamics light bar & fog lights, Talon Cat guard, RCI Skid, Suntek Paint Protection, Century Topper, Paint match mustache, GG Off-road Re-Locator
    Did a similar set up minus the 2nd (lower light bar). I feel the DD fog lights are the real deal. Made a HUGE difference from OEM and almost do as much lighting as the headlight high beams. The markers, grill, and light bar complete the look and package but fog lights are what surprised me the most. Highly recommended. Can install without taking whole grill off as well. simply remove lower "tundra" trim.
    4lo Toys, jhuseby[OP] and CYBERO24 like this.
  14. Dec 22, 2023 at 2:01 PM
    CYBERO24
    CYBERO24 New Member
    East Coast
    2023 Tundra Platnium
    SS3 Pods, SS6 Fogs, Talon Skid & Cat, Rays ALAP 07X w/ 285/70 Toyo OC AT3, TRD Pro fenders, beat sonic amp, Peragon Tonneau,
    I can’t wait to install mine. Should be coming sometime next week. I got DD’s SS3 Pro’s in amber/yellow during their Black Friday sale and the SS6’s as well but the fogs were back ordered. I’ve seen some images of the SS6 in action but you can’t really tell how they perform. Hoping they’ll be as good as everyone says they are, but from my experience with the SS3’s I have high hopes.
  15. Jan 3, 2024 at 5:49 PM
    11748 New Member
    I like it so far, in all that has been done so far! Keep going!
    I too, am slowly working on my 2023 1794.
    Soupbean77 and jhuseby[OP] like this.
  16. Jan 23, 2024 at 5:31 PM
    4lo Toys
    4lo Toys New Member
    Andrew
    This is the info I was searching for, I have a set of the DD fogs on the way and was hoping that it could be done much simpler than their instructions made it seem. Any tips on how to remove the lower trim? I don’t want to be breaking clips on my brand new truck. Thanks!
  17. Jan 24, 2024 at 5:53 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    small plastic trim removal tool. Can start on one far side and work your way to the opposite or middle out. Either way.
    Given the tight fit from the factory, you almost have to flex the piece out and in when re-inserting. Bowing it a bit, if that makes sense.
    super easy, just go slow
    4lo Toys[QUOTED] likes this.
  18. Jan 24, 2024 at 7:09 AM
    4lo Toys
    4lo Toys New Member
    Andrew
    Thanks for the advice, I'll probably wait until it either warms up or I can get it into the shop long enough to get it warmed up. Flexing cold plastic sounds a little iffy. :cheers:
  19. Jan 24, 2024 at 7:59 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    It’s fairly thin so pretty flexible. This is the video I used to install mine that does a better job of explaining
    https://youtu.be/oGMn-lFb9-E?si=G-jqbKxhEEJuG_WO
  20. Jan 24, 2024 at 10:29 AM
    4lo Toys
    4lo Toys New Member
    Andrew
    That's way easier than the way described on DD's website. I appreciate the link!
    Goobax[QUOTED] likes this.
  21. Jun 12, 2024 at 4:40 PM
    Olego123
    Olego123 New Member
    Can you take a picture how your wired in the amber lights?!
  22. Jun 12, 2024 at 8:17 PM
    Hella Krusty
    Hella Krusty New Member
    Painted stache looks awesome
  23. Jun 13, 2024 at 1:00 PM
    jhuseby
    Johannes
    So I connected the positive to the fuse with an add a fuse as can be seen in the photo, and the negative to the ground on the side (see other picture).
  24. Jun 14, 2024 at 3:25 PM
    11748
    11748 New Member
    The submitted pictures above is how most are doing the connections using the fuse box. alternatively, a separate fuse distribution block should be used in conjunction with a decent amp rated (5-10 relay) and a Aux Switch. (Stay off the CANBUS)
    **CAUTION** If you do not fully understand CANBUS systems, I would advise not to splice into the vehicle's CANBUS attached lights and devices to run Aux lighting and other fun stuff. This could potentially interfere with other systems attached to the CANBUS system. This can include light taps used back in the old days. Also, Aux lights and other stuff could carry a higher amp draw and interfere with the CANBUS as well.
    The Control relays can be bought online (12VDC @ 5-10A rated )
    The switches I used are bought from Cali raised off road.
    hope this helps.
    BoomBoomGanoom and brtnstrns like this.
  25. Aug 19, 2024 at 10:25 PM
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    Just got my truck 2 weeks ago and am quickly slipping down this rabbit hole...Everyone still recommend the amber marker lights from eBay over other companies?
